    AJAX timeout error during a print
    48
    8.6k
    • DjDemonDundefined
      DjDemonD
      Firmware Version: 1.15c (2016-09-05)
      WiFi Server Version: 1.02
      Web Interface Version: 1.12
      Communication Error
      An AJAX error has been reported, so the current session has been terminated.
      Please check if your printer is still on and try to connect again.
      Error reason: timeout
      www.precisionpiezo.co.uk
      • appjawsundefined
        appjaws
        Yes the reason is always timeout and I am using DWC1.12
        appjaws - Core XYUV Duet Ethernet Duex5
        firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
        Ormerod 1-converted to laser engraver, Duet wifi
        OpenSCAD version 2024.03.18
        Simplify3D 5.1.2
        • DjDemonDundefined
          DjDemonD
          I have only used Chrome for windows 10 so far. I will try other browsers as I read in another thread it might be the browser ending the session.
            I suspect it's caused by an unreliable WiFi connection, for example due to temporary interference. I've asked chrishamm if he can change DWC to do a configurable number of retries instead of just one.
            • W3DRKundefined
              W3DRK
              For what it's worth I have yet to experience this with my Duet WiFi. I use both Chrome and Firefox on Linux…no issues at all.
              On the other hand, with my Duet 0.6-which is obviously wired- I receive the AJAX timeout error like clockwork. It's not running the latest firmware though and I can't recall off hand what version it is...maybe 1.12 I believe...
              • appjawsundefined
                appjaws
                @dc42:
                I have a pre-production duet wifi board.
                Nothing else is on my network wirelessly so any hints as to what could be causing interference?
                Simplify3D 5.1.2
                • appjawsundefined
                  appjaws
                  @dc42:
                  Simplify3D 5.1.2
                  • W3DRKundefined
                    W3DRK
                    I think the ESP8266 is limited to 2.4GHz which can get really crowded these days. It may be nothing particular to your network but rather any number of wireless devices in your vicinity that share the same RF spectrum.
                    Most wireless routers or access points give you ability to manually choose a particular "channel" to use, you may want to try arbitrarily changing that to a few different ones and see if that makes a difference.
                    • appjawsundefined
                      appjaws
                      @W3DRK I'll look into that, thanks for the info
                      Simplify3D 5.1.2
                        T3P3Tony administrators
                        I am on my phone right now so can't check but I thought the latest version of DWC has the ability to set the number of AJAX timeout retries…
                        • appjawsundefined
                          appjaws
                          Yes you are right, I've just set it to 3 so I will see how that performs.
                          Simplify3D 5.1.2
                          • botundefined
                            bot
                            In regards to the WIFI channel selection, there are free programs available that detect and list all SSIDs in range, their strength, and the channel they are broadcasting on. This is really useful information for selecting a channel to use for your own SSID.
                            Microwave ovens can disturb wifi signals at 2.4Ghz. As can wireless landline telephones.
                            *not actually a robot
                            • DjDemonDundefined
                              DjDemonD
                              I'll try independently testing the increase retries for dwc (how do I set this?) and installing a WiFi access point in the room near to the printer.
                              • DjDemonDundefined
                                DjDemonD
                                Definitely fewer disconnects with a router in the room with the printer in it, on a clear channel and fairly close by.
                                • DjDemonDundefined
                                  DjDemonD
                                  Switched to Chrome Canary and had even fewer but still maybe 2 today in about 3-4 hours. This is not really a problem. Still unsure why these are happening though.
                                  • Russ Griesundefined
                                    Russ Gries
                                    also for me i get a lot of timeouts.
                                    it dose seem to be when its trying to do something, like download a file or during printing.
                                    some times when i go to the G code tab it starts lagging and will not display stuff, or just time out.
                                    I think part of this is the connection for me ( but I'm not sure of that yet) , but i though i would post for more feed back!
                                    ~Russ
                                    One Day At A Time…
                                    My Main Research Page:
                                    http://rwgresearch.com/open-projects/3d-printing-research/
                                      FWIW the WiFi received signal strength is reported to the USB port when you enable WiFi. This might help diagnose connection issues. I'll make it easier to retrieve this information in a future firmware release.
                                      • DjDemonDundefined
                                        DjDemonD
                                        I improved mine a lot but I've got a router 4 feet away from it. I imagine the environment immediately near to a 3d printer is not the best in terms of EMI.
                                        Is it possible to have an external wifi antenna, in a future revision? Or the port for one if its needed?
                                          We'd love to use an external antenna, and we produced a few pre-production boards with them. There are two issues that prevent us from making it standard:
                                          1. The ESP8266 versions supporting external antenna are not FCC certified. I have read that it is impossible to get a wifi module with external antenna certified, you have to get the entire piece of equipment certified instead.
                                          2. The version of the ESP8266 with external antenna is the ESP-08, but that has only 512kbytes or 1Mbyte flash memory, compared to the 4Mbyte flash on the ESP12F that we use. Currently we could manage with 1Mbyte, but it would limit the possibilities for firmware expansion. For the prototypes we changed the flash chip on the ESP-08, but this is not practical to do in production.
                                            We might be able to supply a boards with no esp mounted from the next production run… If you then choose to mount an esp7 or 8 then that's fine. Changing the flash chip is fiddly but doable if you have a rework station.
