    Requests for help: Gcode cam follower/ tangential knife control.
    62
    10.2k
    • Russ Griesundefined
      Russ Gries
      Thanks for the feedback everyone. I will reply to comments sooner than later I hope.
      In the meantime I decided to use a stepper motor directly as my tool end. This mainly to reduce any backlash and confusion between how many steps per revolution Ect. Right now I'm using an unknown stepper motor with a very large gear reduction which I cannot tune correctly. (I also re built it for bipolar). It also has a tremendous amount of backlash in the gears and renders it almost useless for this application. It's also not fast enough so I decided to dig through my Box of steppers and I found these really nice point 9゚ steppers. I ended up drilling a hole down the center and I'm going to attach my tool end directly on the shaft. This is a nema 17 which is quite large and heavy, but this is to prove the concept it will work, and because it was free in my bin of parts. 😉
      Yeah that hole sucked to drill... but i got it!!
      Here's a few photos
      I'll post more later
      Thanks
      ~Russ
      0_1539062048035_20181008_220825.jpg 0_1539062052439_20181008_220837.jpg 0_1539062056515_20181008_212958.jpg 0_1539062066110_20181008_220823.jpg
      One Day At A Time…
      My Main Research Page:
      http://rwgresearch.com/open-projects/3d-printing-research/
        Russ Gries
        Ok, still haven't had time to sit down and respond to posts... will do shortly.
        However i have managed to get this done.
        https://youtu.be/lqoa55_MOiY
        A proper video will be posted on my main YT when its time...
        ~Russ
        One Day At A Time…
          Russ Gries
          One step closer...
          https://youtu.be/2Jksxj-7JEM
          https://youtu.be/5zuiqzTgi_U
          But still alot to do.
          ~Russ
          One Day At A Time…
            Russ Gries @Danal
            @danal said in Requests for help: Gcode cam follower/ tangential knife control.:
            @russ-gries said in Requests for help: Gcode cam follower/ tangential knife control.:
            Also, are you able to make a simple script program that has an in interface for such a G code generator?
            Probably. Let me "check assumptions" on my end. Inputs to such a generator for "cylindrical" coil wraps would need to be:
            • Core diameter (what the wire would be wrapped around, even if removed post wrapping).
            • Core "length" or "height". In other words, first wrap at z=0 and last wrap at Z=this parameter.
            • Wire diameter
            • Number of layers
            • Packing - even or offset (see below)
            • Fudge factor for packing density. Could be called "tightness".
            What else?
            Even Packing:
            OOO   OOO
            OOO   OOO
            OOO   OOO
            OOO   OOO
            OOO   OOO
            OOO   OOO
            Offset Packing(would really be half spaced, characters will not show that properly)
            OOO    OOO
             OOO  OOO
            OOO    OOO
             OOO  OOO
            OOO    OOO
             OOO  OOO
            OOO    OOO
             OOO  OOO
            And, is there a need for "non cylindrical" winds? Donut/Torus or similar? Those are probably beyond a simple script. Examples:
                 OO    OO
                OOO    OOO
              OOOOO    OOOOO
             OOOOOO    OOOOOO
              OOOOO    OOOOO
               OOOO    OOOO
                 OO    OO
                 OO    OO
               OOO      OOO
             OOOO        OOOO
            OOO            OOO
             OOOO        OOOO
               OOO      OOO
                 OO    OO
            I will sendyou a PM and descuss this further!!
            Thanks
            ~Russ
            One Day At A Time…
              Russ Gries
              wow, that's all i have to say...
              https://www.youtube.com/watch?v=yPXUmXTCtok
              https://www.youtube.com/watch?v=aq7Zv-7jEf8
              ~Russ
              One Day At A Time…
                Russ Gries
                https://www.youtube.com/watch?v=QfoMRPy4bJk
                still a lot more to do... but its looking good.
                ~Russ
                One Day At A Time…
                  Russ Gries
                  47.5 AWG wire. about 1000 turns, 4.186 Kohms. That's a lot of resistance!
                  Its funny you cant even see the wire going in to the tool...
                  not to bad. got a bit of a slip there in the center.... more to tune still. also the roller play's a roll. Get it... ha,
                  on i'm slap happy...
                  0_1540575694883_20181026_082736.jpg 0_1540575699249_20181026_082745.jpg 0_1540575702929_20181026_093638.jpg 0_1540575707010_20181026_092932.jpg 0_1540575711000_20181026_093427.jpg
                  God Bless,
                  ~Russ
                  One Day At A Time…
                    Russ Gries
                    https://www.youtube.com/watch?v=jmNTSxDMqxM
                    One Day At A Time…
                      Nice! Anyone have any ideas of applications for flat coils? Wireless charging perhaps?
                        dc42 administrators @dc42
                        ...yes, wireless charging coils. See https://uk.farnell.com/w/c/passive-components/inductors/charging-coils/prl/results?st=wireless+charging+coils.
                        • Alexander Mundyundefined
                          Alexander Mundy
                          Off the top of my head, besides wireless charging: VLF radio. Magnetic radio for underground (cave, tunnel, etc) to surface communication. With larger gauge and some spacing, bed heat for a delta or polar, or induction heating. Metal detector coil.
                          • jot4pundefined
                            jot4p
                            Hi @Russ-Gries ,
                            Fantastic topic.
                            So, you use Duet3d wifi with RepRapFirmware correct ?
                            What is your gcode generator /slicer ?
                            You create a script to run your gcode and change the values ? Do you have more information about your post processor ?
                            Thanks
                              Russ Gries
                              Just about everything is documented on this playlist. :
                              https://www.youtube.com/playlist?list=PLsiIKXpZfLKI-UXGFdXYS2groWniI-Eh5
                              If you want to know why i built it. Its to build this:
                              https://youtu.be/ivPsGxCXyPA
                              And test some theories... 😉
                              ~Russ
                              One Day At A Time…
                              jot4pundefined 1 Reply Last reply Reply Quote 0
                              • jot4pundefined
                                jot4p @Russ Gries
                                @russ-gries
                                Yes, I follow you on YouTube 🙂
                                so, in this video you use Fusion 360, after that you use Simplify3D correct ? But you create a script to adjust the xyz to xyzU correct (U/A the angle of extruder 1), do you have some documentation ? or a start point for me (forum/ paper etc.. ?) I need to do the same for a concrete 3D printer.
                                I know that it is possible to do it automatically with Mach3 but I would like to try to do it myself.
                                At this moment I use Autodesk Inventor + PrinterRun (www.pronterface.com/) , it's possible to create scripts / macros with python to create the "final GCode".
                                My idea is change the rapms 1.4 (3d printer mainboard) by Duet3D and adjust this code to create the "tangential control" .
                                How do you adapt the Duet3D to create a U axis ? (the new "Extruder" axis ) ?
                                • resamundefined resam referenced this topic
                                • Phaedruxundefined Phaedrux referenced this topic
                                • demeundefined deme referenced this topic
