    Running Bed Mesh Compensation
    3.8k
    • Billsrfundefined
      Billsrf @dc42
      @dc42 I needed a quick fix. Not another issue
      www.dpp3d.com , pellet fed large format 3d printers
        T3P3Tony administrators @Billsrf
        @billsrf please let us know what versions of firmware, wifi server and DWV are running as it looks like they are out of sync.
        • Billsrfundefined
          Billsrf
          This happened after I loaded the ZIP file from github link that @dc42 directed me to, to update my firmware and enable my bed mesh compensation. I downloaded the zip and then uploaded it via the DWC, thats when it went crazy. So I reinstalled my working version that I am using now. 0_1534938258128_Version Image.JPG
          • Billsrfundefined
            Billsrf
            I'm sorry for my hasty remark earlier. What am I doing wrong trying to upload the new DWC version?
            • Billsrfundefined
              Billsrf @dc42
              @dc42 I have tried to upload from the link you gave me on get hub but it does the same crazy thing each time. What am I doing wrong???
                @billsrf are you updating all three - the Duet Firmware, The Wifi module firmware and Duet Web control:
                https://github.com/dc42/RepRapFirmware/releases/tag/2.01
                Duet2CombinedFirmware.bin
                DuetWebControl-1.22.zip
                DuetWiFiServer-1.21.bin
                • Billsrfundefined
                  Billsrf
                  No, I just uploaded the zip file for the DWC
                  • Billsrfundefined
                    Billsrf
                    That seems to have worked, thank you. Now, lol, how do I tell it to shut off the bed and nozzle after the print finishes and moves to X0 Y0?
                    • Billsrfundefined
                      Billsrf
                      Did the updating as you suggested, still have the same problem with the bed mesh compensation, still only does a 1/4 of the build plate and disables the connection to the DWC.
                        dc42 administrators @Billsrf
                        @billsrf said in Running Bed Mesh Compensation:
                        So it stops after doing 1/4 of the build plate, and DWC disconnects: correct?
                        Please reconnect after this happens, run M122 and post the report here.
                        • Billsrfundefined
                          Billsrf
                          It will net reconnect. I have to restart the printer to reconnect.
                            In that case, please try connecting via USB. When DWC will not reconnect or refresh, send M122 via USB (e.g. from YAT or Pronterface) to get the diagnostic report, and post that here.
                            Billsrfundefined 2 Replies Last reply Reply Quote 0
                            • Billsrfundefined
                              Billsrf
                              OK, Will Do
                              • Billsrfundefined
                                Billsrf @dc42
                                @dc42 here is the M122 report0_1535484057809_M122 Report.txt
                                • Billsrfundefined
                                  Billsrf @dc42
                                  @dc42 any luck?
                                    The report indicates output buffer overflow and starvation. Please try firmware 2.01 or 2.02beta1, which include fixes to avoid this situation.
                                    • Billsrfundefined
                                      Billsrf @dc42
                                      @dc42 I uploaded the latest firm ware and still the same issue
                                      • Billsrfundefined
                                        Billsrf @dc42
                                        @dc42 I am using 1.22.1 with the Duet2combinedfirmware.bin
                                          Latest firmware for Duet WiFi/Ethernet is 2.01, or 2.02beta1. Perhaps the 1.22.1 number you reported is the Duet Web Control version? Send M115 to check the firmware version.
                                          Billsrfundefined 1 Reply Last reply Reply Quote 0
                                          • Billsrfundefined
                                            Billsrf @dc42
