    Zatsit printer
    3D Printing General Chat
    4.4k
      deckingman @Zatsit
      @zatsit Thanks for that. As I thought, it's not a simple process. Would you open to the idea of just supplying this part? I don't have a delta so the complete kit is of no interest to me. I would be needing batches of at least 6 and possible 12 at a time.
      Also, you didn't answer my second question which was how you cut the tube to length. If you don't want to answer that, I fully understand but if that is the case, could you supply shorted lengths of this tube?
      Zatsitundefined 2 Replies Last reply Reply Quote 0
      • Zatsitundefined
        Zatsit @deckingman
        @deckingman
        Yes, all accessories, including this adapter for Hot-end watercooling, are available independently of the Zatsit kit, during the campaign on Kickstarter, and then on the online shop that will follow.
        Take a look at the Kickstarter page, it says it all!
        To manufacture this adapter, I use a specially modified small lathe with a special saw to cut the tube straight, and without blurr.
        Creator of Zatsit, the delta printer with none assembly
        • Zatsitundefined
          Zatsit @deckingman
          @deckingman said in Zatsit printer:
          Probably.... What do you have in mind?
            deckingman @Zatsit
            @zatsit said in Zatsit printer:
            I'd rather not say at this time. As this is getting way off topic, is it OK if I PM you?
            Zatsitundefined 1 Reply Last reply Reply Quote 0
            • Zatsitundefined
              Zatsit @deckingman
              @deckingman
              Yes, of course.
              • RCarlyleundefined
                RCarlyle
                Now I am imagining very interesting uses for the tube... hmmm... 🙂
                • Zatsitundefined
                  Zatsit @RCarlyle
                  @rcarlyle
                  Yes, this small stainless steel tube, thus cooled, opens up a whole bunch of possibilities, which I am currently developing, and which I hope to be able to offer after Kickstarter.
                  1 - The volume of the Hot End can be divided by 5, and the weight reduced by 3, by directly integrating a miniature nozzle at the bottom of the tube. It is the tube+nozzle assembly that would become interchangeable, rather than the nozzle only.
                  2 - These miniaturized hot-ends make it possible to have a very light extrusion head, of the Direct/remote type, with two or four independent extrusion channels, but with a single drive motor, in the Flystruder position. I have already made a single-track version, which works extremely well.
                  Delta printers have great qualities, but they were generally limited by their single-channel Bowden tube. With 4 printable materials, you can imagine the possibilities!
                  • fmaundefined
                    fma
                    Congratulation for the successful campaign!
                    Frédéric
                    • keyz182undefined
                      keyz182
                      @Zatsit it would be cool if you could get an example config for the Duet out when you start shipping, so it can be added to https://configurator.reprapfirmware.org
                      Would make it a lot faster for us to get up and running with a known good config!
                      I just need to sell my CNC laser now so my wife isn't so mad when she hears I've got to pay for yet another successful Kickstarter 😮
                      3/3 Kickstarters backed and delivered so far, got my hopes up that this makes 4/4!
                      • Zatsitundefined
                        Zatsit @keyz182
                        @keyz182
                        Just after the end of the KS campaign, two new pages will appear on my website www.zatsit.fr : STORE and DOWNLOADS.
                        You will be able to download the configurations for the different systems I was able to try, including of course Duet WiFi.
                        • Zatsitundefined
                          Zatsit @T3P3Tony
                          @t3p3tony
                          Many thanks to all my backers, who allowed Zatsit to be born!
