    My custom Cartesian
    My Duet controlled machine
    14
    152
    23.2k
    • wilrikerundefined
      wilriker @OBELIKS
      @obeliks I have to admit I miss a little bit of reference of what problem you are trying to solve. 😕
      I thought about these motors now for a while. My largest uncertainty is the difference in motor length compared to what I currently have. Since I use dampers on the motors these additional 8mm could be a problem for at least Y axis as my holder for the heated bed has a rather small cut-out for the motor.
      But then again, motors are probably not going to be the very next thing to exchange, so lots of more time to think about it. 🙂
      Manuel
      My Tool Collection
      • OBELIKSundefined
        OBELIKS
        Heh, don't worry about it.
        I just wanted to say I will be able to report soon.
        P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
        Original Prusa i3 MK3S
        • wilrikerundefined
          wilriker @OBELIKS
          @obeliks What I am very interested in is the question if these motors will have an audably different noise level and if so in which direction.
          Manuel
          My Tool Collection
          • OBELIKSundefined
            OBELIKS
            I will measure before and after.
            • wilrikerundefined
              wilriker @OBELIKS
              @obeliks Cool, thanks! Looking forward to the results of that. Because if they are more silent, guess what's next on my to-do list. 😁
              Manuel
              My Tool Collection
              • OBELIKSundefined
                OBELIKS
                First thing, package was here in 3 working days and it came from Germany.
                Now the big problem (maybe?), the shafts have no flat spot. At all.
                Second small problem, the leads are short.
                deckingmanundefined wilrikerundefined 2 Replies Last reply Reply Quote 0
                  deckingman @OBELIKS
                  @obeliks No flats is no big problem - all you need is a file. The shafts aren't usually hardened so it's easy to do.
                  • OBELIKSundefined
                    OBELIKS
                    @deckingman Ah, not hardened, OK then. Thanks.
                    I haven't even tried, I'm just from the vacation. The good thing is that next week I'm still at home.
                      deckingman @OBELIKS
                      @obeliks Yes it's dead easy to do. I've filed flats on all 10 of my motors.
                      • wilrikerundefined
                        wilriker @OBELIKS
                        @obeliks said in My custom Cartesian:
                        Yeah, Wantai has a European warehouse in Hamburg here in Germany. So, if you ordered from their "EU Stock" it'll come from there. 🙂
                        Manuel
                        My Tool Collection
                        • OBELIKSundefined
                          OBELIKS
                          Results are in they are about 5dB quieter and 5°C cooler than stock A8 steppers
                          Also, it seems I am melting.
                          • wilrikerundefined
                            wilriker @OBELIKS
                            @obeliks Definitely sounds great! 👍 At what settings do you run them?
                            Manuel
                            My Tool Collection
                            • OBELIKSundefined
                              OBELIKS
                              Just like on A8 steppers 50%, so 1200mA in case of Wantai.
                              The loudest ones are Z-axis, but that is related to M5 leadscrew.
                              • Witchdoctrundefined
                                Witchdoctr
                                Just wanted to say thank you for your build log.
                                I went a very similar route to you, started with an Anet A8 and am now left with a box full of spare bits that looks suspiciously like an Anet A8 (Only thing left is the stepper motors and guides)...
                                The Duet was a bit of a pain to configure after using Marlin but the first test benches turned out like a dream with your settings.
                                So thanks again!
                                • wilrikerundefined
                                  wilriker @Witchdoctr
                                  @witchdoctr said in My custom Cartesian:
                                  I'm glad that this helped you. 🙂
                                  Manuel
                                  My Tool Collection
                                  • wilrikerundefined
                                    wilriker
                                    @OBELIKS Can you measure the length of your Anet stock steppers? I just measured the length of the newer 0.9A steppers and they are not 40mm but only 37.3mm long.
                                    So compared to the 48mm long Wantai steppers (would you be so kind to measure their length as well?) that is an extra of over 10mm and I have a feeling that I will not be able to fit them everywhere. 😕
                                    Manuel
                                    My Tool Collection
                                    OBELIKSundefined 1 Reply Last reply Reply Quote 0
                                    • OBELIKSundefined
                                      OBELIKS @wilriker
                                      @wilriker sure, tomorrow. I wrapped up for today.
                                      • OBELIKSundefined
                                        OBELIKS
                                        Eh, I needed to fetch a beer from the storage. So I hopped in to the "workshop"
                                        Anet steppers are 37,8mm long and Wantai real length is 46,8mm.
                                        And the beer is imperial IPA with 10% alcohol. And it is brilliant.
                                        wilrikerundefined 1 Reply Last reply Reply Quote 3
                                        • wilrikerundefined
                                          wilriker @OBELIKS
                                          Thanks for that! 👍 Will measure on the weekend of I can fit them. Biggest issue might be Y axis as my heat bed holder has only a certain width cutout for the motor.
                                          I am all but a beer type but happy that you have something you enjoy. 🙂
                                          Manuel
                                          My Tool Collection
                                          • OBELIKSundefined
                                            OBELIKS
                                            If it's aluminum bed holder, just chop it.
