    Configuring 12864 LCD on Maestro?
    79
    23.9k
    • Agniusmundefined
      Agniusm @arnd13
      @arnd13 thought i read somewhere that command is not necessary, well, great news then.
      • Agniusmundefined
        Agniusm @arnd13
        @arnd13
        Just tried wiring it according to your pinout and its still blank. I updated firmware to 2.02RC5.
        Does M918 goes to config.g?
        Where did you get your menu files? Should not make a difference bu still...
          deckingman @dc42
          @dc42 said in Configuring 12864 LCD on Maestro?:
          Thanks! May I add your diagram to the wiki documentation?
          Is that wise? Given that this is another clone? Can you be sure that the pinouts are the same as an original?
          Agniusmundefined 1 Reply Last reply Reply Quote 0
          • Agniusmundefined
            Agniusm @deckingman
            @deckingman said in Configuring 12864 LCD on Maestro?:
            e same a
            Mine is clone until i fry it and make it all good.
            @arnd13 may have genuine, i dont know.
            I have just made jumper wires and wend wire by wire but its still blank. It might be clone pinout as deckingman mentioned, have no clue.
            • Agniusmundefined
              Agniusm
              I went poking wires all over and can confirm it is working now. Pinouts given by @arnd13 did not match. I have tested Reparapdiscount display which came in at the time i was doing this today. It worked strait out of the box so clone maestro pinouts for LCD and SD(confirmed) are correct.
              If you like to add it to wiki here is wiring diagram i made. Cheers
              0_1543846754679_wiring.jpg ,
              arnd13undefined 1 Reply Last reply Reply Quote 2
              • arnd13undefined
                arnd13 @dc42
                @dc42 Yes, no problem.
                • arnd13undefined
                  arnd13 @Agniusm
                  @agniusm That's fine. The only difference ist that LCD_CS (EXP1) and SPIO_CS0 (EXP2) are swapped.
                  Strange but my Display is working too ๐Ÿ™‚
                  My configuration is original ENDER-3 (no PRO) with display like shown above.
                  arnd13undefined 1 Reply Last reply Reply Quote 0
                  • arnd13undefined
                    arnd13
                    Now I'm playing around with the display files (absolute beginner) and found something strange.
                    I tested the examples from here https://duet3d.dozuki.com/Wiki/Duet_2_Maestro_12864_display_menu_system
                    and the linked files from CraneQuadMenuFiles here https://forum.duet3d.com/post/68888
                    With both configuration submenus could not be opened/started. I realized that it must be the "menu" entry in the files. For example:
                    button R15 C5 F0 T"Temperature ยป" A"menu" L"x_temp"
                    ist NOT working.
                    button R15 C5 F0 T"Temperature ยป" A"menu x_temp" L"x_temp"
                    is WORKING.
                    I edited the whole "menu xx" entries in the CraneQuadMenuFiles in the same way as above and now the menus are working.
                    Am I thinking wrong or is it necessary to add the corresponding filename in the "menu" entry?
                    russellundefined 1 Reply Last reply Reply Quote 0
                    • arnd13undefined
                      arnd13 @arnd13
                      @arnd13 said in Configuring 12864 LCD on Maestro?:
                      I made a short test and can confirm:
                      Swapping LCD_CS (EXP1) and SPIO_CS0 (EXP2) makes no difference. Both possibilities are working ๐Ÿ™‚
                      But the diagram with photos from @Agniusm looks better ๐Ÿ‘
                        Does the Ender with the original electronics have anything connected to the EXP1 and EXP2 connectors? I am wondering whether those connectors might duplicate the pins on EXP3 but in a manner compatible with the RepRapDiscount display. You could use a multimeter to check whether the pins on EXP3 are also connected to EXP1 and EXP2, and if so what the pinout is.
                        • arnd13undefined
                          arnd13
                          The Ender display has 3 connectors EXP 1 to EXP 3. Some of th pins of EXP 1 and EXP 3 are named.
                          EXP 1 from the pcb side:
                          EXP 3 from the pcb side:
                          Some pins are have the same signals. EXP 2 has no named pins.
                          Maybe it's possible to use 2 standard 10pin cable to connect EXP 1-3 from the Display to Maestro EXP 1 and EXP 2. But until now I didn't have the time to measure and check if it's possible. I'll try to do the next days.
                          • Agniusmundefined
                            Agniusm
                            I can check pinout. I know that exp2 does not work with duets exp2. It probably shorts as leds go out
                            • arnd13undefined
                              arnd13
                              Maybe 2 cables (10 pin). EXP 1 LCD to EXP 1 Maestro and EXP 3 LCD to EXP 2 Maestro.
                              EXP 1 LCD to EXP 1 Maestro is almost perfect. We only have to check wether Beep and ENC_SW is on EXP 1 LCD.
                              • Agniusmundefined
                                Agniusm
                                Here if if i did not missbeeped something
                                • russellundefined
                                  russell @arnd13
                                  @arnd13 Hi thank you (i am an absolute beginner as well) this has solved my problem you have got my screen working now i just have to refine it
                                  Thank's again
                                  • Agniusmundefined
                                    Agniusm @arnd13
                                    @arnd13
                                    Looks like vcc, gnd, buzz and enc_sw will work on exp1, you only need to cut slot in lcd connector and flip ribbon cable?! I will try that.
                                    Another way is just to cut ribbon cable and crimp dupont pins, then use connectors found on pc for power,hdd, reset. They come in multiple sizes and could be salvaged
                                    3dmntbighkerundefined 1 Reply Last reply Reply Quote 0
                                    • Agniusmundefined
                                      Agniusm
                                      @dc42 @arnd13 I can confirm that display works on EXP1. You need to cut a slot to opposite side of the LCD EXP1 and insert the ribbon cable "the wrong way". Further more if you cut slot on EXP2 on LCD and insert ribbon cable "the wrong way" and connect it to DUET Maestro EXP2, you will have fully functional LCD.
                                      Only encoder will be reversed.
                                      Wow, the trouble i went through crimping those cables when i only needed to cut out 2 slots...
                                      P.S. Probably i was too quick with the post. Weird, but when duet is powered through USB, everything works but when through power terminals the display is blank.
                                      Never mind, had it disabled in config.
                                      So you dont have to enable it in config if its powered by USB but you do when it is power through power terminals
                                      • Agniusmundefined
                                        Agniusm
                                        I tried using menu from @Greg3D , i think and it would not go into menu items so i edited main file and now its working. Attached menu
                                        0_1543946960070_Maestro_Menu.gcode
                                        Did not let to attach .zip, rename .gcode extension to .zip
                                        • arnd13undefined
                                          arnd13
                                          I also used those menu files and had to edit them. Menus are only for the base functions but a good base to extend with additional functions.
                                          A mix between those files and the CraneQuadMenuFiles would be the best solution.
                                          • 3dmntbighkerundefined
                                            3dmntbighker
                                            Whew, ok.. pretty confusing thread. I'm ready right now to connect the Maestro to my stock Ender 3 Pro display. Do we have consensus on what needs to be done? If the the display is standard off the shelf used by Creality why is flipping the cable necessary? Do we actually need two cables? Is the encoder finally reversed when all is wired, or is there a way to correct that? The info I found is pretty limited on schematics. What connectors should be used on the Maestro end, and the display end?
                                            Scratch built CoreXY with Maestro
                                            Heavily modified Ender 3 with Maestro
                                            MPCNC work in progress with Duet WiFi
