    New Product Release - Precision Piezo Orion
    Third-party add-ons
    20
    79
    13.9k
    • keyz182undefined
      keyz182 @hevilp
      @hevilp As I said, I'm still printing this, so completely untested - https://www.thingiverse.com/thing:3046312
      • hevilpundefined
        hevilp
        @keyz182 I got the chimera+ , you got the chimera "old" or?
        And I got the aqua cooled... Will be a lot of work, like it seems
        keyz182undefined 1 Reply Last reply Reply Quote 0
        • keyz182undefined
          keyz182 @hevilp
          @hevilp I have Chimera+. I believe the mounting points are the same in aqua and air, so you may be able to use this.
          • hevilpundefined
            hevilp
            Nice, which x carriage you are using?
            I bought 2 weeks ago the normal piezo20 v1.1.
            Can I use it or I realy need the Orion?
            How Do you mount the coolside on your thing? I do not see any screws from the back of the coolside to the carriage.
            • keyz182undefined
              keyz182 @hevilp
              @hevilp if you don't have an Orion, this works - https://www.thingiverse.com/thing:2801604
              I'm using the standard X carriage, so the one I designed is designed for that.
              • hevilpundefined
                hevilp
                I got this and it works like the last one you posted.
                https://www.thingiverse.com/thing:2990895
                It does not work for me and I cannot realy find a solution.
                I think the problem is, that the pressure is 90 degrees to the nozzle and not direct on it....
                Again, How would I mount the aqua coolside to your mount? Where do the screws go?
                • keyz182undefined
                  keyz182 @hevilp
                  @hevilp do you have 8mm or 10mm X axis rods? I found that there was just enough rotational flex in the Y/Z plane with the two 8mm rods such that if the piezo tension and adjustment pot aren't perfect, it just twists. It does work with a lot of trial and error though. I have a pair of 10mm rods to upgrade to at some point. The above though is why I wanted to change to using the Orion in a vertical orientation - any time I made any adjustments, I had to recalibrate it all. I suspect that 10mm rods will fix that too though.
                  • hevilpundefined
                    hevilp
                    I got 10 mm rods. I think with a normal v6 hotend it will work, but I did a lot of trial and error and it is getting more worse...
                    I will buy the Orion and use your mount. It should perfect my usercase, as it like yours.
                    Thanks but can you answer my question with the mount of the coolside
                    • keyz182undefined
                      keyz182 @hevilp
                      @hevilp I only designed the mount today, and have still not tested it. I don't know how the aqua differs from the air, so not sure how or if it will mount. I do remember reading that the mounting holes on the cooling block are in the same place though. I can put up the CAD files up on thingiverse so you can tweak if you need to.
                      • hevilpundefined
                        hevilp
                        But where do the screws go?
                        I just ordered the Orion kit and hope your mount will work and yes, of course I will tweak if its needed.
                        • keyz182undefined
                          keyz182 @hevilp
                          @hevilp It screws into the part that @Moriquendi linked.
                          • hevilpundefined
                            hevilp
                            I think you mean the screws on the top of the heatsink?
                            The aquacoolside got only 4 screws wholes on the back, so I'm need to mount it in anyway in the back. There are no screw wholes on the top.
                            And, I got the water tubes, I think they will not go through the Orion..
                            • keyz182undefined
                              keyz182 @hevilp
                              @hevilp ah, ok. Just looked up the Aqua, didn't realise the pipes came out the top. I don't believe that it can be made to work with the designs here, and I'm not even sure it would work with the Orion at all, as the pipes are right where the piezo would be.
                              • hevilpundefined
                                hevilp
                                But, the Orion needs a piezo disc right? So independent from the way of mount the it is a better Version of the v1.1?
                                • keyz182undefined
                                  keyz182
                                  Orion has a pair of piezos mounted onto the PCB, rather than being on a wire
                                  • hevilpundefined
                                    hevilp
                                    Okay, is possible to create a mount with vertical orientation? Like the one we have not so good experience with?
                                    keyz182undefined Moriquendiundefined 2 Replies Last reply Reply Quote 0
                                    • keyz182undefined
                                      keyz182 @hevilp
                                      @hevilp probably, though I'm not sure if the Orion would be any advantage over the other board there.
                                      • Moriquendiundefined
                                        Moriquendi @hevilp
                                        @hevilp I'm developing a board similar to the Orion that might be more suitable for the kind of vertical orientation you're talking about. It's currently being tested, if you want to cancel your Orion order just contact me through the store.
                                        Idris
                                        • hevilpundefined
                                          hevilp
                                          @Moriquendi , I used the contact Form on your site and wrote my wish to cancel the order, please do not ship it out and refund the money. Thanks
                                          Moriquendiundefined 1 Reply Last reply Reply Quote 0
                                            Moriquendi @hevilp
                                            @hevilp Order cancelled and money refunded.
