    Firmware 2.02RC5 now available
    Firmware installation
    14
    47
    6.8k
      No issues noted thus far.
      • 3dmntbighkerundefined
        3dmntbighker
        Seemed to work last night.
        Scratch built CoreXY with Maestro
        Heavily modified Ender 3 with Maestro
        MPCNC work in progress with Duet WiFi
        • zzingundefined
          zzing
          9:45:28 PM
          Finished printing file 20mm_cube.gcode, print time was 0h 34m
          9:44:42 PM
          Error: Internal Error in Read at ../src/Storage/FileStore.cpp(281)
          Error: Internal Error in Close at ../src/Storage/FileStore.cpp(148)
          9:11:28 PM
          M290 S-0.05
          9:11:05 PM
          M32 "20mm_cube.gcode"
          File 20mm_cube.gcode selected for printing
          This is the only issue I have noticed with RC5.
            dc42 administrators @zzing
            @zzing said in Firmware 2.02RC5 now available:
            9:45:28 PM
            9:44:42 PM
            9:11:28 PM
            M290 S-0.05
            9:11:05 PM
            Have you any idea what provoked the Internal Error messages? I presume you didn't remove the SD card before the print finished?
            • frafaundefined
              frafa
              Hi David
              Test 2.02RC5 on my Scara
              Homing ok 🙂 --> oup's ko 😞
              But after homnig absolute movement return error
              possible move just on relative movement ...
              Move on G90 impossible ...
              G90 ; absolute movement
              G1 Y0 X0 F1000
              Error: G1/G2/G3: intermediate position outside machine limits
              UPGRADE ...
              David if i remove G1 S2 X1 Y-1; on my homeall.g before G0 I always have the same error as on the versionn 2.02RC4 brief G30 does not work and homig is wrong ...
              ; Home Z ir-probe
              G91; Add test ...
              G1 S2 X1 Y-1; Add test ...
              G90; absolute movement
              G30; Single Z-Probe
              In short on scara I have the same concerns as on version 2.02RC4
              Scara with DuetWifi => Scarlette3D
              https://youtu.be/mBF5cO8vGhI
              • giostarkundefined
                giostark
                I'm still facing the perfect ,or more possible accurate ,calibration. And in the meanwhile I discovered a bug.
                If I use the microstep 0.05 from the WC by pressing the Z-Baby stepping button, before or after a manual extrusion always from the WC ,the printer replicate the same extrusion as an other manual input (see picture ) . If this happen when the filament is near the nozzle occur the muse bite because the gears run faster the capability of the nozzle to release the material . (this because the manual extrusion for load the filament is done fast - my printer have near 15cm between the nozzle and the extruder gear)
                I can reproduce this as many time I want.
                • k3lagundefined
                  k3lag
                  Working fine on my dual idex bigbox
                    dc42 administrators @giostark
                    @giostark said in Firmware 2.02RC5 now available:
                    Thanks for reporting this, it's on my list to investigate.
                    • Gone2Farundefined
                      Gone2Far
                      Working fine on homebrew kossel.
                      Original Prusa i3 MK2S
                      Large Kossel Homebrew
                      • zzingundefined
                        zzing
                        @dc42 correct, no pulling of SD. There really wasn't anything I was doing directly, except for being in proximity to it.
                          dc42 administrators @frafa
                          @frafa said in Firmware 2.02RC5 now available:
                          Are you certain that X0 Y0 is accessible in a straight line from the initial position? What happens if you use G0 instead of G1?
                          This is the homeall.g file on my SCARA:
                          ; Home All file for Robotdigg SCARA arm printer
                          M561			; cancel bed compensation
                          G91
                          G1 S2 Z28 F1000		; raise Z to keep nozzle clear of base frame
                          G1 S1 X200 Y200 F1000	; home proximal and distal arms
                          G1 S2 X-5 Y-5 F1000	; back off
                          G1 S1 X10 Y10 F200	; repeat the homing more slowly
                          G90
                          G1 X-75 Y75 F3000	; move to a position that correspond to one of the M557 grid points
                          G30			; home Z
                          G1 Z28 F1000		; move to safe height again
                          G29 S1			; load height map
                            dc42 administrators @dc42
                            @dc42 said in Firmware 2.02RC5 now available:
                            I confirm this issue. It will be fixed in 2.02RC6.
                            • Danalundefined
                              Danal
                              Installed and working on a Larg-ish delta (600mm x 600mm). No issues found so far. Have done a couple of prints, one of them about six hours.
                              And... this did clean up the HTTP line ends (reported in a separate thread, now marked resolved).
                              • resamundefined
                                resam
                                Some odd behaviour during pause & resume:
                                I have this in my resume.g:
                                G1 R1 X0 Y0 Z3 F6000     ; return to point previously paused at (but above it)
                                G1 R1 X0 Y0 Z0 F180      ; return to point previously paused at (lower nozzle)
                                G1 R1 X0 Y0 Z3 actually moves to X0 and Y0 - instead of the "last saved point".
                                Then it move 3mm down.
                                Then it seems to continue to the correct "last saved point" location (not sure if this is still from with resume.g or already the next commanded move from my print code).
                                Now it obviously crashes because the nozzle is too low.
                                This is repeatable. Print something for a few minutes. Pause. (I usually do a filament change or clear a heat-creep and command some manual extrusion to prime the nozzle). The Resume. Then crash (if I'm not quick enough with the E-stop).
                                I might have tweaked my config - but I don't see anything obvious in my version-controlled config files...
                                @dc42 Should G0 R1 X0 Y0 behave the same as G1 R1 X0 Y0?
                                edit: I just flashed RC4 again - and the problem is gone. So this is a regression in RC5.
                                • frafaundefined
                                  frafa
                                  @David
                                  I have exactly the same problems as with version 2.02RC3
                                  https://forum.duet3d.com/topic/7316/firmware-2-02-release-candidate-3-now-available/70
                                  tested with your homing.all file adapted to my config, the same errors ...
                                  Downgrade 1.21RC3 waiting ...
                                    dc42 administrators @resam
                                    @resam said in Firmware 2.02RC5 now available:
                                    Strange, nobody else has reported this and I have similar lines in resume.g. I will test it again.
                                    RRF restores the last print position automatically immediately before resuming. Using G1 R1 commands is optional, and allows you to control how it is done. G0 R1 should behave the same as G1 R1 except that on some machines (e.g. SCARA) the movement may not be linear.
                                    resamundefined 1 Reply Last reply Reply Quote 0
                                    • resamundefined
                                      resam @dc42
                                      @dc42 I have a corexy. With RC4 it works as expected. RC5 moves to the wrong position.
                                      I suspect the G53&G54 changes might have introduced a bug?
                                        Were you using workplace coordinate offsets when this happened?
                                        • resamundefined
                                          resam @dc42
                                          No - I'm running in a simple plain FFF mode as 3D printer.
                                          I do not have any G53 or G54 codes in my sys/ or macros/ files.
                                            Thanks. Are you using any G10 tool offsets?
                                            EDIT: or M206 offsets?
