    effector tilting into bed on print
    22.1k
    • TimVukmanundefined
      TimVukman
      @Doug1957
      Thankyou. I did not spot that.
      I have set the radius to 95, and rerun the G29 command.
      That would explain what the hot end was doing when I printed the configuration cube. It was rounding off the back corner based on my radius of 80.
        TimVukman
        When I try printing an object, the nozzle is digging into the masking tape that I have on the bed.
        In simplify3d, I am telling the printer to print at 0.20mm
        I have first layer height at 90%
        First layer width at 100%
        I have new rods coming that are shorter than my current rods and metal carriages to replace the plastic ones that are running up and down the vertical pillars.
        How critical is belt tension? My belts are not as tight as I would like, but they are not skipping. I can pinch them anywhere along the travel length and the backs of the belts will touch with no real pressure needed. There is certainly no spring pushing back against my fingers.
        • adavidmundefined
          adavidm
          @timvukman said in effector tilting into bed on print:
          G31 P100 X0 Y0 Z-0.239 ; Set Z probe trigger value, offset and trigger height
          This line is saying that the probe is 0.239mm below the bed when triggered. This seems fairly high for the smart effector and could be causing the digging.
          Z-0.1 is the recommended value and works well for me.
          It sounds like you are getting there, keep going!
          adavidm
            TimVukman
            @adavidm
            0.1 is the new number
            Another issue has surfaced. I think my cube model is bad. It really doesn't try to put down a cube. More of a straight line, and then a big move left and another straight light over then, and then a heater fault on the nozzle heater which I have never seen before.
            • adavidmundefined
              adavidm
              It's unlikely the model is at fault. Upload the gcode somewhere for someone to check if you like but I do not think that is the source of your problems.
              Have you run PID tuning on the hotend and bed heaters? If not then you should do that now. There are several kinds of heater faults but running PID tuning should be your next step. There are instructions in the documentation.
              Once you've got that to work successfully, we can see if the problem persists.
                TimVukman
                I have run the heater PID, but maybe only for the bed. I will run it now.
                I have pulled up the gcode for the model I was printing, and there are no obvious faults in the file structure, etc. Everything looks like it is broken into nice clean block for each layer. I ran a file check on it anyway and it was clean.
                  TimVukman
                  I ran the PID tuning on both heaters
                  No Faults came up.
                  As A general question, what do I have to check to make sure that my Simplify3d software is correctly configured for my delta printer.
                  I have seen situations where the model does not print at or about the center of the bed. I am assuming that it should. The favourite starting position seems to be a little on the high side of what would be X on a cartesian and a little back from center in the Y axis.
                  I am assuming that the hot end will step upward on each layer by the 80mm/step. What should my layer height be in Simplify3d, or will that be automatic based on the printer hardwawre?
                  6:51:41 PMM500
                  6:51:14 PMWarning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 515C.
                  Auto tune heater 1 completed in 220 sec
                  Use M307 H1 to see the result, or M500 to save the result in config-override.g
                  6:48:59 PMAuto tune phase 3, peak temperature was 209.6
                  6:48:50 PMAuto tune phase 2, heater off
                  6:47:40 PMAuto tune phase 1, heater on
                  6:47:34 PMM303 H1
                  Auto tuning heater 1 using target temperature 200.0°C and PWM 1.00 - do not leave printer unattended
                  6:46:18 PMAuto tune heater 0 completed in 460 sec
                  Use M307 H0 to see the result, or M500 to save the result in config-override.g
                  6:41:29 PMM303 H1
                  6:41:10 PMAuto tune phase 3, peak temperature was 75.3
                  6:41:03 PMAuto tune phase 2, heater off
                  6:38:43 PMAuto tune phase 1, heater on
                  6:38:38 PMM303 H0
                  Auto tuning heater 0 using target temperature 75.0°C and PWM 1.00 - do not leave printer unattended
                  adavidmundefined 1 Reply Last reply Reply Quote 0
                  • adavidmundefined
                    adavidm @TimVukman
                    No Faults came up.
                    OK, so have you saved that result into the config-override.g by running M500? Alternatively, you can (and probably should) put the results into the M307 in config.g, the tuning is unlikely to change unless you make hardware changes.
                    Can you post a screenshot of the "Machine" tab from the "Tools->Options" menu? Assuming you've set the machine up as a delta in there it should be set forever. If you have the Simplify3D configuration correct then the object will print on the bed in the same location and orientation as the model on screen.
                    Having said that, your endstop offsets are:
                    M666 X0.425 Y3.690 Z-4.114 A0.00 B0.00
                    If I were you I'd try and reduce that difference. Someone else can chime in here if I'm wrong but I think the effect of those large compensations will be to move the centre of the coordinate system away from the centre of the bed. Auto calibration can be a good thing, especially on deltas, but you should make every effort to get the system mechanically correct first. In this case, when the carriages trigger the endstops, they should be at the same height above the bed from each other. Depending on the kind of endstop and/or carriage you have fitted, the method of adjustment will be different. Post a photo if you are not sure. You should be able to get to better than 1mm deviation between endstops without too much effort.
                    The layer height you choose varies based on lots of parameters but it's basically a tradeoff between speed and z-resolution. For now, and assuming you are using a 0.5 or 0.6mm nozzle, I'd use something like 0.2 or 0.3mm layer height.
                      TimVukman
                      This is the result from the PID tuning of the heaters
                      ; Heater model parameters
                      M307 H0 A129.5 C334.4 D0.5 S1.00 V12.1 B0
                      M307 H1 A490.4 C147.5 D5.4 S1.00 V12.3 B0
                      The heater section from my config.g file is
                      M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
                      M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
                      M305 P1 T100000 B4388 C0 R4700 ; Set thermistor + ADC parameters for heater 1
                      Thanks for pointing out the M666 variances. I did not recheck the switches after I replaced the upper and lower frames. To that end, there was interference on the Z switch from the belt. I will shorten up the overhang.
                        TimVukman
                        New heater section
                        M307 H0 A129.5 C334.4 D0.5 B0 S1.00 V12.1 ; Disable bang-bang mode for the bed heater and set PWM limit
                        M307 H1 A490.4 C147.5 D5.4 B0 S1.0 V12.3
                        I tightened up the belts because the looseness was bothering me.
                        I have rerun the Auto Configuration and it looks good to me
                        10:25:22 AMG32
                        Calibrated 6 factors using 10 points, deviation before 0.089 after 0.084
                        10:24:08 AMG32
                        Calibrated 6 factors using 10 points, deviation before 0.083 after 0.080
                        I did not get the corrections I was looking for with regard to the M666,
                        but I did fix the settings in Simplify3d.
                        • adavidmundefined
                          adavidm @TimVukman
                          Can you take three photos, one for each axis, that clearly shows the top of the frame and the endstop please? Ideally just after homing so we can see the carriage in relation. There must be something in the physical configuration that's giving you that large deviation. It really is worth getting that sorted.
                          The auto calibration looks ok - and you should be able to print - but if I were you I'd want to understand why that correction is needed.
                          Have you tried another cube yet?
                          • Dougal1957undefined
                            Dougal1957
                            What do you mean by I fixed the settings in S3D in relation to the M666?
                              TimVukman
                              Simplify3d came up defaulted to a cartesian configuration. I loaded my delta configuration and went from there
                              This photo is the Z pillar after homing.
                              This is from pillar X
                              This is from pillar Y
                              This is the most recent print of the configuration cube
                              Location of Effector before print
                              When I printed, the nozzle caught the edge of the masking tape, so it didn't actually dig into the bed.
                              You can see the rim and the start of the cube in DSC816. In the back of the cube, you can see where it tried to lay down filament on the bare bed, and you can see how the nozzle tracks in an arc across the back corner. The rim obviously did not fit within the print area.
                              Edited for putting the wrong photo in for Y
                                1. When you run auto calibration, does the nozzle sometimes touch bare parts of the bed and sometimes parts with masking tape on them? If so, that might explain why your calibration deviation is worse than we expect when using the Smart Effector.
                                2. I'm not sure if you have already done this (because this thread is so long); but can you run G29 and post the resulting height map here? That might give a clue about what is going on.
                                3. Have you fitted the spirit level to the Smart Effector; and if so, does it show that the effector is level at all XY positions?
                                • adavidmundefined
                                  adavidm @TimVukman
                                  @timvukman
                                  Measure the distance between the top of the red block ( that one of your endstops is mounted to) and the frame of the printer. Now measure the other two ends tops in precisely the same way. They should be identical. If not you need to fix it.
                                  It's actually easiest to do this with a 'truth stick' approach. You place an object to act as a temporary spacer between the endstop and the top frame, roughly equal to the spacing you have now. One at a time, slacken the endstop mounts and push them against the spacer, and re tighten the mount. It should only take a couple of minutes to complete and will get you to within 0.5mm without difficulty.
                                  If your endstops are already a very close match then we need to know, as something else must be amiss which could be confusing the situation.
                                  TimVukmanundefined 1 Reply Last reply Reply Quote 0
                                  • adavidmundefined
                                    adavidm
                                    Also, for a first print, try a 20mm calibration cube. There are loads on the Web. They print quickly, come nowhere near your axis limits and are not difficult to slice.
                                    Place it on the centre of the bed in simplify 3d.
                                      TimVukman
                                      The answer is yes. I did add another piece of tape to the large blank spot at the front,
                                      I will run the autoconfig again after I finish this note
                                      I will do that.
                                      Have you fitted the spirit level to the Smart effector; and if so, does it show that the effector is level at all XY positions?
                                      With the spirit level in place, the bubble is at the back edge of the black circle, pointed directly at the Z pillar. When I place it on the table that the printer is on, it's almost perfect.
                                      If I move the effector around, the little air bubble stays pretty much in the same place where the edge of the bubble lines up with the edge of the black circle at the rear of the machine
                                        TimVukman
                                        4:15:50 PMG32
                                        Calibrated 6 factors using 10 points, deviation before 0.131 after 0.126
                                        4:15:18 PMG32
                                        Calibrated 6 factors using 10 points, deviation before 0.142 after 0.139
                                        G29
                                        4:18:10 PMG29
                                        45 points probed, mean error -0.033, deviation 0.134
                                        Height map saved to file heightmap.csv
                                          TimVukman @adavidm
                                          @adavidm
                                          I have measured the distance on all three pillars and made sure that they are even
                                            TimVukman @adavidm
                                            @adavidm
                                            That cube is what I was trying to print. That's what was in the photos
