    Magnetic vs Laser filament monitor
    Filament Monitor
    1.8k
    • fmaundefined
      fma
      Did you see this design?
      https://www.thingiverse.com/thing:3241561
      Frédéric
      brunofportoundefined Mr Yodundefined 2 Replies Last reply Reply Quote 0
      • timcurtis67undefined
        timcurtis67
        Yeah I saw that one a little while ago. There is an even nicer one that uses a smaller flange bearing. The flange runs against the filament and the sensor watches the flange. I am in the process of designing a housing with the bearing approach to see how it works.
        My plan it to use a small o-ring on the bearing that the filament will run against for better grip with less pressure on the bearing and filament. Then have the filament monitor board watch the other side of the flange for motion. I guess they read the stainless steel surface of the bearing pretty well. Time will tell.
        • brunofportoundefined
          brunofporto @fma
          @fma said in Magnetic vs Laser filament monitor:
          I was going to try that with the Duet3D LFM but was planning to use two bearings!!! A magnet is MUCH better 😄
          Thank you for the inspiration 😄
          • fmaundefined
            fma
            Instead of a simple bearing, I would like to use a MK7 gear. Such like https://www.ebay.fr/itm/Feedstock-Wheel-Extruder-Gear-Drive-RepRap-3D-Printer-1-75mm-Pignon-5mm/182601677691, so there is a good grip. But there are 2 issues:
            • there is a ratio between the filament move and what the sensor reads; This requires this ratio to be set in the firmware. I think this is not something difficult to do, adding a param to the relevant M-Code.
            • the screw is on the sensor path 😞
            Any idea of a better gear to address the second issue?
            Frédéric
            timcurtis67undefined brunofportoundefined 2 Replies Last reply Reply Quote 0
              timcurtis67 @fma
              I'm looking for the path of least resistance in my design. I don't want the drag of a heavy geared hob. I'm not saying it won't work, I believe the more attempts to create different version is better in the long run for everyone.
              • botundefined
                bot @timcurtis67
                @timcurtis67 Something like this might be good, too. It's a plain bearing with a silicone or urethane coating of variable hardness and colour. https://us.misumi-ec.com/vona2/detail/110300423960/?CategorySpec=00000030014%3A%3Aa unitType%3A%3A1&Inch=0
                *not actually a robot
                timcurtis67undefined 1 Reply Last reply Reply Quote 0
                  timcurtis67 @bot
                  @bot Yep, that would work as well.
                  • fmaundefined
                    fma
                    It seems that the detection of the laser sensor is optimized for steal...
                    Frédéric
                    • botundefined
                      bot
                      Stainless steel, yes. However, we've been trying to get it working with a mix of materials. Having a consistent material that works is all that matters, and that specific product offers a variety of choices (4, really). If none of those work, I suppose you could try a plain bearing, but then you cannot be sure that the bearing is being driven by the filament at all times. Silicone or urethane coating would help with grip, without having a hobbed idler that may damage the filament.
                      I would personally choose a hobbed gear like a bondtech with a very fine tooth pattern, as to not damage the filament. I suggested the misumi bearings as an alternative to anyone looking to try something else.
                      • Mr Yodundefined
                        Mr Yod @fma
                        LOL: it's laser AND magnetic! 😃
                        It still seems similar with the one I linked (and the others linked in that thingiverse page).
                        But my question (that I forgot to address in the OP and that bot reminded me) is: is this system with laser sensor on a bearing reliable?
                          brunofporto @fma
                          @fma I was going to cover the bearing surface with something.... But I would test it first as bare bearing... As there is nothing to resist the movement.....
                            timcurtis67 @Mr Yod
                            @mr-yod said in Magnetic vs Laser filament monitor:
                            I believe it is but we will find out soon enough. There will probably be a few versions built shortly.
