    Delta printer recommendation with Duet2
    3D Printing General Chat
    9
    10
    1.5k
    • toskiumundefined
      toskium
      Hello there,
      well, I am not sure where to post this so if a moderator would be kind enough to move it in the correct category if it is bothering.
      Since I finished my CoreXY machine recently I thought about building a Delta. Can some of the Delta Owners point me in the right direction where I can find information about "state of the art" Deltas?
      I am basically looking for a reliable workhorse which allows for functional printing at a reasonable speed, for configuration-consistency in my little printfarm I would very much love to drive it with a Duet2 board.
      Thanks!
        Some examples, in no particular order:
        • My own Kossel XL build, https://miscsolutions.wordpress.com/dc42s-large-kossel-build/
        • Ultibots DV300S, https://www.ultibots.com/d300vs-plus-3d-printer-diy-kit
        • SeeMeCNC Artemis, https://www.seemecnc.com/products/artemis-300
        • SeeMeCNC Rostock Max version 3.2, https://www.seemecnc.com/collections/3d-printers/products/rostockmax-v3-2-diy-kit-black
        HTH David
        • burtoogleundefined
          burtoogle
          I have a Duet controlled Kossel Mini that I built some years back using a kit from T3P3 in the UK. It's gone through some iterations but is printing nicer than ever now. Currently using an e3d v6 hot end and a Bondtech BMG extruder. Heated bed. It's compact and very quiet. I slung the Duet underneath.
            burtoogle
            I posted about the Duet conversion here:
            https://forum.duet3d.com/topic/1252/kossel-mini-upgrade
            • Danalundefined
              Danal
              At the moment, I have two Deltas containing Duet boards. And, yes, they are my "workhorses".
              • An Anycubic Kossel Linear that was converted. Details of conversion here (this is part 1, there are 7 parts)
              http://danalspub.com/2018/07/anycubic-kossel-linear-plus-to-duet3d-part-1/
              • A scratch built 600mm bed diameter (24") by 620Z printer. If you are interested in a scratch build, I will post more info, just ask.
              • garyd9undefined
                garyd9
                I'm certainly no delta expert, but answering some questions might help to point you in a particular direction:
                You indicated that you want to build the machine... Do you want to build from a kit where you're handed all the parts in a box and you assemble them, or would you prefer to individually source different parts from different vendors, cut them to size (if needed), etc?
                What do you consider a "reasonable speed"? As well, what level of quality are you expecting at that "reasonable speed"?
                What kinds of materials do you expect to print? In particular, are you wanting to print flexible filaments?
                What are you expectations in regards to differences between a delta and a coreXY?
                • AndreSundefined
                  AndreS
                  If you are up for an interesting delta design, take a look at this kickstarter campaign:
                  Zatsit Delta
                  Its a mechanical kit only.
                    T3P3Tony administrators
                    yeah I came by here to say consider the Zatsit!
                    • Ricky_Grade10undefined
                      Ricky_Grade10
                      Whatever you get, I'd recommend the Delta Smart Effector big time. Its probably smarter than me but I could still understand it for to say
                      • heapstarundefined
                        heapstar
                        ...now for something different.
                        NXD evo (RepRap forum in german language with some pictures and links)
                        NXD evo at work (Google video)
                        NXD evo CAD (Onshape)
                        Gruß
                        Niko
