    My custom Cartesian
    My Duet controlled machine
    14
    152
    23.4k
    • OBELIKSundefined
      OBELIKS
      @wilriker Well soon I will be able to tell you if those Wantai 42BYGHM810 are any good. I checked and ruled out everything but steppers, so I ordered these.
      P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
      Original Prusa i3 MK3S
      • wilrikerundefined
        wilriker @OBELIKS
        @obeliks I have to admit I miss a little bit of reference of what problem you are trying to solve. 😕
        I thought about these motors now for a while. My largest uncertainty is the difference in motor length compared to what I currently have. Since I use dampers on the motors these additional 8mm could be a problem for at least Y axis as my holder for the heated bed has a rather small cut-out for the motor.
        But then again, motors are probably not going to be the very next thing to exchange, so lots of more time to think about it. 🙂
        Manuel
        My Tool Collection
        • OBELIKSundefined
          OBELIKS
          Heh, don't worry about it.
          I just wanted to say I will be able to report soon.
          • wilrikerundefined
            wilriker @OBELIKS
            @obeliks What I am very interested in is the question if these motors will have an audably different noise level and if so in which direction.
            Manuel
            My Tool Collection
            • OBELIKSundefined
              OBELIKS
              I will measure before and after.
              • wilrikerundefined
                wilriker @OBELIKS
                @obeliks Cool, thanks! Looking forward to the results of that. Because if they are more silent, guess what's next on my to-do list. 😁
                Manuel
                My Tool Collection
                • OBELIKSundefined
                  OBELIKS
                  First thing, package was here in 3 working days and it came from Germany.
                  Now the big problem (maybe?), the shafts have no flat spot. At all.
                  Second small problem, the leads are short.
                  deckingmanundefined wilrikerundefined 2 Replies Last reply Reply Quote 0
                    deckingman @OBELIKS
                    @obeliks No flats is no big problem - all you need is a file. The shafts aren't usually hardened so it's easy to do.
                    • OBELIKSundefined
                      OBELIKS
                      @deckingman Ah, not hardened, OK then. Thanks.
                      I haven't even tried, I'm just from the vacation. The good thing is that next week I'm still at home.
                        deckingman @OBELIKS
                        @obeliks Yes it's dead easy to do. I've filed flats on all 10 of my motors.
                        • wilrikerundefined
                          wilriker @OBELIKS
                          @obeliks said in My custom Cartesian:
                          Yeah, Wantai has a European warehouse in Hamburg here in Germany. So, if you ordered from their "EU Stock" it'll come from there. 🙂
                          Manuel
                          My Tool Collection
                          • OBELIKSundefined
                            OBELIKS
                            Results are in they are about 5dB quieter and 5°C cooler than stock A8 steppers
                            Also, it seems I am melting.
                            • wilrikerundefined
                              wilriker @OBELIKS
                              @obeliks Definitely sounds great! 👍 At what settings do you run them?
                              Manuel
                              My Tool Collection
                              • OBELIKSundefined
                                OBELIKS
                                Just like on A8 steppers 50%, so 1200mA in case of Wantai.
                                The loudest ones are Z-axis, but that is related to M5 leadscrew.
                                • Witchdoctrundefined
                                  Witchdoctr
                                  Just wanted to say thank you for your build log.
                                  I went a very similar route to you, started with an Anet A8 and am now left with a box full of spare bits that looks suspiciously like an Anet A8 (Only thing left is the stepper motors and guides)...
                                  The Duet was a bit of a pain to configure after using Marlin but the first test benches turned out like a dream with your settings.
                                  So thanks again!
                                  • wilrikerundefined
                                    wilriker @Witchdoctr
                                    @witchdoctr said in My custom Cartesian:
                                    I'm glad that this helped you. 🙂
                                    Manuel
                                    My Tool Collection
                                    • wilrikerundefined
                                      wilriker
                                      @OBELIKS Can you measure the length of your Anet stock steppers? I just measured the length of the newer 0.9A steppers and they are not 40mm but only 37.3mm long.
                                      So compared to the 48mm long Wantai steppers (would you be so kind to measure their length as well?) that is an extra of over 10mm and I have a feeling that I will not be able to fit them everywhere. 😕
                                      Manuel
                                      My Tool Collection
                                      OBELIKSundefined 1 Reply Last reply Reply Quote 0
                                      • OBELIKSundefined
                                        OBELIKS @wilriker
                                        @wilriker sure, tomorrow. I wrapped up for today.
                                        • OBELIKSundefined
                                          OBELIKS
                                          Eh, I needed to fetch a beer from the storage. So I hopped in to the "workshop"
                                          Anet steppers are 37,8mm long and Wantai real length is 46,8mm.
                                          And the beer is imperial IPA with 10% alcohol. And it is brilliant.
                                          wilrikerundefined 1 Reply Last reply Reply Quote 3
                                          • wilrikerundefined
                                            wilriker @OBELIKS
                                            Thanks for that! 👍 Will measure on the weekend of I can fit them. Biggest issue might be Y axis as my heat bed holder has only a certain width cutout for the motor.
                                            I am all but a beer type but happy that you have something you enjoy. 🙂
                                            Manuel
                                            My Tool Collection
