    New beta firmware 2.02beta1
    Firmware installation
    16
    75
    10.6k
    • mdfveronaundefined
      mdfverona
      Tried a few prints on the beta and was working well, but I just had a print stop half way through but claim to be compelted. The web interface makes it look like it was completed, but there is about 1/2 a file of gcode left. Only message in the console was:
      "Finished printing file 0:/gcodes/corners.gcode, print time was 2h 48m"
      I downloaded the gcode file from the web interface to check and it seems okay and a simulator has the full print.
      Here is the gcode downloaded from the web interface: https://drive.google.com/open?id=1_dRimJ3CkYL3QDAyAvLwodNUpNk8j5s7
      Anything else I should look at?
      M122 right after it happened is:
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02beta1(RTOS) running on Duet WiFi 1.02 or later + DueX2
      Board ID: 08DGM-9568A-F23SD-6J9DL-3SJ6R-K9RRH
      Used output buffers: 3 of 20 (14 max)
      Static ram: 28476
      Dynamic ram: 98404 of which 12 recycled
      Exception stack ram used: 532
      Never used ram: 3648
      Tasks: NETWORK(ready,328) HEAT(blocked,1192) MAIN(running,1660)
      Owned mutexes:
      Last reset 07:21:25 ago, cause: software
      Last software reset at 2018-08-11 18:28, reason: User, spinning module GCodes, available RAM 5740 bytes (slot 2)
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
      Error status: 0
      Free file entries: 10
      SD card longest block write time: 94.0ms, max retries 0
      MCU temperature: min 43.0, current 43.2, max 56.1
      Supply voltage: min 23.8, current 24.0, max 24.3, under voltage events: 0, over voltage events: 0
      Driver 0: standstill, SG min/max 0/236
      Driver 1: standstill, SG min/max 0/257
      Driver 2: standstill, SG min/max 0/1023
      Driver 3: standstill, SG min/max 0/255
      Driver 4: standstill, SG min/max 0/271
      Driver 5: standstill, SG min/max 0/1023
      Driver 6: standstill, SG min/max 0/1023
      Expansion motor(s) stall indication: yes
      Date/time: 2018-08-13 17:02:34
      Slowest loop: 132.81ms; fastest: 0.07ms
      Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 145, MaxWait: 2403580ms, Underruns: 0, 0
      Bed compensation in use: mesh
      Bed probe heights: -0.003 -0.003 -0.006 0.003 0.000
      Heater 0 is on, I-accum = 0.3
      Heater 1 is on, I-accum = 0.2
      Segments left: 0
      Stack records: 4 allocated, 0 in use
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 125.06ms; fastest: 0.01ms
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is running
        WiFi firmware version 1.21
        WiFi MAC address 2c:3a:e8:0b:17:81
        WiFi Vcc 3.45, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 16600
        WiFi IP address 192.168.86.38
        WiFi signal strength -45dBm, reconnections 0, sleep mode modem
        === Expansion ===
        DueX I2C errors 0
        Your M122 report is clean and I didn't spot anything wrong with the GCode file.
        • brunofportoundefined
          brunofporto @dc42
          @dc42 said in New beta firmware 2.02beta1:
          Dynamic Acceleration Adjustment (DAA). This is an experimental feature that adjusts the acceleration and deceleration of moves independently, to minimise excitation of mechanical resonance at a specified frequency, thereby reducing ringing. By default this feature is disabled. Use the M593 command to enable and configure it.
          That is just wonderful....
          Please, does anyone have a good methodology to tune base jerk and acceleration settings?
            This post is deleted!
              Phaedrux Moderator @brunofporto
              @brunofporto said in New beta firmware 2.02beta1:
              For jerk you can kind of tune by ear. I try and keep it low enough so that motion is still smooth but quick. Ie no noticeable pauses at direction changes and it doesn't sound like it's shaking the machine apart. X600 Y600 is a good starting point. A delta can probably get away with more than a cartesian. CoreXY in the middle.
              For acceleration you can do a test print and start with a low value and increase it every 20 layers or so. a 100mm cube is a pretty decent model to test with. You can use the formula from the Periodicity of Ringing thread to try and measure your results and find a more suitable acceleration value.
              https://forum.duet3d.com/topic/5951/periodicity-of-ringing
              wilrikerundefined dc42undefined 2 Replies Last reply Reply Quote 1
              • wilrikerundefined
                wilriker @Phaedrux
                @phaedrux said in New beta firmware 2.02beta1:
                I was always wondering what is the upper limit I am looking for with accel? Or put another way: how do I recognize the upper limit of what is possible with my machine? I still have the values set that I took from Marlin config and never really touched this topic yet.
                Manuel
                My Tool Collection
                  dc42 administrators @Phaedrux
                  Dynamic Acceleration Adjustment does that for you. So all you need to do is find out how high you can set the acceleration without any risk of missing steps.
                  brunofportoundefined 1 Reply Last reply Reply Quote 1
                    brunofporto @dc42
                    That is what I loved about this update šŸ˜„ I'll test it ASAP.
                    @dc42 Is it possible to use stall detection and some macro sequence to "auto-tune" max acceleration and/or jerk? Not now, but as a future improvement šŸ˜„
                    For now, I'll use @Phaedrux tuning macro collection to tune them. But would be nice if the firmware was able to automatically tune those settings like we already do with PIDs from heaters.
                      dc42 administrators @brunofporto
                      The problem is that so-called "stall detection" doesn't actually detect motors stalls, what it detects is abnormally high loads that may indicate an approaching stall.
                      • garlicbreadundefined
                        garlicbread
                        Just like to say thanks to dc42 (I think Dave) and the other firmware developers for all they're hard work.
                        I've recently managed to get my Anycubic Kossel Delta to work with the new duet board. It took a little while to figure out but I've got a lot more confidence in the bed leveling now than the original Marlin board.
                        I plan on writing up some docs on my blog at some point with a more step by step guides to try and simplify the setup process, and list some of the things / quirks I've noticed.
                        • zerspaner_gerdundefined
                          zerspaner_gerd
                          What does the new M703 command do?
                          Wiki is not completely understandable to me!
                          Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
                          • wilrikerundefined
                            wilriker @zerspaner_gerd
                            @zerspaner_gerd The filaments have a new entry in the context menu. Besides load and unload macros you can now also define a filament specific config. M703 will check if such a config had been setup by the user for the currently loaded filament and execute it. It will do nothing (especially no error) of no config exists.
                            EDIT: Use-case: If you have e.g. different retraction settings for your different filaments (and use firmware retract) you could add these settings in the config and load it as part of your start GCODE via M703. (That's how I actually use it)
                            Manuel
                            My Tool Collection
                            zerspaner_gerdundefined 1 Reply Last reply Reply Quote 1
                              brunofporto
                              Ok,
                              I tested the DAA function... First time I thought I had great results, until turn it off and print the same gcode and had the same result....
                              Then I tested my maximum acceleration until I had to miss steps (2500mm/s²) to be sure and printed some single perimeter hollow cubes at three different speeds with the DAA turned off to check if my frequencies where close to the DAA setting.
                              Well... They are always around 40Hz and the DAA was set to this frequency.
                              I could see no improvement (the ripples are already very subtle before it anyway)
                              Am I doing something wrong or the test subjects had features that does not benefit from the algorithm? Is there a test model to use as a common reference?
                              I used a 20mm simple cube and this (printed hollow, single perimeter, etc) : https://www.thingiverse.com/thing:277394
                              Thanks!
                                @brunofporto can you post a photo of the ringing? Perhaps it's not actually ringing at all.
                                brunofportoundefined 1 Reply Last reply Reply Quote 0
                                • burtoogleundefined
                                  burtoogle
                                  Some more F593 testing...
                                  I printed https://www.thingiverse.com/thing:277394 without (left) and with M593 F40 (right) on my Kossel XL with flex3drive extruder.
                                  On this example, the ringing is maybe a little reduced but not everywhere and also the piece on the right has some noticeable roughness which can be seen as a shiny area downstream of sharp corners.
                                  So M593 actually makes this print worse for me.
                                    zerspaner_gerd @wilriker
                                    @wilriker Nice, I did not see that. I can do something with that. Thank you
                                      dc42 administrators @burtoogle
                                      @burtoogle said in New beta firmware 2.02beta1:
                                      ...On this example, the ringing is maybe a little reduced but not everywhere and also the piece on the right has some noticeable roughness which can be seen as a shiny area downstream of sharp corners.
                                      Reduced acceleration will cause the head to spend more time near corners. On a Bowden extruder, that will make it more important to use the correct pressure advance setting.
                                        burtoogle
                                        It's not a Bowden extruder, it's a flex3drive.
                                          A Flex3drive might require pressure advance to compensate for the torsional elasticity of the Bowden cable. I've never used one, so I don't know whether this is the case or not.
                                          • gtj0undefined
                                            gtj0 @dc42
                                            I don't use pressure advance on my flex3drive and the corners are way sharper than any bowden I've used. I think the high gear ratio takes care of that.
                                            burtoogleundefined 1 Reply Last reply Reply Quote 0
