    Timelapse pictures & videos with Duet and webcam on layer change
    43
    7.4k
    • resamundefined
      resam
      If there is enough interest, I can make it a pip package, so it is easier to install and update. For now it still requires some manual setup and configuration.
        Phaedrux Moderator @Danal
        @danal said in Timelapse pictures & videos with Duet and webcam on layer change:
        Fantastic.
        Now, we need to integrate this with the other "Proxy/Camera" Pi work that is going on, and produce a pre-built image.
        My thoughts exactly.
        • Railgunner13fundefined
          Railgunner13f
          What is a good way to set up a USB webcam to return snapshot pictures (still image) via an URL? I tried this link and it seemed to install fine. But I'm not getting an image with http://127.0.0.1:8080/?action=snapshot in the raspberry browser.
          • resamundefined
            resam
            I'm also using mjpg-streamer - there should be a bunch of different guides and how-tos out there, even specific ones for Raspberry Pi or other Linux devices.
            @Railgunner13f the link you posted does not configure it as HTTP webcam, but uses port 9000 for streaming with a different protocol. Try this instead: https://github.com/cncjs/cncjs/wiki/Setup-Guide:-Raspberry-Pi-|-MJPEG-Streamer-Install-&-Setup-&-FFMpeg-Recording (only the top part).
              Railgunner13f
              Bingo!
              I am finally capturing the stills!
              Where do I send the beer!
                Would you be able to post an example timelapse?
                • resamundefined
                  resam
                  https://www.dropbox.com/s/2ti52rimgepaq7e/2018-07-01-eggs-abs.mp4?dl=0
                  and
                  https://www.dropbox.com/s/z4az144426w9icp/2018-04-05-Einstein-bust.mp4?dl=0
                    That's great. Exactly what I was hoping for. Hopefully I can find some time to get it setup soon.
                    • resamundefined
                      resam
                      @Phaedrux let me know how the mjpg-streamer stuff works for you. I'm thinking about removing this dependency and implementing a simple frame-grabber with OpenCV in Python directly... This means the webcam can't be used for Octoprint or other tools easily, but if people only want timelapses, thats fine.
                      Phaedruxundefined Danalundefined 2 Replies Last reply Reply Quote 1
                        Phaedrux Moderator @resam
                        @resam Will do. I'm thinking I will pick up another RPi3 to run this on. Or do you think a RPiZeroW with camera module would be good enough? I currently use MotionOS on the zero to act as an IP cam.
                        • resamundefined
                          resam
                          I'm running this on a RPiZeroW - good enough for 15fps streaming of 1280x720p and the snapshots with my script.
                          • Danalundefined
                            Danal @resam
                            @resam said in Timelapse pictures & videos with Duet and webcam on layer change:
                            Would this affect the ability to have the camera visible and updating in Duet Web Control?
                            • resamundefined
                              resam
                              @Danal yes - in that case the "access to the webcam" is exclusive. Either timelapse snapshots or DWC/Octoprint/some other streaming.
                              There might be a way around it, but it involves a more complex Linux setup - which I want to avoid. I can make it optional: "quickstart = exclusive timelapse snapshot" and as second option, the existing mjpg-streamer integration via a URL.
                              Let me know how many of you want to keep DWC/Octoprint webcam access, and how many ONLY want to use timelapse snapshots.
                                T3P3Tony administrators @resam
                                @resam would it be possible to serve those timelapse shots (or rather the latest one) to DWC? For remote monitoring it gives a once per layer update.
                                • resamundefined
                                  resam
                                  @T3P3Tony probably - but the idea behind using OpenCV and ditching mjpg-streamer was to REDUCE complexity 😄
                                  For people who want to keep their DWC webcam, you should probably still use mjpg-streamer (unless somebody knows of a similar / better tool?)
                                  T3P3Tonyundefined assasinscreed00undefined 2 Replies Last reply Reply Quote 0
                                  • Danalundefined
                                    Danal
                                    Having a camera visible in DWC allows a human to periodically check from their mobile and abort prints that go wrong. And/or have the confidence at hour X that a long print is going right!! They may be checking from the next room, or across town. Timelapse is nifty to document, share, show to non-3D print people, etc. It is most desirable to capture these on the same long prints where remote monitoring is most desirable.
                                    Longwinded way of saying: If we are building an Rpi setup (or image) to provide a camera for Duet/RepRap based printers, it really should do both camera functions, seamlessly.
                                    Blending that with the desirability of a proxy function, the DWC camera view should work on "local network" or "via proxy" equally seamlessly.
                                      @resam yeah I get that. I think the big opportunity is to add that complexity back in to compare commanded movement with what happens and what the model should look like so a failed print can be detected.
                                      • garyd9undefined
                                        garyd9
                                        This thread can't be allowed to die... This tool is incredible, @resam
                                        I didn't bother with the "M400" or "G4 P500", and it's still perfect. If the snapshot isn't exactly on the layer change, it's okay. As long as I get a snapshot each layer, it's all good.
                                        It would be nice of the script had an option to automagically run ffmpeg and then (on success) remove the jpg directory. Perhaps if I ever get any free time, I'll add that functionality (and adjust the focus on my pi camera.)
                                        thank you!
                                        Edit: first time lapse using this code (camera is mounted in a temporary location, so haven't bothered with focus yet.) https://youtu.be/inLM1-AvhUo
                                        Gary
                                        • bjoern85undefined
                                          bjoern85
                                          Can you make a small guide, how to set this up on an sbc?
                                          After cloning from github i don't know what to do... 😞
                                          I'm using another SBC with octoprint, webcam and octolapse. But the connection to the duet ethernet is not fast enough sometimes.
                                          I would love to make timelapses with my deltaprinter.
                                          Thank you for all your work 🙂
                                          resamundefined 1 Reply Last reply Reply Quote 0
                                          • resamundefined
                                            resam @bjoern85
                                            @bjoern85 did you try starting the script as documented in the README?
                                            From your SBC terminal (or SSH):
                                            ./timelapse.py <folder> <duet_host> <webcam_url>
                                            bjoern85undefined 1 Reply Last reply Reply Quote 0
