    New Product Release - Precision Piezo Orion
    Third-party add-ons
    20
    79
    13.9k
    • burtoogleundefined
      burtoogle @pogo1213
      Hello @pogo1213 . Is it the Orion groove mount STL you want? If so, I can provide that and also a modified version that I am currently using because the original did not fit well and was also too flexible.
      Orion groovemount original stl + my hacked version
      • hevilpundefined
        hevilp
        Hi, there are any news on the chimera mount?
        Moriquendiundefined 1 Reply Last reply Reply Quote 0
        • Moriquendiundefined
          Moriquendi @hevilp
          @hevilp Chimera mount is out with beta testers at the moment but I haven't heard back from them yet.
          keyz182undefined 1 Reply Last reply Reply Quote 0
          • keyz182undefined
            keyz182 @Moriquendi
            @moriquendi said in New Product Release - Precision Piezo Orion:
            Oooh, I've been looking for a better way to mount my Chimera, please keep us updated 🙂
              Moriquendi
              I've just uploaded the prototype Chimera/Cyclops+ mount, I'd welcome your feedback if you try it out.
              Idris
              • keyz182undefined
                keyz182 @Moriquendi
                @moriquendi I'll have to wait for the couplings to arrive in the week (just ordered), so will let you know how it goes, thanks!
                • hevilpundefined
                  hevilp
                  How do I mount it? Which X-carriage is neccessary? Can you show a picture?
                  I have a HEVO and there are a lot of hotend carriages...
                  Which is compatible with the chimera orion mount?
                  keyz182undefined 2 Replies Last reply Reply Quote 0
                  • keyz182undefined
                    keyz182 @hevilp
                    @hevilp I couldn't find anything for a Hevo when I looked, so am working on something. Parts are printing currently so I'll let you know when I've had a chance to test.
                      Moriquendi
                      I don't know of any carriage for the HEVO that is directly compatible with the chimera mount. It's not possible for me to develop integrated mounts/carriages for every kind of printer and hotend combination. I try to develop parts that can be easily adapted to specific printers.
                      Idris
                      • keyz182undefined
                        keyz182 @hevilp
                        @hevilp As I said, I'm still printing this, so completely untested - https://www.thingiverse.com/thing:3046312
                        • hevilpundefined
                          hevilp
                          @keyz182 I got the chimera+ , you got the chimera "old" or?
                          And I got the aqua cooled... Will be a lot of work, like it seems
                          • keyz182undefined
                            keyz182 @hevilp
                            @hevilp I have Chimera+. I believe the mounting points are the same in aqua and air, so you may be able to use this.
                            • hevilpundefined
                              hevilp
                              Nice, which x carriage you are using?
                              I bought 2 weeks ago the normal piezo20 v1.1.
                              Can I use it or I realy need the Orion?
                              How Do you mount the coolside on your thing? I do not see any screws from the back of the coolside to the carriage.
                              • keyz182undefined
                                keyz182 @hevilp
                                @hevilp if you don't have an Orion, this works - https://www.thingiverse.com/thing:2801604
                                I'm using the standard X carriage, so the one I designed is designed for that.
                                • hevilpundefined
                                  hevilp
                                  I got this and it works like the last one you posted.
                                  https://www.thingiverse.com/thing:2990895
                                  It does not work for me and I cannot realy find a solution.
                                  I think the problem is, that the pressure is 90 degrees to the nozzle and not direct on it....
                                  Again, How would I mount the aqua coolside to your mount? Where do the screws go?
                                  • keyz182undefined
                                    keyz182 @hevilp
                                    @hevilp do you have 8mm or 10mm X axis rods? I found that there was just enough rotational flex in the Y/Z plane with the two 8mm rods such that if the piezo tension and adjustment pot aren't perfect, it just twists. It does work with a lot of trial and error though. I have a pair of 10mm rods to upgrade to at some point. The above though is why I wanted to change to using the Orion in a vertical orientation - any time I made any adjustments, I had to recalibrate it all. I suspect that 10mm rods will fix that too though.
                                    • hevilpundefined
                                      hevilp
                                      I got 10 mm rods. I think with a normal v6 hotend it will work, but I did a lot of trial and error and it is getting more worse...
                                      I will buy the Orion and use your mount. It should perfect my usercase, as it like yours.
                                      Thanks but can you answer my question with the mount of the coolside
                                      • keyz182undefined
                                        keyz182 @hevilp
                                        @hevilp I only designed the mount today, and have still not tested it. I don't know how the aqua differs from the air, so not sure how or if it will mount. I do remember reading that the mounting holes on the cooling block are in the same place though. I can put up the CAD files up on thingiverse so you can tweak if you need to.
                                        • hevilpundefined
                                          hevilp
                                          But where do the screws go?
                                          I just ordered the Orion kit and hope your mount will work and yes, of course I will tweak if its needed.
                                          • keyz182undefined
                                            keyz182 @hevilp
                                            @hevilp It screws into the part that @Moriquendi linked.
