    Laser Filament Monitor - test results
    Filament Monitor
    16
    139
    21.3k
      dc42 administrators @wilriker
      @wilriker said in Laser Filament Monitor - test results:
      My question on the direction of the cone that @dc42 suggested was that it could be he meant to have the base of the cone starting at the sensor going into its tip in direction of the top housing part so that in the end it looks like the top housing has some kind of spike. I would assume that this is to keep the light deflecting internally in various directions until it is too faint to detected by the sensor anymore. But that is just an assumption.
      Yes, that is what I intended.
      • wilrikerundefined
        wilriker @dc42
        @dc42 said in Laser Filament Monitor - test results:
        So I came up with
        Top View:
        top view
        Bottom View:
        bottom view
        Sorry for those screen-caps, my OpenSCAD only produces fully-black PNG files when trying to export the design as an image.
        Manuel
        My Tool Collection
          deckingman @wilriker
          I think the png background colour gets inherited from the preferences you set for 3d view. So "Edit - Preferences - 3D view" then select a different colour scheme. I'm pretty sure that you can also create custom colour schemes but it means digging into code - not my field of expertise but I'm sure you could make the changes. As ever, Google is your friend.
          • wilrikerundefined
            wilriker @deckingman
            @deckingman OK, I can see that the background color gets inherited from the theme. But why is then everything black on export? Even the blue-ish rendered parts?
            Anyway, changing the theme helps. I found though that the export does not do anything really different from a screen capture. 😂 So no use in doing it that way.
            Manuel
            My Tool Collection
              Don't ask me - I'm just an old guy who cuts a screws bits of wood together ☺ .
              wilrikerundefined 1 Reply Last reply Reply Quote 1
              • wilrikerundefined
                @deckingman said in Laser Filament Monitor - test results:
                Don't forget the guy that gives great advise on how to also screw aluminum extrusions together. 😉
                Manuel
                My Tool Collection
                • wilrikerundefined
                  wilriker
                  So, I added some more results to my Spreadsheet and they line up with the previous results pretty good which means that for the same conditions, e.g. filament, housing and settings the sensor will perform quite stable.
                  Probably tonight or maybe tomorrow night I can switch the housing to one having a cone-shaped interior as @dc42 suggested - took me some tries to design it in a way to be actually printable. I will then do some more prints with the current filament to see if the redesigned housing performs better or worse before switching filament.
                  Manuel
                  My Tool Collection
                    T3P3Tony administrators @wilriker
                    @wilriker thanks for the update. So from those results you could probably be comfortable having the filament sensor error outside 40%-120% which over 3mm mean it would under read by 1.8mm before having an error - that is short enough to save some prints, but not all, depending on how big the object is, layer height etc.
                    • fmaundefined
                      fma
                      Did someone try to reduce/increase the check length (default to 3mm)? Could it improve things?
                      Frédéric
                        T3P3Tony administrators @fma
                        @fma I did a lot of testing with 1mm earlier on, this increased the % range of min and max, which is to be expected as there is less difference to average over and some time maybe that 1mm is all during a fast retract or something. On the other hand if you have 20%-140% of 1mm then the maximum underextrusion before an alarm is only 0.8mm so worth testing and tuning for specific filaments, retract lengths etc.
                        • fmaundefined
                          fma
                          Ok, I see. Thanks.
                          Frédéric
                          • wilrikerundefined
                            wilriker @T3P3Tony
                            @t3p3tony Based on my current results and as stable as they are I would even be comfortable to set the limits to a narrower range of 65-105%. 🙂 I will add this to my filament's config.g but still with S0 as long as I continue testing.
                            EDIT: Regarding check length: would it make sense to synchronize this somehow with retraction distance? On my MK8 direct extruder I use a rather unusual 3.5mm retraction length which is quite close to 3mm check length.
                            Manuel
                            My Tool Collection
                            • wilrikerundefined
                              wilriker
                              I switched now to a cone shaped interior. First print with it might be tomorrow or the day after.
                              But when I removed the PCB from the housing I took a look at the sensor itself and it seems to have some kind of dirt on the shiny part. It is hart to spot or to explain. What would be the best way to clean it? My intuitive approach would be to deal with it like with my camera lenses that have sensitive coatings on it and therefore need careful cleaning with just cigarette paper (the softest paper available) and Isopropyl alcohol. But I am open to suggestions.
                              Mounted in its new housing it just happily blinks now... green - red - green - red - green - red... 😁
                              EDIT: And yes I read and adhered to
                              Take great care not to damage [the sensor] or to touch it. Do not put the filament monitor PCB component-side down on any surface.
                              Manuel
                              My Tool Collection
                                I used cotton buds and isopropyl alcohol to clean the image sensor. AFAIR this is close to what the manufacturer recommends.
                                • wilrikerundefined
                                  wilriker @dc42
                                  @dc42 Thanks, will do it like that then.
                                  Manuel
                                  My Tool Collection
                                    PS - the manufacturer says you must not squirt alcohol on the image sensor because it could get inside. So moisten the cotton bud with alcohol and then use it to gently wipe the sensor.
                                    • wilrikerundefined
                                      wilriker @dc42
                                      Did it like that. Sensor seems to be clean now. I have not printed anything yet but the status gives a lower brightness than before. No idea if that is somehow related.
                                      Also did a first print with the internally cone shaped housing and the results are worse than with the default square window and open top. Not much worse but measurable. See my Google Spreadsheet for details.
                                      Manuel
                                      My Tool Collection
                                      • wilrikerundefined
                                        wilriker
                                        And a second print with the cone-housing. Again slightly worse than the straight square open-window version.
                                        I printed @T3P3Tony's housing with divergence today but when I tried to mount it I noticed that it does not fit. Has there been a rearrangement on the PCB at some point in time? Because the window for the sensor is much to far down. I took a photo with mounting holes aligned because they fit:
                                        housing comparison
                                        Left is Tony's design, right is my cone-shaped based on @dc42's version on Thingiverse.
                                        Manuel
                                        My Tool Collection
                                        wilrikerundefined T3P3Tonyundefined 3 Replies Last reply Reply Quote 1
                                        • wilrikerundefined
                                          wilriker @wilriker
                                          Can I get a patent on this term - or better word-spaghetti? 😂
                                          Manuel
                                          My Tool Collection
                                            @wilriker that is very odd - maybe i uploaded the wrong version i need to check this when i get a chance!
