    Maestro connection/guide halp!
    2.7k
    • Fizbanundefined
      Fizban
      Tried that, no dice.
      Both 0.0.0.0 and the config tool.
      So I need to take support to M3D ?
      Meh here's for me thinking Plug and play lol
        If both are 0.0.0.0 then your router is not allocating an IP address for the Maestro. Have you tried a different Ethernet cable? Do the LEDs on the Ethernet socket blink?
        • Fizbanundefined
          Fizban
          Oh aye they all the lights acts as expected. I'll try a different approach on the router, I might have had the same issue when I installed the pi.
          Ill keep you updated, thanks
          • Fizbanundefined
            Fizban
            Ok so I made progress. I might have put the files in the wrong place form the start. They are now located in /sys
            I doublechecked that it's connected to my router at .106 via DCHP however I would like to set it as static later on.
            But I stil can't conncet via duettest.local and if I type the ip 192.168.0.106 i get a white screen now with the message:
            Your Duet rejected the HTTP request: page not found
              That message usually means that you do not have the DuetWebControl files in the /web folder of the SD card.
              • Fizbanundefined
                Fizban
                Hmm by glance the SD looks like it got all I need. I'll grab a new package and move on to it.
                Thanks
                • Fizbanundefined
                  Fizban
                  Ok so erhm. Good news! and bad new! 😞 I've got the DWC working. On another computer for some reason.
                  Now I just got a ton of other issues lol.
                  My parts fan is running constantly.
                  BLtouch is triggered physically, but hardware is not detecting it.
                  All my endstops wont trigger, or rather.
                  -If I trigger Y the fans stops running and the board disconnects it self from the DWC and shuts down the USB.
                  The steppers do however work, I tried to home X and strangely all three axis moved all together. With the classical back 'n forth move of 10mm when no endstop is triggered.
                  Seems like I got a long day ahead of me tomorrow, going to unplug it all and try over. However everything seems in order.
                    I think you may want to have another crack at the online configurator and see if you can provide some more accurate details.
                    You can also post your config.g here along with a description of your printer details so we can point out what needs to be changed.
                    Perhaps this would be of help:
                    https://duet3d.dozuki.com/Wiki/Step_by_step_guide
                    https://duet3d.dozuki.com/Wiki/Going_from_Marlin_on_Arduino_to_RepRapFirmware_on_Duet
                    https://duet3d.dozuki.com/Wiki/BLTouch_Troubleshooting
                    https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter
                      dc42 administrators @Fizban
                      @fizban said in Maestro connection/guide halp!:
                      You have the endstop switch wired incorrectly. It's shorting +3.3v to ground when it is triggered.
                      Fizbanundefined 1 Reply Last reply Reply Quote 0
                      • Fizbanundefined
                        Fizban @dc42
                        @Phaedrux
                        Going through it all now. I'll post specs and config after my next attempt.
                        I might have, Man this board is nowhere what I'm used to work with 🙂
                        Im going through it again now, hopefully I can run a test later today.
                        Thanks
                        • Fizbanundefined
                          Fizban
                          Ok so I took it all apart and started over.
                          I got all my endstops working, I connected them side by side and not most two outer pins. My bad.
                          I even made my optical endstops working!
                          Bed and hotend heats up!
                          It homes and runs correctly in all directions!
                          Now to setup that BLtouch, but I see I'm not the only one having issues, but I'll take this elsewhere, for now 😉
                          Thanks all!
                            Phaedrux Moderator @Fizban
                            It's really not that bad.
                            Did you follow the setup guide?
                            https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
                            • Fizbanundefined
                              Fizban
                              @Phaedrux
                              Nah not yet, I have more important errors to look into as of now 🙂
                              Getting a new one and I see it's been up quite a few times!
                              I had a somewhat successful print last night. Massive over extrusion and skipping. I did the math wrong, I later realized that I forgot that I some weeks back went from 32 > 16 stepping on the extruder and forgot to take this into account.
                              Anyways, I'm now getting this error !
                              Fun fact I'm doing a test cube XYZ it lays down the first layer perfect, starts the second layer, does one round then it stops extruding and this comes up.
                              I did for a brief moment set a higher motor current, cause there's little to no holding power on the steppers. Im used to them being locked down and immoveable!
                              It shortly popped up on Driver2 but I somehow set the direction as reverse by mistake /shrug reverting this fixed it.
                              I checked Vin it's stable.
                              The drivers Arent hot, it extruders 10x100mm no problems
                              I wanted to try extruding on E1 instead of E0 but it wouldn't let me, I think put in the wrong code for it...
                                https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Tool_definition_section
                                That may help you to reconfigure your tool to use a different extruder drive.
                                Do you still get that error if you disconnect the motor and issue a movement command to the driver? If you no longer get the error that would hint that it is a wiring problem.
                                • Fizbanundefined
                                  Fizban @Phaedrux
                                  @phaedrux The thing is, it's not complaining till second layer. I can issue ten 100mm extrusions without issues.
                                    What firmware version are you using?
                                    I believe this thread may apply to your issue.
                                    https://forum.duet3d.com/topic/6607/frequent-short-to-ground-on-z-and-extruder
                                    You may need to upgrade to 2.02RC2 if you aren't already and tune your stealth chop / spread cycle setup.
                                    https://duet3d.dozuki.com/Wiki/Gcode#Section_M569_Set_motor_driver_direction_enable_polarity_and_step_pulse_timing
                                    • Fizbanundefined
                                      Fizban
                                      2.01beta I'll update and look into this. Thank you very much!
                                      • Fizbanundefined
                                        Fizban
                                        This can't be right.
                                        Besides it's cloning all my macros/Gcodes all the time. Trying to revert this lol
                                          @fizban what file did you use?
                                          • Fizbanundefined
                                            Fizban
                                            these
