    Ethernet not working what did i miss ?
    Firmware installation
    1.6k
      T3P3Tony administrators @the_lund
      @the_lund strange that the Ethernet LEDs do not light up, but it got an IP address what happens if you ping it:
      ping 192.168.0.22
      You say you have a Duet Ethernet that is working, what happens if you unplug the ethernet cable from that and plug it into the new one, with only 5V power applied and nothing else plugged in?
      • the_lundundefined
        the_lund
        Did not work sorry ping the wrong ip
        i have tryed with the cabels
          @the_lund what is displayed in the browser when you go to the IP address?
          the_lundundefined 1 Reply Last reply Reply Quote 0
          • the_lundundefined
            the_lund @T3P3Tony
            @t3p3tony
            Another pc has taken the same ip
            • the_lundundefined
              the_lund
              i get to a site like when your net broke down
                @the_lund it sounds like the board is faulty, please would you contact the reseller you bought it from and arrange a replacement under warranty.
                • the_lundundefined
                  the_lund @T3P3Tony
                  @t3p3tony i will i bought it direct from http://duet3d.com 😉
                  Thanks for your help
                  • cabal2000undefined
                    cabal2000
                    I am having a similar issue. With USB cable connected the ethernet stays on but the minute I disconnect the USB and power up the board, it stays on for a few seconds and then turns off.
                      dc42 administrators @cabal2000
                      @cabal2000 said in Ethernet not working what did i miss ?:
                      Do you mean that just the Ethernet turns off, or something else?
                      Do you have a jumper on the I_5V_EN pins, to enable the internal 5V regulator?
                      cabal2000undefined 1 Reply Last reply Reply Quote 0
                        cabal2000 @dc42
                        @dc42 Ethernet shuts off. Blinks for a few seconds and stops.
                          Do the red 5V and green 3.3V LEDs on the Duet go off as well?
