    X and Y motors not moving
    motor not running
    2.5k
      Also, are you sure the x and y steps per mm are 80?
      You said when you switched them to be extruders they worked but the extruder steps are 400.
      • samlogan87undefined
        samlogan87
        Sorry I typed M584 and got
        M584
        Driver assignments: X0 Y1 Z2:3:4 U3 V4 E5, 5 axes visible
        I tried changing the steps per mm to 800 and it just sits there and hums
        Custom Core-XY
          If you replace your m584 command in config.g with just M584 X0 Y1 and nothing else do they work then?
            samlogan87
            Tried that and still nothing. Sounds like it wants to move but it doesn't do anything unfortunately
            Custom Core-XY
              Can you send M906 and verify that the motor currents are being accepted?
                samlogan87
                Sure can.
                Here they are
                M906
                Motor current (mA) - X:850, Y:850, Z:1850, U:1850, V:1850, E:800, idle factor 50%
                Custom Core-XY
                  Phaedrux Moderator @samlogan87
                  This is why
                  ; Automatic power saving
                  M911 S10 R11 P"
                  M913 X0 Y0
                  M913 is dropping current to 0%
                    samlogan87
                    You are an absolute genius. It works.
                    Thank you so much. I really love this forum
                    Custom Core-XY
                      Aww shucks.
                      Now maybe I can sleep because that was bugging me.
                      • whosrdaddyundefined
                        whosrdaddy
                        Nice catch!
                        This one was bugging me too 🙂
                          samlogan87
                          Yeah I have no idea why that line was in there. I copied the restart on power fail from somewhere and it must have been in there. Oh well I am really happy you guys have sorted it for me. I was starting to get a bit deflated.
                          Custom Core-XY
                            @samlogan87 said in X and Y motors not moving:
                            The M913 X0 Y0 command should have been within the quoted string on the previous line.
