    Setup Issue
    1.3k
    • kwhitehouse68undefined
      kwhitehouse68
      I am trying to set up the Duet Wifi on my MacBook pro but I can't get past the first step. The USB is not recognized on my computer for some reason. I receive the following code when trying to connect:
      /dev/tty.*
      -bash: /dev/tty.Bluetooth-Incoming-Port: Permission denied
      I have also tried running as admin, as seen in the forums:
      sudo: /dev/tty.Bluetooth-Incoming-Port: command not found
      Any help would be really appreciated.
      • briskspiritundefined
        briskspirit
        @kwhitehouse68 said in Setup Issue:
        /dev/tty.*
        Try this command when Duet is connected: ls /dev/tty.*
        And show output here.
        kwhitehouse68undefined 1 Reply Last reply Reply Quote 0
        • nicktundefined
          nickt
          I have exactly the same problem ,
          ls /dev/tty.*
          it says
          " no such file of directory "
          total stuck guess i need to borrow a PC ??
          brismaundefined 1 Reply Last reply Reply Quote 1
            briskspirit
            ok, lets try: ls /dev/tty*
            if nothing, then: system_profiler SPUSBDataType
            • brismaundefined
              brisma @nickt
              @nickt try with sudo ls /dev/tty.*
              • nicktundefined
                nickt
                thanks for the info , i have put the results below......
                No such file or directory
                Vendor ID: 0x0a5c (Broadcom Corp.)
                Version: 1.00
                Speed: Up to 12 Mb/sec
                Manufacturer: Apple Inc.
                Location ID: 0xfa110000 / 3
                Current Available (mA): 500
                Current Required (mA): 94
                Extra Operating Current (mA): 0
                Built-In: Yes
                            Bluetooth USB Host Controller:
                              Product ID: 0x821a
                              Vendor ID: 0x05ac  (Apple Inc.)
                              Version: 0.42
                              Location ID: 0xfa113000 / 6
                              Current Required (mA): 0
                              Built-In: Yes
                sudo ls /dev/tty.*
                Password: ( then a key symbol )
                  So what happens if you then enter the super user password?
                  • nicktundefined
                    nickt
                    Out of interest can i set up the wifi if i plug the duet lcd screen in ?
                      Yes, if your PanelDue is running recent firmware that includes the Shift key on the touch keyboard, then you can send the M587 wifi setup command command from it.
                        kwhitehouse68 @briskspirit
                        @briskspirit
                        Last login: Sat Oct 6 15:32:57 on ttys000
                        MacBook-Pro:~ kwhitehouse$ ls /dev/tty.usbmodem1411
                          kwhitehouse68
                          Ok I have discovered the issue was me not entering the commands properly. Now my problem is that I hit the erase button while troubleshooting as per a forum thread and I think I probably need to reinstall something onto the board before it will connect. I found this thread, but it seems to be specific to windows:
                          https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
                          I have considered boot camping Windows on my mac or trying to use my raspberry pi with raspian on it to configure the board, but this seems unnecessary. If you could point me in the right direction for reloading the firmware to the board and getting to the point where I can start over at the setup procedures again, I would appreciate it.
                            T3P3Tony administrators @kwhitehouse68
                            @kwhitehouse68 if you erased the firmware you will need to use fallback procedure #3 on the documentation page you linked.
                            I don't have a Mac however there are instructions at the bottom of the section about how to use bossac to upload an image to the board.
