Magnetic vs Laser filament monitor
@fma said in Magnetic vs Laser filament monitor:
Did you see this design?
I was going to try that with the Duet3D LFM but was planning to use two bearings!!! A magnet is MUCH better
Thank you for the inspiration
Instead of a simple bearing, I would like to use a MK7 gear. Such like https://www.ebay.fr/itm/Feedstock-Wheel-Extruder-Gear-Drive-RepRap-3D-Printer-1-75mm-Pignon-5mm/182601677691, so there is a good grip. But there are 2 issues:
there is a ratio between the filament move and what the sensor reads; This requires this ratio to be set in the firmware. I think this is not something difficult to do, adding a param to the relevant M-Code.
the screw is on the sensor path
Any idea of a better gear to address the second issue?
I'm looking for the path of least resistance in my design. I don't want the drag of a heavy geared hob. I'm not saying it won't work, I believe the more attempts to create different version is better in the long run for everyone.
@timcurtis67 Something like this might be good, too. It's a plain bearing with a silicone or urethane coating of variable hardness and colour. https://us.misumi-ec.com/vona2/detail/110300423960/?CategorySpec=00000030014%3A%3Aa unitType%3A%3A1&Inch=0
@bot Yep, that would work as well.
It seems that the detection of the laser sensor is optimized for steal...
Stainless steel, yes. However, we've been trying to get it working with a mix of materials. Having a consistent material that works is all that matters, and that specific product offers a variety of choices (4, really). If none of those work, I suppose you could try a plain bearing, but then you cannot be sure that the bearing is being driven by the filament at all times. Silicone or urethane coating would help with grip, without having a hobbed idler that may damage the filament.
I would personally choose a hobbed gear like a bondtech with a very fine tooth pattern, as to not damage the filament. I suggested the misumi bearings as an alternative to anyone looking to try something else.
LOL: it's laser AND magnetic!
It still seems similar with the one I linked (and the others linked in that thingiverse page).
But my question (that I forgot to address in the OP and that bot reminded me) is: is this system with laser sensor on a bearing reliable? -
@fma I was going to cover the bearing surface with something.... But I would test it first as bare bearing... As there is nothing to resist the movement.....
@mr-yod said in Magnetic vs Laser filament monitor:
But my question (that I forgot to address in the OP and that bot reminded me) is: is this system with laser sensor on a bearing reliable?I believe it is but we will find out soon enough. There will probably be a few versions built shortly.
