    [SOLVED] Heated bed PID auto tune failed.
    7.5k
      What happens if you use a lower target temperature such as 70C?
      The bed needs to be allowed to cool down completely to room temperature between tuning attempts.
      vapvapundefined 1 Reply Last reply Reply Quote 0
      • vapvapundefined
        vapvap @dc42
        11:20:51 PM
        M307 H0 A181.2 C1041.0 D4.0 P0.5
        Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 206C.
        11:20:43 PM
        M307 H0 A181.2 C1041.0 D4.0 P0.6
        10:39:52 PM
        M307 H0 A181.2 C1041.0 D4.0 P0.7
        10:39:27 PM
        M307 H0 A181.2 C1041.0 D4.0 P0.8
        10:38:52 PM
        10:21:55 PM
        Warning: Auto tune of heater 0 failed due to bad curve fit (A=181.2, C=1041.0, D=-0.8)
        10:05:55 PM
        Auto tune phase 3, peak temperature was 70.3
        10:05:48 PM
        Auto tune phase 2, heater off
        10:00:36 PM
        Auto tune phase 1, heater on
        10:00:30 PM
        M303 H0 S70
        Auto tuning heater 0 using target temperature 70.0°C and PWM 1.00 - do not leave printer unattended
        10:00:00 PM
        M307 H0
        Heater 0 model: gain 90.0, time constant 700.0, dead time 30.0, max PWM 1.00, calibration voltage 0.0, mode PID, inverted no, frequency default
        Computed PID parameters for setpoint change: P46.3, I0.319, D971.8
        Computed PID parameters for load change: P46.
        9:59:31 PM
        Connection established!
        9:59:31 PM
        Page Load complete!
          Try with those M307 settings. The warning message is usual when using a high-power bed heater.
          • vapvapundefined
            vapvap
            This post is deleted!
              What type of heated bed is it?
              • vapvapundefined
                vapvap @Phaedrux
                @phaedrux Aluminum disc 220mm (Delta Printer).
                • vapvapundefined
                  vapvap @dc42
                  In the end, I achieved a positive value.
                  But what to do next?
                  After all, the "auto tune" still does not work.
                  7:20:11 PM
                  Warning: Auto tune of heater 0 failed due to bad curve fit (A=183.8, C=1042.4, D=0.1)
                  7:04:11 PM
                  7:04:04 PM
                  6:58:52 PM
                  6:58:46 PM
                  M303 H0 S70
                  6:58:30 PM
                  M307 H0
                  Heater 0 model: gain 188.4, time constant 1070.6, dead time 5.0, max PWM 1.00, calibration voltage 0.0, mode PID, inverted no, frequency default
                  Computed PID parameters for setpoint change: P202.9, I2.773, D710.0
                  Computed PID parameters for load change: P2
                  6:58:23 PM
                  M307 H0 A188.4 C1070.6 D5.0
                  Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 213C.
                    Phaedrux Moderator @vapvap
                    @vapvap said in Heated bed PID auto tune failed.:
                    And what is the heating element?
                    • vapvapundefined
                      vapvap @Phaedrux
                      @phaedrux said in Heated bed PID auto tune failed.:
                      https://www.amazon.co.uk/anycubic-MK3-Round-Aluminium-Diameter-Printers/dp/B01LZ36INV
                        Ok, now is it wired as 12v or 24v? What is your power supply voltage and wattage?
                        • vapvapundefined
                          vapvap @Phaedrux
                          @phaedrux 12V, 30A, 360W.
                          https://www.amazon.co.uk/gp/product/B072J97N8T/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
                            Please note: There is no Thermister not installed on the card or including in the list. Please, install the precisely Thermister
                            The listing says the bed doesn't come with a thermistor. What thermistor are you using and do you have the right configuration values for it?
                            • vapvapundefined
                              vapvap @Phaedrux
                              @phaedrux 100K Wired NTC Thermistor 3950
                              https://www.ebay.co.uk/itm/100K-Wired-NTC-Thermistor-for-3D-Printers-3950-RepRap-Marlin-EPCOS-Flux-Workshop-/113189674857?hash=item1a5aa15f69
                                dc42 administrators @vapvap
                                7:20:11 PM
                                In your M307 command, use the A and C values reported by auto tuning, but try a value of 5 for D. Then heat the bed to a typical temperature and see how it performs. If the temperature oscillates, increase D some more.
                                vapvapundefined 2 Replies Last reply Reply Quote 0
                                • vapvapundefined
                                  vapvap @dc42
                                  @dc42 In the end, everything worked. Many, many thanks for your help.
                                  I did it Only because You shared your thoughts and experience with me.
                                  Without you, I would never have done it.
                                  In gratitude, let me share my experience with you.
                                  It is not enough, it can be useful ...
                                  With best regards.
                                  • vapvapundefined
                                    vapvap @dc42
                                    @dc42 After installing MOSFET, I again cannot autotune my PID.
                                    After endless attempts, I just got ~ :
                                    Warning: Auto tune of heater 0 failed due to bad curve fit (A=191.5, C=1032.9, D=-0.1)
                                    8:14:49 PM
                                    Auto tune phase 3, peak temperature was 80.0
                                    8:14:42 PM
                                    8:08:14 PM
                                    8:08:08 PM
                                    M303 H0 S80
                                    Auto tuning heater 0 using target temperature 80.0°C and PWM 1.00 - do not leave printer unattended
                                    7:34:06 PM
                                    M307 H0 A190.3 C1026.6 D5.0
                                    Tell me please, is my MOSFET a bad idea, or am i doing something wrong?
                                    Regards.
                                      It's the same issue as before: the PID tuning algorithm has failed to compute the dead time for your bed.
                                      Adding the mosfet may have changed the gain slightly but it won't have changed the time constant or dead time. Comparing your results:
                                      Old: A=183.8, C=1042.4, D=0.1
                                      New: A=191.5, C=1032.9, D=-0.1
                                      this is indeed the case. So I suggest you use the A and C parameters reported by tuning, and whatever value of the D parameter that worked for you last time.
                                      • vapvapundefined
                                        vapvap @dc42
                                        @dc42 Unfortunately, I have again and again fail my calibration.
                                        It seems to me that I spend too much time on it.
                                        Maybe it will be easier to install PT100 / Thermocouple?
                                          @vapvap said in [SOLVED/(+/-)UNSOLVED ] Heated bed PID auto tune failed.:
                                          I don't understand what you mean by "fail my calibration". All you need to do is add M307 P0 A191.5 C1032.9 D5.0 to your config.g file, and make sure that there isn't a similar command in config-override.g that will override it. Then heat the bed up to normal temperature. If you see oscillations then increase the D parameter. You can do this live, i.e. send the M307 command with different D parameters while the bed is hot, until you find a suitable value.
                                          adavidmundefined vapvapundefined 2 Replies Last reply Reply Quote 0
                                          • adavidmundefined
                                            adavidm @dc42
                                            @dc42 said in [SOLVED/(+/-)UNSOLVED ] Heated bed PID auto tune failed.:
                                            It looks like @vapvap is setting the parameters using M307 and then running an autotune with M303, thinking that that is needed. Possibly a language barrier problem?
                                            adavidm
