    Tuning for smooth extrusion
    31
    3.5k
    • botundefined
      bot
      Increase your extrusion axis resolution dramatically and see if it goes away. Gear it down 3-5 times more than you are now.
      *not actually a robot
      • gnydickundefined
        gnydick @burtoogle
        @burtoogle my steps/mm are 183. It's not geared just like my prusa isn't geared, and my prusa prints literally perfect surfaces.
        • gnydickundefined
          gnydick @bot
          @bot said in Tuning for smooth extrusion:
          what do you mean by that? What is axis resolution?
          • botundefined
            bot
            Try using absolute extruder positioning rather than relative positioning.
            I just mean your E steps/mm. X axis, Y axis, Z axis, E(xtrusion) axis -- at least in my mind.
            With relative E positioning, you get underextrusion when steps/mm are low.
            • gnydickundefined
              gnydick
              I turned on absolute extrusion and it started expelling really fast a lot of filament into big blogs every time there was a retraction.
              adavidmundefined 1 Reply Last reply Reply Quote 0
              • adavidmundefined
                adavidm @gnydick
                @gnydick
                Did you re-slice the file using absolute extrusion too? If not then you need to.
                • gnydickundefined
                  gnydick @adavidm
                  @adavidm yes, I did. Turns out, the duet wiki says not to use absolute as it's prone to compounding of rounding errors.
                  • gnydickundefined
                    gnydick
                    This photo shows a low poly model. There are two contiguous faces outlined. The edge between them, surrounded by the intersection of the squares is protruding from the part. The angle between the faces is very shallow. All of the edges on the model stick outb like that. Does that kind of artifact mean pressure advance is too low or too high?
                      dc42 administrators @gnydick
                      @gnydick said in Tuning for smooth extrusion:
                      XY jerk may be set too low, and pressure advance is probably too low as well.
                      • gnydickundefined
                        gnydick @dc42
                        @dc42 I tried all sorts of values and nothing worked. I was running around 100mm/sec actual speed. I cut it in half and it looks like the ripples have gone away, or at least reduced.
                        How do you think the speed is affecting it?
                          Using high speeds usually excites resonances more than using low speeds does. This effect shows up particularly well on flat surfaces downstream of sharp corners, such as when printing cubes and similar parts.
                          • gnydickundefined
                            gnydick
                            I was really tired, I kept lowering jerk instead of increasing it, so it kept getting worse. 😕
                            • gnydickundefined
                              gnydick
                              Thanks for the help
                                Glad to help! Is the problem solved?
                                • gnydickundefined
                                  gnydick @dc42
                                  @dc42 it's definitely much better.
                                    So it was just a case of low x and Y jerk?
                                    • gnydickundefined
                                      gnydick @Phaedrux
                                      @phaedrux seems to be
                                      • gnydickundefined
                                        gnydick
                                        So, I've tuned and upgraded my printer mechanics. It now prints BEAUTIFULLY. The layers are ridiculously identical. But I'm having a couple problems. Notice the two circled defects.
                                        The circles I print are all oblong or misshaped, though identical at all layers.
                                        The other area has a kink in the transition from the top radius to the vertical tangent edge. Again, identical at all layers.
                                        I can't seem to figure out how all straight lines are phenomenally consistent, but curves are so badly rendered.0_1541783588376_IMG_20181109_090709.jpg
                                        I printed a large cube with pressure advance slightly changed every 5mm and picked a setting that yielded the best overall square profile.
                                        • SupraGuyundefined
                                          SupraGuy
                                          Every time I've seen oblong circles, it's been a case of backlash in a movement axis. This was what finally did in my I3, when I could no longer get rid of backlash in the Y axis, I took it out of service.
                                          They're consistent layer for layer because the printer always goes around the circle in the same direction, usually anticlockwise around the perimeter. This means that it will still always start the straight line in the same place, but curves or changes in direction will be out, usually delayed along the axis that has the backlash problem.
                                          Lead screw driven printer, powered by Duet 2 Wifi
                                          MPCNC powered by Duet 2 Wifi
                                          CoreXY printer driven by Duet 3 6HC
                                          LowRider CNC powered by Duet 2 Wifi
                                          • gnydickundefined
                                            gnydick @SupraGuy
                                            @supraguy That makes sense, but I don't think that's the case here. I'm going to print super slow to see if it still happens.
