    Requests for help: Gcode cam follower/ tangential knife control.
    62
    10.2k
    • Russ Griesundefined
      Russ Gries
      wow, that's all i have to say...
      https://www.youtube.com/watch?v=yPXUmXTCtok
      https://www.youtube.com/watch?v=aq7Zv-7jEf8
      ~Russ
      One Day At A Time…
      My Main Research Page:
      http://rwgresearch.com/open-projects/3d-printing-research/
        Russ Gries
        https://www.youtube.com/watch?v=QfoMRPy4bJk
        still a lot more to do... but its looking good.
        ~Russ
        One Day At A Time…
          Russ Gries
          47.5 AWG wire. about 1000 turns, 4.186 Kohms. That's a lot of resistance!
          Its funny you cant even see the wire going in to the tool...
          not to bad. got a bit of a slip there in the center.... more to tune still. also the roller play's a roll. Get it... ha,
          on i'm slap happy...
          0_1540575694883_20181026_082736.jpg 0_1540575699249_20181026_082745.jpg 0_1540575702929_20181026_093638.jpg 0_1540575707010_20181026_092932.jpg 0_1540575711000_20181026_093427.jpg
          God Bless,
          ~Russ
          One Day At A Time…
            Russ Gries
            https://www.youtube.com/watch?v=jmNTSxDMqxM
            One Day At A Time…
              Nice! Anyone have any ideas of applications for flat coils? Wireless charging perhaps?
                dc42 administrators @dc42
                ...yes, wireless charging coils. See https://uk.farnell.com/w/c/passive-components/inductors/charging-coils/prl/results?st=wireless+charging+coils.
                • Alexander Mundyundefined
                  Alexander Mundy
                  Off the top of my head, besides wireless charging: VLF radio. Magnetic radio for underground (cave, tunnel, etc) to surface communication. With larger gauge and some spacing, bed heat for a delta or polar, or induction heating. Metal detector coil.
                  • jot4pundefined
                    jot4p
                    Hi @Russ-Gries ,
                    Fantastic topic.
                    So, you use Duet3d wifi with RepRapFirmware correct ?
                    What is your gcode generator /slicer ?
                    You create a script to run your gcode and change the values ? Do you have more information about your post processor ?
                    Thanks
                      Russ Gries
                      Just about everything is documented on this playlist. :
                      https://www.youtube.com/playlist?list=PLsiIKXpZfLKI-UXGFdXYS2groWniI-Eh5
                      If you want to know why i built it. Its to build this:
                      https://youtu.be/ivPsGxCXyPA
                      And test some theories... 😉
                      ~Russ
                      One Day At A Time…
                      jot4pundefined 1 Reply Last reply Reply Quote 0
                      • jot4pundefined
                        jot4p @Russ Gries
                        @russ-gries
                        Yes, I follow you on YouTube 🙂
                        so, in this video you use Fusion 360, after that you use Simplify3D correct ? But you create a script to adjust the xyz to xyzU correct (U/A the angle of extruder 1), do you have some documentation ? or a start point for me (forum/ paper etc.. ?) I need to do the same for a concrete 3D printer.
                        I know that it is possible to do it automatically with Mach3 but I would like to try to do it myself.
                        At this moment I use Autodesk Inventor + PrinterRun (www.pronterface.com/) , it's possible to create scripts / macros with python to create the "final GCode".
                        My idea is change the rapms 1.4 (3d printer mainboard) by Duet3D and adjust this code to create the "tangential control" .
                        How do you adapt the Duet3D to create a U axis ? (the new "Extruder" axis ) ?
                        • resamundefined resam referenced this topic
                        • Phaedruxundefined Phaedrux referenced this topic
                        • demeundefined deme referenced this topic
