    Duet Maestro Freefall
    Firmware wishlist
    10
    51
    5.7k
    • LeonMFundefined
      LeonMF
      I hate to come post here but I think you guys may have a better idea as to whether this is inherent to the Trinimac stepper chips or something that could be addressed in firmware or with a settings. current firmware 2.02beta1.
      The primary printer the Maestro is installed on is the new M3D Promega which has a... novel... belt design for the Z axis. When the motor over currents, rather than skipping a step the drivers seem to cut off and cause the motors to freewheel (not limited by being a generator somehow) and the bed crashes to the floor of the printer. This, at a minimum skips belts and requires a full bed re-calibration.
      Is it possible to just disable the steppers and go into a stop condition and let the natural force of the steppers let the bed drift to the bottom like it does when you power the machine off or is this a limitation of the stepper driver chips themselves?
      Thanks!
      Current: Railcore II ZLT w/Duet 3 and Hemera hot end.
      Retired: Robo3D R1,BI V2.5 Delta updated to BerryBot magnets, bespoke carriages and Duet Ethernet, M3D Promega;
        Please explain what you mean by "When the motor over currents".
        • LeonMFundefined
          LeonMF
          The current behavior is that when the bed is pushed up into the nozzle, I would expect this to overcome the motor torque and cause a skipped step. Instead the motor seems to reach current limit, the driver shuts off(?) and the the bed drops at a high rate of speed (gravity? Feels like faster than gravity) and crashes to the bottom. I could take the hit and provide a video if needed for diagnostics.
          • fcwiltundefined
            fcwilt @LeonMF
            @leonmf said in Duet Maestro Freefall:
            Is the movement in the axis so free the the bed will drop on it's own due to gravity?
            Could you post a picture of your machine?
            • LeonMFundefined
              LeonMF
              @fcwilt Yes, the bed is belt driven from a single Z axis motor. With the stepper disabled, the bed will slowly drop while acting as a generator. When the stall detection kicks in (I just learned this was a feature and I presume they may be using M915? I'm going to check when I get home) the motors are disconnected from the stepper and the bed falls like a rock. Given that it's a 15x15 glass bed with aluminum frame... this is undesirable behavior and will break things!
              https://store.printm3d.com/pages/promega
              I can post a picture later if you still want one.
              • fcwiltundefined
                fcwilt @LeonMF
                Thanks much. That is a large and pricey printer. I guess for that kind of money that can provide a low friction setup.
                My FT5 moves smoothly but it slowly sinks down without crashing.
                • LeonMFundefined
                  LeonMF
                  I hope this printer becomes a solid workhorse but, I'm afraid, it is still more of a beta solution and this particular problem is one of the more vexing ones!
                  • LeonMFundefined
                    LeonMF
                    Here are some videos highlighting the issue:
                    Duet Power off free-fall:
                    https://youtu.be/WCvHGXi6jxs
                    Duet Power On Free-Fall
                    https://youtu.be/7uG-6czPOVY
                    Duet Bed Stall crash
                    https://youtu.be/QH9c-w1Nbgg
                    deckingmanundefined wilrikerundefined napierdmarkundefined 3 Replies Last reply Reply Quote 1
                    • mrehorstdmdundefined
                      mrehorstdmd
                      Wow! I'd say something needs to be done about that.......
                        deckingman @LeonMF
                        @leonmf OK. So what seems to be happening is that the bed is being driven in minus Z because those moves are very much faster than gravity with no power. So if it's being driven, then there must be something in your files telling it to move to Znnn at a feedrate (speed) of Fnnn. Might be an idea to post your home Z file, or at least take a look at it and see what is being commanded after the probe or stall detection or whatever method you use to home, has been triggered.
                        Edit. And/or you have the steps per mm for Z set wildly wrong.
                        • wilrikerundefined
                          wilriker @LeonMF
                          @leonmf For one @deckingman is right, the last one is definitely driven by the motor. You can even hear the high pitched sound of the motor running at a very high speed. Please post homez.g, homeall.g and maybe also your config.g.
                          Manuel
                          My Tool Collection
                            deckingman @wilriker
                            @wilriker said in Duet Maestro Freefall:
                            @leonmf For one @deckingman is right, ...................
                            Manuel, mind if I correct your translation? That sounds a bit like "For once deckingman is right" To a native English speaker, that means the person is usually wrong but on this occasion was right. Now of course, you might have meant that I'm usually wrong, in which case no correction is needed 😉
                            • wilrikerundefined
                              wilriker @deckingman
                              @deckingman said in Duet Maestro Freefall:
                              Thanks and I never mind being corrected! 🙂 Also I definitely did not want to say that you are usually wrong because I know better. 😂 (And I don't mean I know better not to say it but I know better that this would not be true).
                              But one thing I wonder now: I wrote "For one" and wanted to say "First of all" whereas you corrected "For on_c_e" (which I would have known to have the meaning to described). So would my wording have expressed what I wanted to say?
                              Manuel
                              My Tool Collection
                                I agree, the motor is definitely driving the bed down.
                                Is the printer definitely being controlled by a Duet Maestro? I believe M3D used other Duets in early machines, before the Maestro became available. So I am wondering whether your machine is running a Duet 2 Ethernet and the stall detection is configured to do something silly.
                                  Yes, you did say "for one" but it's not a common or normal expression. So the meaning of what you wrote was clear but it's an unusual thing to say. Hence it could easily be misinterpreted as a typo and the actual meaning was something else. Whilst I always enjoy these little chats, this probably isn't the time or place to discuss the finer points of English grammar. ☺
                                  • wilrikerundefined
                                    You are right and we should put a stop to hijacking this thread. 😉 Thanks for clarification, though.
                                    Manuel
                                    My Tool Collection
                                    • LeonMFundefined
                                      LeonMF
                                      @dc42 This is definitely a Duet Maestro. I can post a board picture later if you want confirmation.
                                      Firmware Name: RepRapFirmware for Duet 2 Maestro
                                      Firmware Electronics: Duet Maestro 1.0
                                      Firmware Version: 2.01beta1(RTOS) (2018-06-23b1)
                                      Web Interface Version: 1.22.1
                                      Here is my current config:
                                      https://www.dropbox.com/s/aeppocjnft4zg4q/Promega Config.zip?dl=0
                                      I looked for an a M915 command in the files but found nothing, Typing M915 into the gcode console says not supported. Is there something else I should be looking at?
                                      • Dougal1957undefined
                                        Dougal1957
                                        Could this by due to the fact that you have Deploy/retractprobe files in the sys directory there was a note on one of the firmware updates to remove them as they caused issues?
                                        • wilrikerundefined
                                          wilriker
                                          What confuses me more is that on the one hand the config defines
                                          M574 X2 Y2 Z2 S0 ; Set xy end-stops types (S0 is active low, applied to XY)
                                          a Z-max switch as an endstop in machine_endstoptypes.g and then also
                                          a switch-based Z-probe in machine-zprobe.g.
                                          Additionally at the start of homez.g there is
                                          ; Ignore Machine boundaries
                                          M564 H0 S0
                                          and I am not sure how this influences the latter
                                          ; Rapid Z until limit switch triggers
                                          G0 Z450 F1500 S1
                                          in the same file.
                                          So @LeonMF can you give some more information on what your endstop for Z actually is?
                                          Manuel
                                          My Tool Collection
                                          LeonMFundefined 1 Reply Last reply Reply Quote 0
                                            Dougal1957
                                            The way the config has been written with all those called macros is very confusing that's for sure it seems to be very over complicated
                                            wilrikerundefined LeonMFundefined 2 Replies Last reply Reply Quote 0
