    Duet Web Control wishlist notes and priorities
    32
    116
    21.1k
    • ShadowXundefined
      ShadowX @Phaedrux
      @phaedrux
      Understood. But its a bit inconvenient. The majority of the code should already exist since he has a "Download as zip" file for the System Editor settings and G-code files already. If the Macros also has that function, it would make backing up the Macros much easier.
      • chrishammundefined
        chrishamm administrators
        @deckingman Sorry for the confusion, my bad. It's fixed in 1.22-b3 which is now available here: https://github.com/chrishamm/DuetWebControl/blob/dev/DuetWebControl-1.22-b3.zip
        @ShadowX It is already possible to download macro files as a ZIP bundle but the code behind does not support zipping up entire directories yet. I guess that is the reason why this option appears to be hidden for you.
        Duet software engineer
        ShadowXundefined wilrikerundefined deckingmanundefined 3 Replies Last reply Reply Quote 0
          The List items functionality is still off. It lists every single gcode I've entered into the console and even if I delete them they just show up again on the next reload. Any new ones I purposely enter using the add gcode button don't remain after a reload either.
          • ShadowXundefined
            ShadowX @chrishamm
            @chrishamm
            Okay, that makes sense. I did have directories inside the folder to sort the different macro sets.
            • wilrikerundefined
              wilriker @chrishamm
              @chrishamm Again thanks for coming up with fixes so quickly. 👍
              Now I only need my Connect/Disconnect button back. 😉
              Or - and that would also be OK for me - drastically reduce the AJAX calls when the tab is in the background and no print is ongoing. And by drastically I mean intervals of at least 1 minute. This could even be made a setting.
              Just thinking: is the longer interval for background tabs an implemented feature or is that just what my browser (Vivaldi) does and you have no control over it?
              Manuel
              My Tool Collection
              • DaveAundefined
                DaveA
                Just installed 1.22.b3 and everything has moved. Machine status on left, temp graph on right., tool control in the middle. And I also don't have a connect button.
                Is this intentional?
                  chrishamm administrators @Phaedrux
                  @phaedrux That is not surprising because you apparently did not save the settings after deleting those entries. I just checked and it does work.
                  @wilriker You can already do that. Just change the AJAX update interval to 60000 and it will send exactly one update request per minute.
                  @DaveA Yes, it is. I don't think there is any point in leaving the Connect/Disconnect button on the UI - if you want to disconnect, close the browser tab. Reconnecting will happen automatically anyway from now on.
                  • JoduWeiundefined
                    JoduWei
                    make machine control modular! It would be nice, if i could remove, add widgets and edit widgets (every widget has its own file)
                    • wilrikerundefined
                      wilriker @chrishamm
                      @chrishamm said in Duet Web Control wishlist notes and priorities:
                      But that will reduce all AJAX updates to be 60s apart (and in background even 120s). What I would like is the following (in my case I already have AJAX update rate set to 1s interval):
                      1. Tab in foreground: selected update interval
                      2. Tab in background and print ongoing: 2x interval as selected (this is currently what I get whenever the tab is in background, i.e. 2s update interval for my settings)
                      3. Tab in background with no print: 60s update interval - or even paused but this may lead to not going to 2) above if a print is started another way/session
                      I usually keep my tabs open and in specific positions inside my tab bar (they form some kind of logical groups) and I only close tabs that I will not use for longer, so what you recommended to @DaveA would heavily disrupt my workflow.
                      I could also live with a configurable visibility of a Connect/Disconnect button that is invisible by default.
                      Manuel
                      My Tool Collection
                        If a web client doesn't request an update for more than 8 seconds and isn't doing a file upload, it will be timed out after 8 seconds. So you shouldn't reduce the polling rate to below about once every 5 seconds, unless the automatic reconnect mechanism is working really well.
                        • wilrikerundefined
                          wilriker @dc42
                          @dc42 said in Duet Web Control wishlist notes and priorities:
                          OK, then this leaves me with my request to get the Connect/Disconnect button back as virtually the only option. 😕
                          Manuel
                          My Tool Collection
                            @dc42 and @wilriker I think you only need to worry about session timeouts if you have a password configured. If none is set, RRF does not deny rr_* request and thus the web interface should remain functional even with status update intervals greater than 8 seconds. And if DWC encounters multiple AJAX errors (e.g. because the session timed out), v1.22 attempts to reconnect automatically with the last entered password. I suggest you try it out and if it does not work in the way you expect, I'll consider adding back the Connect/Disconnect buttons.
                            • wilrikerundefined
                              wilriker @chrishamm
                              @chrishamm I don't have a non-default password set, so no problem on this end.
                              Still I would need a way to configure a separate (tab in) background update interval if no print is running. I do want my 1s-updates when tab is in foreground and I am ok with 2s-updates when tab is in background and printing. I just need this third case.
                              Manuel
                              My Tool Collection
                                deckingman @chrishamm
                                Confirmed fixed. Thanks.
                                • wilrikerundefined
                                  wilriker
                                  @chrishamm I have to apologize. I am doing something here, that I, as a professional software developer, always complain about: I told you what I want you to implement. I'm sorry this is bad behavior.
                                  Instead I am now going to tell you what I need in terms of functionality:
                                  I need an (at least semi-)automatic way to considerably reduce non-printing background traffic (even down to zero).
                                  It would be acceptable for me to push a button or to configure a setting or something similar.
                                  It is not acceptable to me to have to change settings all the time.
                                  I will be happy to accept whatever you implement as long as it fulfills my above description.
                                  And just to be clear this is just a request not an order nor an expectation.
                                  Manuel
                                  My Tool Collection
                                    Phaedrux Moderator @wilriker
                                    @wilriker I'm curious how much bandwidth is actually being used. I suppose on a metered connection everything adds up.
                                    • wilrikerundefined
                                      wilriker @Phaedrux
                                      @phaedrux I'd have to calculate this again but AFAIR it did sum up to something between 1 and 2 GB per month just for the Ajax updates in my use-case. This does not include any further interaction with the Duet.
                                      Currently I have a monthly included traffic of 10GB on the connection I need to use for this which is more than sufficient but this will drop to only 1GB in September.
                                      Manuel
                                      My Tool Collection
                                      • whosrdaddyundefined
                                        whosrdaddy
                                        @Phaedrux : well it consumes quite a bit, open F12 on IE or Chrome and see what I mean, on a local network this is no problem, but can be problematic on mobile...
                                          So I've just released v1.22 of the web interface, see https://github.com/chrishamm/DuetWebControl/releases/tag/1.22 for the ZIP bundle and the full change log since the last stable version.
                                          @wilriker This version brings back the Connct/Disconnect button too, although you need to enable it explicitly on the Settings page. I guess that is OK.
                                          wilrikerundefined 1 Reply Last reply Reply Quote 2
                                          • zerspaner_gerdundefined
                                            zerspaner_gerd
                                            With German language setting, you can not create new system files
                                            Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
                                            gideonundefined 1 Reply Last reply Reply Quote 0
