    Laser Filament Monitor - test results
    Filament Monitor
    16
    139
    21.5k
    • wilrikerundefined
      wilriker @T3P3Tony
      @t3p3tony said in Laser Filament Monitor - test results:
      @wilriker Thanks updated
      Do updates in dozuki pages take a while? I cannot see any difference. ๐Ÿ˜•
      Manuel
      My Tool Collection
      • wilrikerundefined
        wilriker @T3P3Tony
        @dc42 The housing design I shared has a divergent light path where the amount it diverges can be edited. Its has a square rather than round profile though.
        @dc42 Also in what direction is that cone/divergence supposed to be according to your suggestion (that I apparently missed and cannot find either)? Tip towards the sensor or away from the sensor?
        EDIT: Of course if it is tip towards the sensor it would not make sense to have full cone since it would block the sensor. In that case I would assume a cone with the top chopped off.
        Manuel
        My Tool Collection
          T3P3Tony administrators @wilriker
          @wilriker have a look at this:
          Having a divergent light path to reduce stray reflections back to the sensor might help, See the "divergeAmount" variable in the OpenSCAD design on youmagine.
          From the documentation
          • wilrikerundefined
            wilriker @T3P3Tony
            @t3p3tony Now I am confused ๐Ÿ˜•
            I thought your "Thanks updated" was related to me reporting that I found the screw lengths given in the documentation to be too short.
            Re: housing: I already have your scad file on my hard drive and looked into it. My question on the direction of the cone that @dc42 suggested was that it could be he meant to have the base of the cone starting at the sensor going into its tip in direction of the top housing part so that in the end it looks like the top housing has some kind of spike. I would assume that this is to keep the light deflecting internally in various directions until it is too faint to detected by the sensor anymore. But that is just an assumption.
            Manuel
            My Tool Collection
              dc42 administrators @wilriker
              @wilriker said in Laser Filament Monitor - test results:
              Yes, that is what I intended.
              • wilrikerundefined
                wilriker @dc42
                @dc42 said in Laser Filament Monitor - test results:
                So I came up with
                Top View:
                top view
                Bottom View:
                bottom view
                Sorry for those screen-caps, my OpenSCAD only produces fully-black PNG files when trying to export the design as an image.
                Manuel
                My Tool Collection
                  deckingman @wilriker
                  I think the png background colour gets inherited from the preferences you set for 3d view. So "Edit - Preferences - 3D view" then select a different colour scheme. I'm pretty sure that you can also create custom colour schemes but it means digging into code - not my field of expertise but I'm sure you could make the changes. As ever, Google is your friend.
                  • wilrikerundefined
                    wilriker @deckingman
                    @deckingman OK, I can see that the background color gets inherited from the theme. But why is then everything black on export? Even the blue-ish rendered parts?
                    Anyway, changing the theme helps. I found though that the export does not do anything really different from a screen capture. ๐Ÿ˜‚ So no use in doing it that way.
                    Manuel
                    My Tool Collection
                      Don't ask me - I'm just an old guy who cuts a screws bits of wood together โ˜บ .
                      wilrikerundefined 1 Reply Last reply Reply Quote 1
                      • wilrikerundefined
                        @deckingman said in Laser Filament Monitor - test results:
                        Don't forget the guy that gives great advise on how to also screw aluminum extrusions together. ๐Ÿ˜‰
                        Manuel
                        My Tool Collection
                        • wilrikerundefined
                          wilriker
                          So, I added some more results to my Spreadsheet and they line up with the previous results pretty good which means that for the same conditions, e.g. filament, housing and settings the sensor will perform quite stable.
                          Probably tonight or maybe tomorrow night I can switch the housing to one having a cone-shaped interior as @dc42 suggested - took me some tries to design it in a way to be actually printable. I will then do some more prints with the current filament to see if the redesigned housing performs better or worse before switching filament.
                          Manuel
                          My Tool Collection
                            @wilriker thanks for the update. So from those results you could probably be comfortable having the filament sensor error outside 40%-120% which over 3mm mean it would under read by 1.8mm before having an error - that is short enough to save some prints, but not all, depending on how big the object is, layer height etc.
                            • fmaundefined
                              fma
                              Did someone try to reduce/increase the check length (default to 3mm)? Could it improve things?
                              Frรฉdรฉric
                                T3P3Tony administrators @fma
                                @fma I did a lot of testing with 1mm earlier on, this increased the % range of min and max, which is to be expected as there is less difference to average over and some time maybe that 1mm is all during a fast retract or something. On the other hand if you have 20%-140% of 1mm then the maximum underextrusion before an alarm is only 0.8mm so worth testing and tuning for specific filaments, retract lengths etc.
                                • fmaundefined
                                  fma
                                  Ok, I see. Thanks.
                                  Frรฉdรฉric
                                  • wilrikerundefined
                                    wilriker @T3P3Tony
                                    @t3p3tony Based on my current results and as stable as they are I would even be comfortable to set the limits to a narrower range of 65-105%. ๐Ÿ™‚ I will add this to my filament's config.g but still with S0 as long as I continue testing.
                                    EDIT: Regarding check length: would it make sense to synchronize this somehow with retraction distance? On my MK8 direct extruder I use a rather unusual 3.5mm retraction length which is quite close to 3mm check length.
                                    Manuel
                                    My Tool Collection
                                    • wilrikerundefined
                                      wilriker
                                      I switched now to a cone shaped interior. First print with it might be tomorrow or the day after.
                                      But when I removed the PCB from the housing I took a look at the sensor itself and it seems to have some kind of dirt on the shiny part. It is hart to spot or to explain. What would be the best way to clean it? My intuitive approach would be to deal with it like with my camera lenses that have sensitive coatings on it and therefore need careful cleaning with just cigarette paper (the softest paper available) and Isopropyl alcohol. But I am open to suggestions.
                                      Mounted in its new housing it just happily blinks now... green - red - green - red - green - red... ๐Ÿ˜
                                      EDIT: And yes I read and adhered to
                                      Take great care not to damage [the sensor] or to touch it. Do not put the filament monitor PCB component-side down on any surface.
                                      Manuel
                                      My Tool Collection
                                        I used cotton buds and isopropyl alcohol to clean the image sensor. AFAIR this is close to what the manufacturer recommends.
                                        • wilrikerundefined
                                          wilriker @dc42
                                          @dc42 Thanks, will do it like that then.
                                          Manuel
                                          My Tool Collection
                                            PS - the manufacturer says you must not squirt alcohol on the image sensor because it could get inside. So moisten the cotton bud with alcohol and then use it to gently wipe the sensor.
