    RepRapFirmware 2.02RC4 released
    Firmware installation
    18
    72
    8.2k
    • fcwiltundefined
      fcwilt @dc42
      @dc42 said in RepRapFirmware 2.02RC4 released:
      Are you sure? M1 should call sleep.g.
      M1 does do that - verified.
      If something is calling "ause.g" perhaps the P parameter was left off?
        @fcwilt, what is your evidence that M1 is calling "ause.g"? Do you have a sleep.g file on your system?
        • fcwiltundefined
          fcwilt @dc42
          I verified that M1 calls "sleep.g".
          BUT I speculated that perhaps something (not M1) was executing a command "M98 pause.g", with the P parameter left off by mistake, thus yielding a call to "ause.g".
          • smoki3undefined
            smoki3 @dc42
            @dc42 I get the message "ause.g" cant not found on my paneldue.
            But maybe I found the issue. In my sleep.g It calls M98 pause.g instead of M98 Ppause.g
              I don't see that message when I send M1 from PanelDue on my delta.
              Do you have a sleep.g file, and if so, what is in it?
                Updated firmware, DWC, and PanelDue to latest. Re did bed leveling routine and a mesh grid. Went smoothly. Ran a 15 hour print no issues.
                  dc42 administrators @Phaedrux
                  @phaedrux said in RepRapFirmware 2.02RC4 released:
                  Thanks for the feedback!
                  • frafaundefined
                    frafa
                    Hello
                    Same problem on 2.02RC4 for me
                    https://forum.duet3d.com/topic/7316/firmware-2-02-release-candidate-3-now-available/70
                    Scara with DuetWifi => Scarlette3D
                    https://youtu.be/mBF5cO8vGhI
                      dc42 administrators @frafa
                      @frafa said in RepRapFirmware 2.02RC4 released:
                      Hello
                      I'm sorry, I remember reading that post but somehow it didn't get added to my list of issues to investigate.
                      I've just reproduced that problem on my own SCARA by changing the homing file not to use the Z endstop. In my case, the reason is that I have a G1 XY move to position the arm just before the G30 move, and the firmware isn't allowing that move because the Z axis is not homed.
                      I will fix this in the 2.02 release. Meanwhile, a possible workaround is to use a G1 S2 XY move to set the arm positions to specified angles, instead of commanding a specified XY position.
                      • frafaundefined
                        frafa
                        Hi David,
                        Homing ok if i add:
                        ;Home Z ir-probe
                        G91 ; Add test ...
                        G1 S2 X1 Y-1 ; Add test ...
                        G90 ; absolute movement
                        G30 ; Single Z-Probe
                        But test move after homing return error ...
                        17:26:48
                        G28
                        17:25:46
                        M120
                        G91
                        G1 Y10 F6000
                        M121
                        Error: G1/G2/G3: intermediate position outside machine limits
                          I've implemented a fix in the source code, which will be included in 2.02RC5. Thanks for your patience.
                          • frafaundefined
                            frafa
                            Thank you
                            No problems David 1.21RC3 works perfectly in the meantime 🙂
                            • insertnamehereundefined
                              insertnamehere
                              Previously I've been using M226 to pause prints by editing it into the gcode. I've just tried that on RC4 and although it paused, it also locked up and I was unable to continue the print. A power off was the only way to reset.
                              M600 was doing the same thing in RC3.
                              Anybody else experiencing this?
                                We had a report of this one or two RC versions ago, but I was unable to reproduce it. I'll test it again. Please post your pause.g file here.
                                insertnamehereundefined 1 Reply Last reply Reply Quote 0
                                • garyd9undefined
                                  garyd9
                                  With RC4, DWC is still often reporting an incorrect current layer. In the attached/linked gcode file, there are 70 layers. DWC is reporting that layer 2 of 70 is currently being printed for many layers (I'm currently printing the 6th layer and it's still showing 2 of 70.)
                                  Slicer is cura 3.6.0 and adaptive layers is turned OFF. The "LAYER:xx" comments in the gcode file are correct.
                                  In the attached image, you can see Z is at 1.01 which corresponds to the 6th layer in the file, but DWC still thinks it's on layer 2 of 70 (search for "LAYER:5" in the gcode file (Cura layer numbers start with 0 in the gcode file.))
                                  gcode file: (google drive link) https://drive.google.com/open?id=1O-v-Pu1YvzgWd29iQmxBT9_bVLOqXol-
                                    dc42 administrators @garyd9
                                    @garyd9 said in RepRapFirmware 2.02RC4 released:
                                    I think this line, just before the "end of prime line" comment, is confusing the firmware:
                                    G1 X34.441 Y-145.764 Z4.2 E0 F9000
                                    Because it contains both XY movement and extrusion, the firmware classifies it as a printing move, and it therefore thinks that you have completed the print up to Z=4.2. It is waiting for an extruding move at a greater Z height before it counts another layer.
                                    garyd9undefined 1 Reply Last reply Reply Quote 0
                                    • Martin1454undefined
                                      Martin1454
                                      @dc42 Im trying to update my bed.g to support the latest release.
                                      I use 3 independent lead screws, and your IR probe.
                                      My old bed.g file was:
                                      ; bed.g
                                      ; generated by RepRapFirmware Configuration Tool on Tue Jul 31 2018 15:05:50 GMT+0200 (Centraleuropæisk sommertid)
                                      G28 Z;
                                      G29 S2; Clear bed height map
                                      ; Probe the bed at 3 points
                                      G30  P0 X0 Y160 Z-9999 ; Front Right
                                      G30  P1 X320 Y47 Z-9999 ; Front Left
                                      G30  P2 X320 Y280 Z-9999 S3 ; Center Rear
                                      I can now see that a tool have to be selected, but do I also have to use 1 of the S-* parameters? If so, how?
                                        I can't think of any reason why you would need to change the bed.g file for the latest release. You should not need to have a tool selected. You do need to have homed X and Y as well as Z, so you might want to change the G28 Z command to just G28.
                                        BTW, M561 and G29 S2 do the same thing.
                                        Martin1454undefined 1 Reply Last reply Reply Quote 0
                                          Martin1454 @dc42
                                          @dc42 Well, I get an "homing error" when the it is done probing the 3 points and returning to X0 Y0
                                          I home in my X and Y in the homeall.g and Z in bed.g
                                          Here is my home all:
                                          M400; make sure everything has stopped before we make changes
                                          M574 X1 Y1 S3		;
                                          M913 X30 Y30 		; XY motors to 30% current
                                          M915 X Y H400 S3 R0 F0	; set X and Y to sensitivity , do nothing when stall, unfiltered
                                          ; X axis home
                                          G91			; use relative positioning
                                          G1 Z5 F6000 S2    ; lift Z relative to current position
                                          G1 S1 X-405 F6000 ; move quickly to X axis endstop and stop there (first pass)
                                          G1 X5 F6000       ; go back a few mm
                                          G1 S1 X-405 F4000  ; move slowly to X axis endstop once more (second pass)
                                          ; Y axis home
                                          G1 S1 Y-305 F6000 ; move quickly to Y axis endstop and stop there (first pass)
                                          G1 Y5 F6000       ; go back a few mm
                                          G1 S1 Y-305 F4000  ; move slowly to Y axis endstop once more (second pass)
                                          G90               ; absolute positioning
                                          M913 X100 Y100; motor currents back to 100%
                                          ; Z-axis
                                          M561                     ; Clear any bed transform
                                          G32                      ; Start 3-point probe sequence - Bed.g
                                          ;M375 P"bareplate.csv"    ; Load heightmap
                                          G1 Z20.0 F6000           ; Move Z to 20
                                          G1 X5 Y5    		 ; Move Head to front left
                                          • resamundefined
                                            resam
                                            @deckingman said in RepRapFirmware 2.02RC4 released:
                                            I do still get a short "double blip" of the hot end fan when booting but it's much much shorter and the overall boot up time seems to be faster.
                                            I think I always had this double blip - see my video (listen to the audio!)
                                            https://www.dropbox.com/s/tz5n8j4xaparicd/fan-double-blip.mp4?dl=0
                                            Also take a look at my reconnect time of the PanelDue.
                                            DuetWifi 2.02RC4 + PanelDue 1.22.1
                                            @dc42 is this normal behaviour - or do you suspect something is wrong?
