    [SOLVED] Heated bed PID auto tune failed.
    7.5k
      deckingman @vapvap
      @vapvap It's the negative dead time that's screwing it up but I don't know why you are getting that. Are you starting from a low ambient or are things really hot in your part of the world?
      vapvapundefined 1 Reply Last reply Reply Quote 0
      • vapvapundefined
        vapvap @deckingman
        @deckingman Normal room temperature (~20C).
          What happens if you use a lower target temperature such as 70C?
          The bed needs to be allowed to cool down completely to room temperature between tuning attempts.
          • vapvapundefined
            vapvap @dc42
            11:20:51 PM
            M307 H0 A181.2 C1041.0 D4.0 P0.5
            Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 206C.
            11:20:43 PM
            M307 H0 A181.2 C1041.0 D4.0 P0.6
            10:39:52 PM
            M307 H0 A181.2 C1041.0 D4.0 P0.7
            10:39:27 PM
            M307 H0 A181.2 C1041.0 D4.0 P0.8
            10:38:52 PM
            10:21:55 PM
            Warning: Auto tune of heater 0 failed due to bad curve fit (A=181.2, C=1041.0, D=-0.8)
            10:05:55 PM
            Auto tune phase 3, peak temperature was 70.3
            10:05:48 PM
            Auto tune phase 2, heater off
            10:00:36 PM
            Auto tune phase 1, heater on
            10:00:30 PM
            M303 H0 S70
            Auto tuning heater 0 using target temperature 70.0°C and PWM 1.00 - do not leave printer unattended
            10:00:00 PM
            M307 H0
            Heater 0 model: gain 90.0, time constant 700.0, dead time 30.0, max PWM 1.00, calibration voltage 0.0, mode PID, inverted no, frequency default
            Computed PID parameters for setpoint change: P46.3, I0.319, D971.8
            Computed PID parameters for load change: P46.
            9:59:31 PM
            Connection established!
            9:59:31 PM
            Page Load complete!
              Try with those M307 settings. The warning message is usual when using a high-power bed heater.
              • vapvapundefined
                vapvap
                This post is deleted!
                  What type of heated bed is it?
                  • vapvapundefined
                    vapvap @Phaedrux
                    @phaedrux Aluminum disc 220mm (Delta Printer).
                    • vapvapundefined
                      vapvap @dc42
                      In the end, I achieved a positive value.
                      But what to do next?
                      After all, the "auto tune" still does not work.
                      7:20:11 PM
                      Warning: Auto tune of heater 0 failed due to bad curve fit (A=183.8, C=1042.4, D=0.1)
                      7:04:11 PM
                      7:04:04 PM
                      6:58:52 PM
                      6:58:46 PM
                      M303 H0 S70
                      6:58:30 PM
                      M307 H0
                      Heater 0 model: gain 188.4, time constant 1070.6, dead time 5.0, max PWM 1.00, calibration voltage 0.0, mode PID, inverted no, frequency default
                      Computed PID parameters for setpoint change: P202.9, I2.773, D710.0
                      Computed PID parameters for load change: P2
                      6:58:23 PM
                      M307 H0 A188.4 C1070.6 D5.0
                      Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 213C.
                        Phaedrux Moderator @vapvap
                        @vapvap said in Heated bed PID auto tune failed.:
                        And what is the heating element?
                        • vapvapundefined
                          vapvap @Phaedrux
                          @phaedrux said in Heated bed PID auto tune failed.:
                          https://www.amazon.co.uk/anycubic-MK3-Round-Aluminium-Diameter-Printers/dp/B01LZ36INV
                            Ok, now is it wired as 12v or 24v? What is your power supply voltage and wattage?
                            • vapvapundefined
                              vapvap @Phaedrux
                              @phaedrux 12V, 30A, 360W.
                              https://www.amazon.co.uk/gp/product/B072J97N8T/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
                                Please note: There is no Thermister not installed on the card or including in the list. Please, install the precisely Thermister
                                The listing says the bed doesn't come with a thermistor. What thermistor are you using and do you have the right configuration values for it?
                                • vapvapundefined
                                  vapvap @Phaedrux
                                  @phaedrux 100K Wired NTC Thermistor 3950
                                  https://www.ebay.co.uk/itm/100K-Wired-NTC-Thermistor-for-3D-Printers-3950-RepRap-Marlin-EPCOS-Flux-Workshop-/113189674857?hash=item1a5aa15f69
                                    dc42 administrators @vapvap
                                    7:20:11 PM
                                    In your M307 command, use the A and C values reported by auto tuning, but try a value of 5 for D. Then heat the bed to a typical temperature and see how it performs. If the temperature oscillates, increase D some more.
                                    vapvapundefined 2 Replies Last reply Reply Quote 0
                                    • vapvapundefined
                                      vapvap @dc42
                                      @dc42 In the end, everything worked. Many, many thanks for your help.
                                      I did it Only because You shared your thoughts and experience with me.
                                      Without you, I would never have done it.
                                      In gratitude, let me share my experience with you.
                                      It is not enough, it can be useful ...
                                      With best regards.
                                      • vapvapundefined
                                        vapvap @dc42
                                        @dc42 After installing MOSFET, I again cannot autotune my PID.
                                        After endless attempts, I just got ~ :
                                        Warning: Auto tune of heater 0 failed due to bad curve fit (A=191.5, C=1032.9, D=-0.1)
                                        8:14:49 PM
                                        Auto tune phase 3, peak temperature was 80.0
                                        8:14:42 PM
                                        8:08:14 PM
                                        8:08:08 PM
                                        M303 H0 S80
                                        Auto tuning heater 0 using target temperature 80.0°C and PWM 1.00 - do not leave printer unattended
                                        7:34:06 PM
                                        M307 H0 A190.3 C1026.6 D5.0
                                        Tell me please, is my MOSFET a bad idea, or am i doing something wrong?
                                        Regards.
                                          It's the same issue as before: the PID tuning algorithm has failed to compute the dead time for your bed.
                                          Adding the mosfet may have changed the gain slightly but it won't have changed the time constant or dead time. Comparing your results:
                                          Old: A=183.8, C=1042.4, D=0.1
                                          New: A=191.5, C=1032.9, D=-0.1
                                          this is indeed the case. So I suggest you use the A and C parameters reported by tuning, and whatever value of the D parameter that worked for you last time.
                                          • vapvapundefined
                                            vapvap @dc42
                                            @dc42 Unfortunately, I have again and again fail my calibration.
                                            It seems to me that I spend too much time on it.
                                            Maybe it will be easier to install PT100 / Thermocouple?
