    Tips for adjusting Precision Piezo Orion
    Third-party add-ons
    8
    28
    3.6k
    • cabal2000undefined
      cabal2000 @hevilp
      @hevilp
      Core XY.
      G28 Z
      Error: G0/G1: insufficient axes homed
      • hevilpundefined
        hevilp
        Okay:
        M574 X1 Y1 S1 ; Set active high endstops
        M574 Z1 S2 ; Define Z to use Probe. Home to Min
        ; Z Probe
        M558 P8 I1 R0.6 F300 Z1
        cabal2000undefined 1 Reply Last reply Reply Quote 0
          cabal2000 @hevilp
          @hevilp
          Nope!!
          I only have it connected to the z-stop switch. This is correct right?
          And also, which is the correct one i should clicked on Switch/Unmodulated/simple Ultrasonic etc...?
          • hevilpundefined
            hevilp
            No it comes to the z Probe connection, not the end stop z
            Take a look at the wiring guide from duet for your Board
              cabal2000 @hevilp
              @hevilp
              Will that makes more sense!! OK, 5v or 3.3v and Z-Probe_mod I am guessing!!
              • hevilpundefined
                hevilp
                I dont know your Board, but piezo can do 5v yes
                  cabal2000 @hevilp
                  @hevilp
                  I think I have that figured out BUT for some reason the z is not going up.
                  • Moriquendiundefined
                    Moriquendi
                    I'm do not know the Maestro but...
                    To use the Orion as the Z-endstop and the Z-probe it must be connected to the Z-probe connector. As @hevilp says, your M558 should be...
                    M558 P8 (mode 8, digital, unfiltered) I1 (inverted, active low) R0.6 (wait 0.6s before Z-probe) F300 (probe at 5mm/s) Z1 (probe from 1mm z-height)
                    Did you use the Duet online configurator?
                    I'm on holiday at the moment so I don't have access to my printer to check your config against mine.
                    Idris
                      cabal2000
                      @moriquendi So, do I just change the one line or take everything out I just add this line. Sorry for such noobs questions, very very new to Duet boards. And yes i did use the Duet online configurator. I used the "Switch" setting. And set all the endstops to Low End. Z to Z-Probe.
                      Moriquendiundefined 1 Reply Last reply Reply Quote 0
                        Moriquendi @cabal2000
                        @cabal2000 Just change that line in your config.g
                        Here's the relevant part of my config.g
                        M574 X1 Y1 S0 ; Set active low endstops
                        M574 Z1 S2 ; Set endstops controlled by probe
                        M558 P8 I1 H2 R0.5 F300 T6000 ; Set Z probe type to switch and the dive height + speeds
                        G31 P500 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
                        The important parts are:
                        M574 X1 Y1 S0 ; X and Y endstops active low.
                        M574 Z1 S2 ; Z-endstop active low, controlled by Z-probe.
                        Do you have these lines in your config.g?
                        Idris
                          cabal2000 @Moriquendi
                          @moriquendi
                          What do you have in your homez?
                            cabal2000
                            This is what I have:
                            ; homez.g
                            ; called to home the Z axis
                            ; generated by RepRapFirmware Configuration Tool on Mon Sep 17 2018 22:03:45 GMT-0230 (Newfoundland Daylight Time)
                            G91 ; relative positioning
                            G90 ; absolute positioning
                            G1 X150 Y150 F6000 ; go to first probe point
                            ;G91 ; relative positioning
                            ;G1 S2 Z5 F100 ; lift Z relative to current position
                            ;G90 ; absolute positioning
                            The head moves to x150 y 150 (center of bed) but when the z starts to rise the head is slowly moving to the left. It isn't staying on center
                              Perhaps you have axis skew compensation enabled in config.g? It's the M556 command. Not to be confused with M558, which configured the Z probe.
                                Moriquendi
                                My homez.g is the same as yours except for different dimensions.
                                Idris
