    Dave's so proud
    47
    4.8k
    • fcwiltundefined
      fcwilt @sjason1377
      @sjason1377 said in Dave's so proud:
      this is a $5000 print 200lbs 16 stepper quad motor per axis large format all external 5.6 amp drive machine.
      Impressive. What is the point you are trying to make?
      • sjason1377undefined
        sjason1377 Banned
        it's not on my end. It's his code and again he won't admit what he was force to admit a year ago. Once again Im the lair. Until a few hundred other agree and he fixes it. Until than I can't print.
          deckingman @sjason1377
          @sjason1377 If the machine is reporting firmware as being 2.0 as you have posted, then that is what you've installed. The version you should be using, which has been pointed out numerous times is 2.01. Just look at the release notes and the bug fixes.
          Oh and don't send me this again like you did last time I tried to help. For the rest of you, this is a quote from an email that this guy sent me a while back
          Quote....
          Hey Just wanted to respond. You wear your feelings on your sleeve like a little bitch! Stop proof reading old post and concentrate on the real issues. How bout the faulty board dc42 is refusing to honor warranty for after admitting it the mcu path that is defective. I'm a ginny pig for his testing, not a costumer I see. Just stop being a winney lit bitch, You fucking fag!"
          ..........end of quote.
          So be warned people. If you try to help this guy, that's the kind of abuse that you'll get for your efforts.
          fcwiltundefined sjason1377undefined 2 Replies Last reply Reply Quote 0
          • fcwiltundefined
            fcwilt @deckingman
            @deckingman said in Dave's so proud:
            Well I hope he builds printers better than he spells.
              sjason1377 Banned
              RepRapFirmware for Duet 2 WiFi/Ethernet
              Firmware Electronics: Duet Ethernet 1.02 or later
              Firmware Version: 2.0(RTOS) (2018-06-05b3)
              Web Interface Version: 1.21.2-dc42
              this is what he told me to upload direct from his link
              • fcwiltundefined
                fcwilt @sjason1377
                Seems to me he suggested you install 2.01.
                  sjason1377 Banned
                  i did but thats what board is reporting
                  fcwiltundefined Danalundefined 2 Replies Last reply Reply Quote 0
                  • fcwiltundefined
                    fcwilt @sjason1377
                    So that tells you that the firmware did not get updated.
                    Double check you are trying to upload the 2.01 version and try again.
                      sjason1377 Banned
                      Firmware Version: 2.01(RTOS) (2018-07-26b2)
                      ok guess what probe doesn't work still
                        sjason1377 Banned
                        M574 X1 Y1 S1 ; Set active low endstops
                        M574 Z0
                        M558 P9 X0 Y0 Z1 H5 F100 T2000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
                        G31 P600 X0 Y12 Z.96; Set Z probe trigger value, offset and trigger height
                        M557 X52:300 Y60:335 S40 ; Define mesh grid
                          deckingman
                          This post is deleted!
                          • Danalundefined
                            Danal @sjason1377
                              sjason1377 Banned
                                sjason1377 Banned
                                M574 Z0
                                correct version and correct wording in config.g probe is unresponsive. a year of flawless performance under build 1.19.1 and now nothing.
                                fcwiltundefined 2 Replies Last reply Reply Quote 0
                                • Danalundefined
                                  Danal
                                  • fcwiltundefined
                                    fcwilt @sjason1377
                                    M574 Z0
                                    The current docs for M558 report that the X, Y and Z parameters are obsolete.
                                    Perhaps that is causing some sort of problem?
                                      sjason1377 Banned
                                      I would never had upgraded except for those false heater faults he said was a bug from the old version. Now he's got no support for this problem because he won't admit there is one. That my issue. It take many failures from many user before he responds. History proves I was not at fault before. I'm not now either.
                                        sjason1377 Banned
                                        I'm not proud I'm not saying I have any answers. I know my spelling sucks. But I'm no liar. We depend on him to help with these issue. But where does that leave us when he won't help.
                                        • botundefined
                                          bot
                                          Do you expect David to drop everything in his real life to help one of the rudest users ever to come on these boards?
                                          You need to learn to be patient, and/or how to resolve issues yourself.
                                          *not actually a robot
                                          • Danalundefined
                                            Danal
                                            Ooops... just read the whole thread from the top.
                                            BYE.
                                            You want support from the community, you need a whole different attitude.
