    RepRapFirmware 2.02RC4 released
    Firmware installation
    18
    72
    8.2k
    • incogizmoundefined
      incogizmo
      @dc42 & @Veti ahhh awesome thanks guys so I was doing something wrong 🙂
      So I understand, on a button to launch a menu the file name is to be in both the A and L value? Or A"#0" preferably.
      Easily fixed! I'll update all my menus and switch back to rc4 thanks again for all your help 🙂
        dc42 administrators @incogizmo
        @incogizmo said in RepRapFirmware 2.02RC4 released:
        Having looked into it some more, I can see that the person who implemented my specification misread my intentions, and my supposed fix in 2.02RC4 has not helped. For now put "#0" in the A parameter and the menu filename in the F parameter. Don't start the menu name with letter G, M or T. This is a temporary workaround, and I will fix it properly in the 2.02 release.
        • GizmotronX5000undefined
          GizmotronX5000
          I'll likely update today!
          (This is a test post against the spam filter. I was getting automatically flagged last week.)
          • smoki3undefined
            smoki3
            @dc42 Hi,
            i noticed that M1 is calling "ause.g" instead of "pause.g". I think its a typo.
            Running RC4
              dc42 administrators @smoki3
              @smoki3 said in RepRapFirmware 2.02RC4 released:
              @dc42 Hi,
              Running RC4
              Are you sure? M1 should call sleep.g.
              fcwiltundefined smoki3undefined 2 Replies Last reply Reply Quote 0
              • fcwiltundefined
                fcwilt @dc42
                @dc42 said in RepRapFirmware 2.02RC4 released:
                M1 does do that - verified.
                If something is calling "ause.g" perhaps the P parameter was left off?
                  @fcwilt, what is your evidence that M1 is calling "ause.g"? Do you have a sleep.g file on your system?
                  • fcwiltundefined
                    fcwilt @dc42
                    I verified that M1 calls "sleep.g".
                    BUT I speculated that perhaps something (not M1) was executing a command "M98 pause.g", with the P parameter left off by mistake, thus yielding a call to "ause.g".
                    • smoki3undefined
                      smoki3 @dc42
                      @dc42 I get the message "ause.g" cant not found on my paneldue.
                      But maybe I found the issue. In my sleep.g It calls M98 pause.g instead of M98 Ppause.g
                        I don't see that message when I send M1 from PanelDue on my delta.
                        Do you have a sleep.g file, and if so, what is in it?
                          Updated firmware, DWC, and PanelDue to latest. Re did bed leveling routine and a mesh grid. Went smoothly. Ran a 15 hour print no issues.
                            dc42 administrators @Phaedrux
                            @phaedrux said in RepRapFirmware 2.02RC4 released:
                            Thanks for the feedback!
                            • frafaundefined
                              frafa
                              Hello
                              Same problem on 2.02RC4 for me
                              https://forum.duet3d.com/topic/7316/firmware-2-02-release-candidate-3-now-available/70
                              Scara with DuetWifi => Scarlette3D
                              https://youtu.be/mBF5cO8vGhI
                                dc42 administrators @frafa
                                @frafa said in RepRapFirmware 2.02RC4 released:
                                Hello
                                I'm sorry, I remember reading that post but somehow it didn't get added to my list of issues to investigate.
                                I've just reproduced that problem on my own SCARA by changing the homing file not to use the Z endstop. In my case, the reason is that I have a G1 XY move to position the arm just before the G30 move, and the firmware isn't allowing that move because the Z axis is not homed.
                                I will fix this in the 2.02 release. Meanwhile, a possible workaround is to use a G1 S2 XY move to set the arm positions to specified angles, instead of commanding a specified XY position.
                                • frafaundefined
                                  frafa
                                  Hi David,
                                  Homing ok if i add:
                                  ;Home Z ir-probe
                                  G91 ; Add test ...
                                  G1 S2 X1 Y-1 ; Add test ...
                                  G90 ; absolute movement
                                  G30 ; Single Z-Probe
                                  But test move after homing return error ...
                                  17:26:48
                                  G28
                                  17:25:46
                                  M120
                                  G91
                                  G1 Y10 F6000
                                  M121
                                  Error: G1/G2/G3: intermediate position outside machine limits
                                    I've implemented a fix in the source code, which will be included in 2.02RC5. Thanks for your patience.
                                    • frafaundefined
                                      frafa
                                      Thank you
                                      No problems David 1.21RC3 works perfectly in the meantime 🙂
                                      • insertnamehereundefined
                                        insertnamehere
                                        Previously I've been using M226 to pause prints by editing it into the gcode. I've just tried that on RC4 and although it paused, it also locked up and I was unable to continue the print. A power off was the only way to reset.
                                        M600 was doing the same thing in RC3.
                                        Anybody else experiencing this?
                                          We had a report of this one or two RC versions ago, but I was unable to reproduce it. I'll test it again. Please post your pause.g file here.
                                          insertnamehereundefined 1 Reply Last reply Reply Quote 0
                                          • garyd9undefined
                                            garyd9
                                            With RC4, DWC is still often reporting an incorrect current layer. In the attached/linked gcode file, there are 70 layers. DWC is reporting that layer 2 of 70 is currently being printed for many layers (I'm currently printing the 6th layer and it's still showing 2 of 70.)
                                            Slicer is cura 3.6.0 and adaptive layers is turned OFF. The "LAYER:xx" comments in the gcode file are correct.
                                            In the attached image, you can see Z is at 1.01 which corresponds to the 6th layer in the file, but DWC still thinks it's on layer 2 of 70 (search for "LAYER:5" in the gcode file (Cura layer numbers start with 0 in the gcode file.))
                                            gcode file: (google drive link) https://drive.google.com/open?id=1O-v-Pu1YvzgWd29iQmxBT9_bVLOqXol-
