    Mesh Bed Compensation and Bed Leveling
    mesh compensation auto leveling
    4.2k
    • samlogan87undefined
      samlogan87
      Hi @dc42,
      Yes they do.
      Kind Regards,
      Sam
      Custom Core-XY
        samlogan87
        I forgot to mention I also re home the z axis after the auto bed leveling before I run the mesh compensation.
        Kind Regards,
        Sam
        Custom Core-XY
          That does seem odd. Can you arrange it so that the 4 points that you use for bed levelling correspond exactly to points on the mesh?
            samlogan87
            Hi @dc42
            Sure can. Will give it a go tonight when I get home from work.
            Kind Regards,
            Sam
            Custom Core-XY
              samlogan87
              Hi @dc42
              So I had a look at the actual maximum probing points for the mesh compensation and used them for the bed leveling.
              Here was the probing for the auto leveling:
              8:39:12 PMLeadscrew adjustments made: 0.001 -0.001 -0.000 -0.001, points used 4, deviation before 0.001 after 0.000
              8:38:44 PMLeadscrew adjustments made: -0.003 0.003 0.001 -0.001, points used 4, deviation before 0.004 after 0.000
              8:38:16 PMLeadscrew adjustments made: 0.156 0.148 0.154 0.151, points used 4, deviation before 0.153 after 0.000
              Here is the mesh height map:
              This was the results from doing auto leveling right after:
              9:14:34 PMLeadscrew adjustments made: -0.000 0.004 -0.002 -0.002, points used 4, deviation before 0.003 after 0.000
              9:14:07 PMLeadscrew adjustments made: -0.001 0.002 0.008 0.003, points used 4, deviation before 0.005 after 0.000
              9:13:39 PMG32
              Leadscrew adjustments made: 0.006 0.019 0.031 0.014, points used 4, deviation before 0.022 after 0.000
              I guess the points do line up other than maybe the second that was 0.01mm out. I am guessing some of the issues I am having could be attributed to the fact that there would be a compounding error over 342 x2 z movements as it probes every point twice?
              Kind Regards,
              Sam
              Custom Core-XY
                samlogan87
                Another quick question, do you have to specify a taper at all in the .config or does it default if you do not specify the M376 code? I have not had it in my config file.
                Kind Regards,
                Sam
                Custom Core-XY
                  If you probe repeatedly in the high-X high-y region (where the error appears to be greatest) using G30 S-1, do you get a consistent trigger height reading?
                  The default is that bed compensation is not tapered.
                    samlogan87
                    Hi @dc42
                    Thanks for that. I will give it a go.
                    So by not tapering, does that have an effect on the compensation? Or will it compensate over the entire height of the print?
                    Regards,
                    Sam
                    Custom Core-XY
                      Phaedrux Moderator @samlogan87
                      @samlogan87 said in Mesh Bed Compensation and Bed Leveling:
                      Exactly.
                        samlogan87
                        Hi @Phaedrux
                        Thanks for clarifying that. I just seem to have a few issues with consistency between mesh compensation results and auto leveling that I think is causing issues with my first layer being inaccurate.
                        Kind Regards,
                        Sam
                        Custom Core-XY
                        • SupraGuyundefined
                          SupraGuy
                          For almost any case like this, my first go-to for an explanation would be a machinist's straight edge. 0.1mm deviation over a couple hundred mm is practically impossible to see, but that straightedge should tell the real story. If you are getting incorrect reporting from the sensor, the first step is to determine if your sensor is wrong.
                          If your sensor is wrong, then the idea is to determine what rules (And there will be some) that determine HOW it is wrong. Sometimes certain portions of the bed have more compliance than others, particularly when your bed is spring mounted. Sometimes there is a sag or bow in axis rails, and though the bed isn't bent, the probe is correct. this is one of the things that a mesh probe can help correct for.
                          Lead screw driven printer, powered by Duet 2 Wifi
                          MPCNC powered by Duet 2 Wifi
                          CoreXY printer driven by Duet 3 6HC
                          LowRider CNC powered by Duet 2 Wifi
                            samlogan87
                            @SupraGuy
                            I did one more run last night of the mesh leveling and I want to do another one again tonight to confirm, but some of it could be a slightly bent Y axis (That is my moving carriage axis). I am still getting inconsistency in the mesh leveling which I am not overly sure why, hence the post.
                            Kind Regards,
                            Sam
                            Custom Core-XY
                              samlogan87
                              Well, I did another run and it is not a bent y axis. When I set it up, I had a few good nozzle digs into the bed and I am wondering whether somehow in doing so, it managed to put a slight bow in the center of the bed.
                              @dc42 When I run G30 S-1 with the piezo probe, it does not lift after probing and progressively digs harder into the bed. Not sure what I need to change to stop this. Even so at X 340 Y360 according to the mesh height map, the z value should be .197mm. When I probe it is 0.02mm.
                              Kind Regards,
                              Sam
                              Custom Core-XY
                                You need to raise the head by 5mm between each pair of G30 S-1 commands.
                                  samlogan87
                                  Hi @dc42
                                  I am sure I was doing that. I will have another go at it tonight.
                                  Kind Regards,
                                  Sam
                                  Custom Core-XY
