New beta firmware 2.02beta1
@dc42 said in New beta firmware 2.02beta1:
@phaedrux said in New beta firmware 2.02beta1:
You can use the formula from the Periodicity of Ringing thread to try and measure your results and find a more suitable acceleration value.
Dynamic Acceleration Adjustment does that for you. So all you need to do is find out how high you can set the acceleration without any risk of missing steps.
That is what I loved about this update
I'll test it ASAP.
@dc42 Is it possible to use stall detection and some macro sequence to "auto-tune" max acceleration and/or jerk? Not now, but as a future improvement
For now, I'll use @Phaedrux tuning macro collection to tune them. But would be nice if the firmware was able to automatically tune those settings like we already do with PIDs from heaters.
@brunofporto said in New beta firmware 2.02beta1:
The problem is that so-called "stall detection" doesn't actually detect motors stalls, what it detects is abnormally high loads that may indicate an approaching stall.
Just like to say thanks to dc42 (I think Dave) and the other firmware developers for all they're hard work.
I've recently managed to get my Anycubic Kossel Delta to work with the new duet board. It took a little while to figure out but I've got a lot more confidence in the bed leveling now than the original Marlin board.
I plan on writing up some docs on my blog at some point with a more step by step guides to try and simplify the setup process, and list some of the things / quirks I've noticed.
What does the new
M703
command do?
Wiki is not completely understandable to me! -
@zerspaner_gerd The filaments have a new entry in the context menu. Besides load and unload macros you can now also define a filament specific config.
M703
will check if such a config had been setup by the user for the currently loaded filament and execute it. It will do nothing (especially no error) of no config exists.EDIT: Use-case: If you have e.g. different retraction settings for your different filaments (and use firmware retract) you could add these settings in the config and load it as part of your start GCODE via
M703
. (That's how I actually use it) -
Ok,
I tested the DAA function... First time I thought I had great results, until turn it off and print the same gcode and had the same result....
Then I tested my maximum acceleration until I had to miss steps (2500mm/s²) to be sure and printed some single perimeter hollow cubes at three different speeds with the DAA turned off to check if my frequencies where close to the DAA setting.
Well... They are always around 40Hz and the DAA was set to this frequency.
I could see no improvement (the ripples are already very subtle before it anyway)
Am I doing something wrong or the test subjects had features that does not benefit from the algorithm? Is there a test model to use as a common reference?
I used a 20mm simple cube and this (printed hollow, single perimeter, etc) : https://www.thingiverse.com/thing:277394
Thanks!
@brunofporto can you post a photo of the ringing? Perhaps it's not actually ringing at all.
Some more F593 testing...
I printed https://www.thingiverse.com/thing:277394 without (left) and with M593 F40 (right) on my Kossel XL with flex3drive extruder.
On this example, the ringing is maybe a little reduced but not everywhere and also the piece on the right has some noticeable roughness which can be seen as a shiny area downstream of sharp corners.
So M593 actually makes this print worse for me.
@wilriker Nice, I did not see that. I can do something with that. Thank you
@burtoogle said in New beta firmware 2.02beta1:
...On this example, the ringing is maybe a little reduced but not everywhere and also the piece on the right has some noticeable roughness which can be seen as a shiny area downstream of sharp corners.
Reduced acceleration will cause the head to spend more time near corners. On a Bowden extruder, that will make it more important to use the correct pressure advance setting.
It's not a Bowden extruder, it's a flex3drive.
A Flex3drive might require pressure advance to compensate for the torsional elasticity of the Bowden cable. I've never used one, so I don't know whether this is the case or not.
I don't use pressure advance on my flex3drive and the corners are way sharper than any bowden I've used. I think the high gear ratio takes care of that.
@phaedrux Here!
Left DAA (40Hz) Right No DAA -
@gtj0 said in New beta firmware 2.02beta1:
Apologies for the off-topic question but what speed, accel, jerk are you using with the flex3drive? I am using 25, 400 and 10 with no pressure advance and normally get good results.
Too bad that
M703
does not already work with filament loading.Thus, no change to the filament load macro would be necessary!
@zerspaner_gerd said in New beta firmware 2.02beta1:
Too bad that M703 does not already work with filament loading.
Doesn't it, in firmware 2.02beta1?
When filament loading it does not work (no temperature is set, no error messages)
My guess is that the filament name is updated only after the load, so M703 has no macro name.When unloading it works!
Have you read https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M703_Configure_filament to see how M703 is intended to be used?
XY Speed: 80 mm/s
XY Accel: 1000 mm/s^2
XY Jerk: 800 mm/minE Accel: 125 mm/^s
E Jerk: 120 mm/minNo pressure advance
I haven't even attempted to do any advanced tuning let alone tried to tune out the ringing yet but the corners are pretty sharp.
