    Tuning for smooth extrusion
    31
    3.5k
    • LHelgeundefined
      LHelge
      What type of extruder are you using? Is it geared? If so, are the gears running smooth?
      I have similar issues with a Zesty nimble, which is an issue that has been known for some time. (https://forum.zesty.tech/t/surface-effects-like-ripples-etc/186) It doesn't bother me much since i mainly print functional parts, bu I could see how some would be bothered by it.
      • gnydickundefined
        gnydick @LHelge
        @lhelge
        I'm using flexion extruders. They're not geared.
        • burtoogleundefined
          burtoogle
          If the extruder isn't geared, the steps/mm value is going to be quite low and, therefore, the resolution of the extruder is going to be low. I think this can cause quality issues, especially when using relative extrusion and made even worse if using 2.85mm filament.
          gnydickundefined 1 Reply Last reply Reply Quote 1
          • botundefined
            bot
            Increase your extrusion axis resolution dramatically and see if it goes away. Gear it down 3-5 times more than you are now.
            *not actually a robot
            • gnydickundefined
              gnydick @burtoogle
              @burtoogle my steps/mm are 183. It's not geared just like my prusa isn't geared, and my prusa prints literally perfect surfaces.
              • gnydickundefined
                gnydick @bot
                @bot said in Tuning for smooth extrusion:
                what do you mean by that? What is axis resolution?
                • botundefined
                  bot
                  Try using absolute extruder positioning rather than relative positioning.
                  I just mean your E steps/mm. X axis, Y axis, Z axis, E(xtrusion) axis -- at least in my mind.
                  With relative E positioning, you get underextrusion when steps/mm are low.
                  • gnydickundefined
                    gnydick
                    I turned on absolute extrusion and it started expelling really fast a lot of filament into big blogs every time there was a retraction.
                    adavidmundefined 1 Reply Last reply Reply Quote 0
                    • adavidmundefined
                      adavidm @gnydick
                      @gnydick
                      Did you re-slice the file using absolute extrusion too? If not then you need to.
                      • gnydickundefined
                        gnydick @adavidm
                        @adavidm yes, I did. Turns out, the duet wiki says not to use absolute as it's prone to compounding of rounding errors.
                        • gnydickundefined
                          gnydick
                          This photo shows a low poly model. There are two contiguous faces outlined. The edge between them, surrounded by the intersection of the squares is protruding from the part. The angle between the faces is very shallow. All of the edges on the model stick outb like that. Does that kind of artifact mean pressure advance is too low or too high?
                            dc42 administrators @gnydick
                            @gnydick said in Tuning for smooth extrusion:
                            XY jerk may be set too low, and pressure advance is probably too low as well.
                            • gnydickundefined
                              gnydick @dc42
                              @dc42 I tried all sorts of values and nothing worked. I was running around 100mm/sec actual speed. I cut it in half and it looks like the ripples have gone away, or at least reduced.
                              How do you think the speed is affecting it?
                                Using high speeds usually excites resonances more than using low speeds does. This effect shows up particularly well on flat surfaces downstream of sharp corners, such as when printing cubes and similar parts.
                                • gnydickundefined
                                  gnydick
                                  I was really tired, I kept lowering jerk instead of increasing it, so it kept getting worse. 😕
                                  • gnydickundefined
                                    gnydick
                                    Thanks for the help
                                      Glad to help! Is the problem solved?
                                      • gnydickundefined
                                        gnydick @dc42
                                        @dc42 it's definitely much better.
                                          So it was just a case of low x and Y jerk?
                                          • gnydickundefined
                                            gnydick @Phaedrux
                                            @phaedrux seems to be
