New beta firmware 2.02beta1
I should add that the wall (not shown in image above) that precedes the corner at the top of the image is approx 50mm long so there's plenty of time for the nozzle to reach the commanded velocity (in the direction normal to the surface we are looking at). By contrast the holes are only about 4mm deep so I would expect the velocity to be quite low still by the time it reaches the edge.
At 40mm/sec and trying to cancel 40Hz ringing, the optimum acceleration at the corners should be 1600mm/sec^2 or less, depending on how much jerk you have configured. So if there is definitely no M104 command either in config.g or in the code generated by the slicer, that doesn't explain it. You can run M104 without parameters to check.
The interior perimeters of the holes may be being printed at a lower top speed if the holes do not go right through the cube, in which case the optimum acceleration when printing them will be lower.
M204 query gives:
Maximum printing acceleration 10000.0, maximum travel acceleration 10000.0
@dc42 a question from a github conversation "Do you also adjust the laser pwm depending on x/y acceleration and deceleretion (like Grbl in M4 mode)?"
https://github.com/LaserWeb/LaserWeb4/issues/500#issuecomment-412592499
@t3p3tony said in New beta firmware 2.02beta1:
Not yet, but I plan to do so before the 2.02 release. It does adjust the laser power if for any reason the actual top speed of the move is slower than the requested speed.
Tried a few prints on the beta and was working well, but I just had a print stop half way through but claim to be compelted. The web interface makes it look like it was completed, but there is about 1/2 a file of gcode left. Only message in the console was:
"Finished printing file 0:/gcodes/corners.gcode, print time was 2h 48m"
I downloaded the gcode file from the web interface to check and it seems okay and a simulator has the full print.
Here is the gcode downloaded from the web interface: https://drive.google.com/open?id=1_dRimJ3CkYL3QDAyAvLwodNUpNk8j5s7
Anything else I should look at?
M122 right after it happened is:
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02beta1(RTOS) running on Duet WiFi 1.02 or later + DueX2
Board ID: 08DGM-9568A-F23SD-6J9DL-3SJ6R-K9RRH
Used output buffers: 3 of 20 (14 max)
Static ram: 28476
Dynamic ram: 98404 of which 12 recycled
Exception stack ram used: 532
Never used ram: 3648
Tasks: NETWORK(ready,328) HEAT(blocked,1192) MAIN(running,1660)
Owned mutexes:
Last reset 07:21:25 ago, cause: software
Last software reset at 2018-08-11 18:28, reason: User, spinning module GCodes, available RAM 5740 bytes (slot 2)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
Error status: 0
Free file entries: 10
SD card longest block write time: 94.0ms, max retries 0
MCU temperature: min 43.0, current 43.2, max 56.1
Supply voltage: min 23.8, current 24.0, max 24.3, under voltage events: 0, over voltage events: 0
Driver 0: standstill, SG min/max 0/236
Driver 1: standstill, SG min/max 0/257
Driver 2: standstill, SG min/max 0/1023
Driver 3: standstill, SG min/max 0/255
Driver 4: standstill, SG min/max 0/271
Driver 5: standstill, SG min/max 0/1023
Driver 6: standstill, SG min/max 0/1023
Expansion motor(s) stall indication: yes
Date/time: 2018-08-13 17:02:34
Slowest loop: 132.81ms; fastest: 0.07ms
Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 145, MaxWait: 2403580ms, Underruns: 0, 0
Bed compensation in use: mesh
Bed probe heights: -0.003 -0.003 -0.006 0.003 0.000
Heater 0 is on, I-accum = 0.3
Heater 1 is on, I-accum = 0.2
Segments left: 0
Stack records: 4 allocated, 0 in use
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 125.06ms; fastest: 0.01ms
HTTP sessions: 1 of 8- WiFi -
Network state is running
WiFi firmware version 1.21
WiFi MAC address 2c:3a:e8:0b:17:81
WiFi Vcc 3.45, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 16600
WiFi IP address 192.168.86.38
WiFi signal strength -45dBm, reconnections 0, sleep mode modem
=== Expansion ===
DueX I2C errors 0
- WiFi -
Your M122 report is clean and I didn't spot anything wrong with the GCode file.
@dc42 said in New beta firmware 2.02beta1:
Dynamic Acceleration Adjustment (DAA). This is an experimental feature that adjusts the acceleration and deceleration of moves independently, to minimise excitation of mechanical resonance at a specified frequency, thereby reducing ringing. By default this feature is disabled. Use the M593 command to enable and configure it.
That is just wonderful....
Please, does anyone have a good methodology to tune base jerk and acceleration settings?
This post is deleted! -
@brunofporto said in New beta firmware 2.02beta1:
For jerk you can kind of tune by ear. I try and keep it low enough so that motion is still smooth but quick. Ie no noticeable pauses at direction changes and it doesn't sound like it's shaking the machine apart. X600 Y600 is a good starting point. A delta can probably get away with more than a cartesian. CoreXY in the middle.
For acceleration you can do a test print and start with a low value and increase it every 20 layers or so. a 100mm cube is a pretty decent model to test with. You can use the formula from the Periodicity of Ringing thread to try and measure your results and find a more suitable acceleration value.
@phaedrux said in New beta firmware 2.02beta1:
I was always wondering what is the upper limit I am looking for with accel? Or put another way: how do I recognize the upper limit of what is possible with my machine? I still have the values set that I took from Marlin config and never really touched this topic yet.
Dynamic Acceleration Adjustment does that for you. So all you need to do is find out how high you can set the acceleration without any risk of missing steps.
That is what I loved about this update
I'll test it ASAP.
@dc42 Is it possible to use stall detection and some macro sequence to "auto-tune" max acceleration and/or jerk? Not now, but as a future improvement
For now, I'll use @Phaedrux tuning macro collection to tune them. But would be nice if the firmware was able to automatically tune those settings like we already do with PIDs from heaters.
The problem is that so-called "stall detection" doesn't actually detect motors stalls, what it detects is abnormally high loads that may indicate an approaching stall.
Just like to say thanks to dc42 (I think Dave) and the other firmware developers for all they're hard work.
I've recently managed to get my Anycubic Kossel Delta to work with the new duet board. It took a little while to figure out but I've got a lot more confidence in the bed leveling now than the original Marlin board.
I plan on writing up some docs on my blog at some point with a more step by step guides to try and simplify the setup process, and list some of the things / quirks I've noticed.
What does the new
M703
command do?
Wiki is not completely understandable to me! -
@zerspaner_gerd The filaments have a new entry in the context menu. Besides load and unload macros you can now also define a filament specific config.
M703
will check if such a config had been setup by the user for the currently loaded filament and execute it. It will do nothing (especially no error) of no config exists.EDIT: Use-case: If you have e.g. different retraction settings for your different filaments (and use firmware retract) you could add these settings in the config and load it as part of your start GCODE via
M703
. (That's how I actually use it) -
Ok,
I tested the DAA function... First time I thought I had great results, until turn it off and print the same gcode and had the same result....
Then I tested my maximum acceleration until I had to miss steps (2500mm/s²) to be sure and printed some single perimeter hollow cubes at three different speeds with the DAA turned off to check if my frequencies where close to the DAA setting.
Well... They are always around 40Hz and the DAA was set to this frequency.
I could see no improvement (the ripples are already very subtle before it anyway)
Am I doing something wrong or the test subjects had features that does not benefit from the algorithm? Is there a test model to use as a common reference?
I used a 20mm simple cube and this (printed hollow, single perimeter, etc) : https://www.thingiverse.com/thing:277394
Thanks!
@brunofporto can you post a photo of the ringing? Perhaps it's not actually ringing at all.
Some more F593 testing...
I printed https://www.thingiverse.com/thing:277394 without (left) and with M593 F40 (right) on my Kossel XL with flex3drive extruder.
On this example, the ringing is maybe a little reduced but not everywhere and also the piece on the right has some noticeable roughness which can be seen as a shiny area downstream of sharp corners.
So M593 actually makes this print worse for me.
