    Dude over Bed Compensation
    • peirofundefined
      peirof
      How works bed compensation?.
      Option A. Nozzle follow bed.
      When print, nozzle follows the bed profile, and matain this profile in all print
      Option B. Nozzle at start follow bed, and after print in plane
      When print, in first layers, nozzle follows bed, but after some layers, they are perfect plane.
      Why answer this?
      I have to print a piece, and it is important that it is flat, as flat as possible, depending on how I print Duet, I will choose one option or another. These are the ones I consider:
      • If bed compensation, use system A. I would give the piece more thickness in the base, and then sand it ... I think it would be worth it.
      • If bed compesation, use system B, I would place the piece in the Slicer, lifted from the bed, a few centimeters. That distance, will depend, of encuantas layers, the bed compensation look for the perfect plane. This would be the ideal option
        deckingman
        This should help
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M376_Set_bed_compensation_taper
        Ultimately, to print a perfectly flat piece, there is no substitute fro a perfectly flat build plate.
        peirofundefined 1 Reply Last reply Reply Quote 1
        • peirofundefined
          peirof @deckingman
          @deckingman yes.... Help me. Thanks
            Another option would be to use bed compensation taper, and print on a raft that is a little thicker than the taper height.
            peirofundefined 1 Reply Last reply Reply Quote 0
              What is the minimum taper height?
              • peirofundefined
                peirof @dc42
                @dc42 Where can find info of bed compensation taper?
                  https://duet3d.dozuki.com/Wiki/GCode#Section_M376_Set_bed_compensation_taper
