    Dave's so proud
    47
    4.9k
    • fcwiltundefined
      fcwilt @deckingman
      @deckingman said in Dave's so proud:
      So be warned people. If you try to help this guy, that's the kind of abuse that you'll get for your efforts.
      Well I hope he builds printers better than he spells.
      • sjason1377undefined
        sjason1377 Banned
        RepRapFirmware for Duet 2 WiFi/Ethernet
        Firmware Electronics: Duet Ethernet 1.02 or later
        Firmware Version: 2.0(RTOS) (2018-06-05b3)
        Web Interface Version: 1.21.2-dc42
        this is what he told me to upload direct from his link
        • fcwiltundefined
          fcwilt @sjason1377
          @sjason1377 said in Dave's so proud:
          Seems to me he suggested you install 2.01.
            sjason1377 Banned
            i did but thats what board is reporting
            fcwiltundefined Danalundefined 2 Replies Last reply Reply Quote 0
            • fcwiltundefined
              fcwilt @sjason1377
              So that tells you that the firmware did not get updated.
              Double check you are trying to upload the 2.01 version and try again.
                sjason1377 Banned
                Firmware Version: 2.01(RTOS) (2018-07-26b2)
                ok guess what probe doesn't work still
                  sjason1377 Banned
                  M574 X1 Y1 S1 ; Set active low endstops
                  M574 Z0
                  M558 P9 X0 Y0 Z1 H5 F100 T2000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
                  G31 P600 X0 Y12 Z.96; Set Z probe trigger value, offset and trigger height
                  M557 X52:300 Y60:335 S40 ; Define mesh grid
                    deckingman
                    This post is deleted!
                    • Danalundefined
                      Danal @sjason1377
                        sjason1377 Banned
                          sjason1377 Banned
                          M574 Z0
                          correct version and correct wording in config.g probe is unresponsive. a year of flawless performance under build 1.19.1 and now nothing.
                          fcwiltundefined 2 Replies Last reply Reply Quote 0
                          • Danalundefined
                            Danal
                            • fcwiltundefined
                              fcwilt @sjason1377
                              M574 Z0
                              The current docs for M558 report that the X, Y and Z parameters are obsolete.
                              Perhaps that is causing some sort of problem?
                                sjason1377 Banned
                                I would never had upgraded except for those false heater faults he said was a bug from the old version. Now he's got no support for this problem because he won't admit there is one. That my issue. It take many failures from many user before he responds. History proves I was not at fault before. I'm not now either.
                                  sjason1377 Banned
                                  I'm not proud I'm not saying I have any answers. I know my spelling sucks. But I'm no liar. We depend on him to help with these issue. But where does that leave us when he won't help.
                                  • botundefined
                                    bot
                                    Do you expect David to drop everything in his real life to help one of the rudest users ever to come on these boards?
                                    You need to learn to be patient, and/or how to resolve issues yourself.
                                    *not actually a robot
                                    • Danalundefined
                                      Danal
                                      Ooops... just read the whole thread from the top.
                                      BYE.
                                      You want support from the community, you need a whole different attitude.
                                      • fcwiltundefined
                                        fcwilt @sjason1377
                                        M574 Z0
                                        Do you have a Z endstop in addition to the Z probe?
                                        In the M574 Z0 there is no S parameter - which indicates an active high endstop - is that correct?
                                          sjason1377 Banned
                                          yes that's correct. I went back to p7 and it works now
                                          fcwiltundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                            sjason1377 Banned @deckingman
                                            @deckingman eat my load!
