    Timelapse pictures & videos with Duet and webcam on layer change
    43
    7.5k
      Would you be able to post an example timelapse?
      • resamundefined
        resam
        https://www.dropbox.com/s/2ti52rimgepaq7e/2018-07-01-eggs-abs.mp4?dl=0
        and
        https://www.dropbox.com/s/z4az144426w9icp/2018-04-05-Einstein-bust.mp4?dl=0
          That's great. Exactly what I was hoping for. Hopefully I can find some time to get it setup soon.
          • resamundefined
            resam
            @Phaedrux let me know how the mjpg-streamer stuff works for you. I'm thinking about removing this dependency and implementing a simple frame-grabber with OpenCV in Python directly... This means the webcam can't be used for Octoprint or other tools easily, but if people only want timelapses, thats fine.
            Phaedruxundefined Danalundefined 2 Replies Last reply Reply Quote 1
              Phaedrux Moderator @resam
              @resam Will do. I'm thinking I will pick up another RPi3 to run this on. Or do you think a RPiZeroW with camera module would be good enough? I currently use MotionOS on the zero to act as an IP cam.
              • resamundefined
                resam
                I'm running this on a RPiZeroW - good enough for 15fps streaming of 1280x720p and the snapshots with my script.
                • Danalundefined
                  Danal @resam
                  @resam said in Timelapse pictures & videos with Duet and webcam on layer change:
                  Would this affect the ability to have the camera visible and updating in Duet Web Control?
                  • resamundefined
                    resam
                    @Danal yes - in that case the "access to the webcam" is exclusive. Either timelapse snapshots or DWC/Octoprint/some other streaming.
                    There might be a way around it, but it involves a more complex Linux setup - which I want to avoid. I can make it optional: "quickstart = exclusive timelapse snapshot" and as second option, the existing mjpg-streamer integration via a URL.
                    Let me know how many of you want to keep DWC/Octoprint webcam access, and how many ONLY want to use timelapse snapshots.
                      T3P3Tony administrators @resam
                      @resam would it be possible to serve those timelapse shots (or rather the latest one) to DWC? For remote monitoring it gives a once per layer update.
                      • resamundefined
                        resam
                        @T3P3Tony probably - but the idea behind using OpenCV and ditching mjpg-streamer was to REDUCE complexity 😄
                        For people who want to keep their DWC webcam, you should probably still use mjpg-streamer (unless somebody knows of a similar / better tool?)
                        T3P3Tonyundefined assasinscreed00undefined 2 Replies Last reply Reply Quote 0
                        • Danalundefined
                          Danal
                          Having a camera visible in DWC allows a human to periodically check from their mobile and abort prints that go wrong. And/or have the confidence at hour X that a long print is going right!! They may be checking from the next room, or across town. Timelapse is nifty to document, share, show to non-3D print people, etc. It is most desirable to capture these on the same long prints where remote monitoring is most desirable.
                          Longwinded way of saying: If we are building an Rpi setup (or image) to provide a camera for Duet/RepRap based printers, it really should do both camera functions, seamlessly.
                          Blending that with the desirability of a proxy function, the DWC camera view should work on "local network" or "via proxy" equally seamlessly.
                            @resam yeah I get that. I think the big opportunity is to add that complexity back in to compare commanded movement with what happens and what the model should look like so a failed print can be detected.
                            • garyd9undefined
                              garyd9
                              This thread can't be allowed to die... This tool is incredible, @resam
                              I didn't bother with the "M400" or "G4 P500", and it's still perfect. If the snapshot isn't exactly on the layer change, it's okay. As long as I get a snapshot each layer, it's all good.
                              It would be nice of the script had an option to automagically run ffmpeg and then (on success) remove the jpg directory. Perhaps if I ever get any free time, I'll add that functionality (and adjust the focus on my pi camera.)
                              thank you!
                              Edit: first time lapse using this code (camera is mounted in a temporary location, so haven't bothered with focus yet.) https://youtu.be/inLM1-AvhUo
                              Gary
                              • bjoern85undefined
                                bjoern85
                                Can you make a small guide, how to set this up on an sbc?
                                After cloning from github i don't know what to do... 😞
                                I'm using another SBC with octoprint, webcam and octolapse. But the connection to the duet ethernet is not fast enough sometimes.
                                I would love to make timelapses with my deltaprinter.
                                Thank you for all your work 🙂
                                resamundefined 1 Reply Last reply Reply Quote 0
                                • resamundefined
                                  resam @bjoern85
                                  @bjoern85 did you try starting the script as documented in the README?
                                  From your SBC terminal (or SSH):
                                  ./timelapse.py <folder> <duet_host> <webcam_url>
                                  bjoern85undefined 1 Reply Last reply Reply Quote 0
                                  • bjoern85undefined
                                    bjoern85 @resam
                                    @resam thank you! and sorry for my late reply. i'm testing it right now.
                                    it looks, like it works. somehow... i was able to download a single jpg file during the print, which has a size of 2gb 😵 but i could not open it.
                                    edit: ...achtion=snapshot instead of ...action=stream would help, i guess 🙃
                                    • garyd9undefined
                                      garyd9
                                      I have to admit that my reply to this thread is, at least in part, a bump to keep it from dying... it's just too valuable.
                                      On the other hand, I do have updated information, @resam, in regards to using this script with RR3 on a Duet3 (in standalone mode.)
                                      For some reason, using the script from your github (pulled on 24th of Jan, 2020), the process would stop working after each print. It was almost as if the telnet session froze or locked up or something after the print finished and ffmpeg was run. I'd see the 'Print finished' message, the mp4 would be created, and then it wouldn't start again when a new print was started.
                                      I've modified my version of the script to deal with that by breaking from the "while true" loop after a print is finished and inserting the code below before the exception handler (at the same scope as the "while true"):
                                      conn = None
                                      sock.shutdown(socket.SHUT_RDWR)
                                      sock.close()
                                      This should break the loop, shutdown and close the socket, and then loop back up for another connection attempt (which usually works fine.)
                                      Take care
                                      Gary
                                      • resamundefined
                                        resam
                                        Thanks @garyd9 - I haven't tested it yet on RRF3 (still need to upgrade my printers).
                                        I'm a bit surprised because we do have error handling that should auto-reconnect if any failure with the telnet socket occurs: https://github.com/Kriechi/DuetRRF-timelapse/blob/d2b472ceb26491f07812c030e00ee1005d69487b/timelapse.py#L136
                                        I'm happy to add more error handling - but at this point I'm not sure what actually hangs/blocks. Or did anything in RRF3 change regarding the way telnet connections are handled @dc42?
                                        • assasinscreed00undefined
                                          assasinscreed00 @resam
                                          @resam So I'm a noob with python and rasperry pi's but I think I mostly understand the github and what i need to do, but you said you ditched mjpg streamer and instead use OpenCv, I can't find how to setup OpenCV to host the webcam image on a url. Can I still use mjpg streamer (seems easier for a noob to setup)
                                          • resamundefined
                                            resam
                                            @assasinscreed00 I don't remember saying I ditched OpenCV - I still use mjpg streamer, just like almost every tutorial on the internet.
                                            assasinscreed00undefined 1 Reply Last reply Reply Quote 0
