    Javascript error after auto bed compensation
    1.5k
    • ajcraig99undefined
      ajcraig99
      Just updated to 1.21.2-dc42 and still get the error
      JavaScript Error
      A JavaScript error has occurred so the web interface has closed the connection to your board. It is recommended to
      reload the web interface now. If this happens again, please contact the author and share this error message:
      Version: 1.21.2-dc42
      Message: Uncaught TypeError: Cannot read property 'getExtension' of null
      URL: http://192.168.1.11/js/dwc.js
      Line: 15:296307
      Error object: {}
      General Info:
      Firmware Name:	RepRapFirmware for Duet 2 WiFi/Ethernet
      Firmware Electronics:	Duet WiFi 1.02 or later
      Firmware Version:	1.21 (2018-03-21)
      WiFi Server Version:	1.21RC4(08b3)
      Web Interface Version:	1.21.2-dc42
        ajcraig99
        Have also updated the WIFI server to 1.21 to no avail.
          ajcraig99
          Any suggestions?
            I don't know if this will help, but you could try pressing "Load factory defaults" followed by "Apply settings" on the Settings/User Interface page of DWC.
              ajcraig99
              Thanks, I will give that a shot when I get home tonight. I found it works no problem on my phone this morning so I updated java on my PC but that didn't work. Will report back
                ajcraig99
                Still no luck. It works fine on Edge browser though
                  dc42 administrators @ajcraig99
                  @ajcraig99 said in Javascript error after auto bed compensation:
                  Have you tried DWC 1.22, available at https://github.com/chrishamm/DuetWebControl/blob/master/DuetWebControl-1.22.zip (follow that link, then press Download)?
                  ajcraig99undefined 1 Reply Last reply Reply Quote 0
                    ajcraig99 @dc42
                    Just installed 1.22, no luck.
                     × JavaScript Error
                    A JavaScript error has occurred so the web interface has closed the connection to your board. It is recommended to reload the web interface now. If this happens again, please contact the author and share this error message:
                    Version: 1.22
                    Line: 15:296307
                    Error object: {}
                    • JoergS5undefined
                      JoergS5 @ajcraig99
                      @ajcraig99 There was a thread here:
                      https://github.com/mrdoob/three.js/issues/4927
                      with different possibilities, one of them chrome having problems with WebGL. And one quick check was to call
                      https://get.webgl.org/
                      whether this page works.
                      arefin86 created this issue in mrdoob/three.js
                      closed Error creating WebGL context #4927
                      ajcraig99undefined 1 Reply Last reply Reply Quote 1
                        ajcraig99 @JoergS5
                        @joergs5
                        Thankyou, although my graphics drivers were up to date, I reinstalled chrome which solved the issue.
                        JoergS5undefined 1 Reply Last reply Reply Quote 1
                        • JoergS5undefined
                          JoergS5 @ajcraig99
                          @ajcraig99 That's fine. Sometimes reinstall or reboots solves a problem.
                          • gnatmanundefined
                            gnatman
                            Im getting a similar issue. Though my error reads;
                            Version 1.22
                            Message: Uncaught TypeError:rememberedGCodes.indexOf is not a function
                            url:http://ipaddressofprinter/js/dwc.jc
                            Line: 1175:69
                            Error object: {}
                            it makes it hard to type in a gcode command to move the head. it does it after bed leveling too. I thought it might have been from my filament sensors but it wasn't from that.
                              T3P3Tony administrators @gnatman
                              @gnatman your DWC is out of sync with the firmware i think. I would grade to the latest stable firmware and DWC:
                              https://github.com/dc42/RepRapFirmware/releases/tag/2.01
                              make sure you read the Whats New file for all releases in between your current one and 2.01:
                              https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md
