[Problem] Homing Z works with Macro but not with Home Buttons
z probe homez homing npn sensor macro
2.3k
    deckingman @Tommy_Fr
    @tommy_fr You can use whatever commands you like in homez and homeall. You don't have to use G30. If your test macro works fine, then just use those commands in homez and homeall.
      Can you post the contents of your test homing macro?
      You can do as Deckingman says and just replace your homing files with the contents of that test macro, but that won't help you if you ever want to use G30 elsewhere, say for mesh grid bed leveling, etc.
      You may want to review the information here: https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
        Tommy_Fr
        Thank you both for your answers.
        I replaced homez.g and homeall.g Z probe command G30 with Macro_01 file command G1 S1 Z3200 F9000 (I just deleted Xnnnn Ynnnn). It now works.
        @phaedrux said in [Problem] Homing Z works with Macro but not with Home Buttons:
        Here it is:
        0_1544630685917_01-Test_IR_PD_Homing.g
        Printer: FLSun I3 C_Plus
        Board: Duet Wifi 1.04
          Which firmware version?
            Tommy_Fr
            Firmware Electronics: Duet WiFi 1.04 (bought from one of the official Duet suppliers)
            Firmware Version: 2.01(RTOS) (2018-07-26b2)
            WiFi Server Version: 1.21
            Web Interface Version: 1.21.2-dc42
              kazolar
              I have a fairly complex home z operation, so I put all of it in homez.g and then I call that from homeall.g -- that's simple -- in fact in my homeall.g I simply have
              M280 P5 S160
              G91
              G1 Z4 F200 S2
              M98 Phomeaxis.g
              G90
              M98 Phomez.g
              so I can make whatever adjustments I need in each script for doing homing
                Tommy_Fr
                I noticed what you said @kazolar .
                I fixed toward direction for my Z axis to be rightful and easier to understand. It now goes in right direction (forward goes up, with Z increasing).
                When I use G30, G30 S-1 or G30 S-2, movement is in the wrong direction (so upward instead of downward); before the toward change for my Z axis it was going downward.
                So G30 direction and stop while probe is triggering does not work.
                undefined 1 Reply Last reply 15 Dec 2018, 15:12 Reply Quote 0
                  dc42 administrators @Tommy_Fr
                  @tommy_fr said in [Problem] Homing Z works with Macro but not with Home Buttons:
                  Increasing positive Z must be the nozzle moving upwards or the bed moving downwards, so that the Z coordinate is the height of the nozzle above the bed.
                    Tommy_Fr
                    Yes, it was what I meant. Sorry if my english was incorrect. The nozzle is moving upwards with increasing positive Z.
                    undefined 1 Reply Last reply 15 Dec 2018, 17:55 Reply Quote 0
                      In that case, I don't understand how G30 commands can be moving in the wrong direction; except that some variations of G30 command move the nozzle t the dive height (M558 H parameter) first, and all G30 commands move the nozzle back to the dive height after probing.
                      Have you tested the Z probe as described at https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe ?
                        Tommy_Fr
                        M558 H parameter was H5, I have changed it to 1 to try, and there is no difference.
                        Yes, I have tested Z as described at https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe.
                        But I wonder if there is a scale issue, because on DWC I have that for machine control:
                        It is normal X and Y lines have different values from Z line.
                        And when I click, for example, on Z+5, nozzle moves five times more longer away than on X+10.
                        So, is there a scale issue?
                        UPDATE: I edited my config.g file and changed Z steps per mm which was totally wrong (I set a M5 lead screw system instead of a M8, but value was still incorrect, changing from 4000 to 2560, I finally changed it to 400 which seems to be right or close of the rightful value). Z line on DWC did not change but movement matches more with the first both lines, X and Y.
                          So does Z homing work now?
                          undefined 1 Reply Last reply 18 Dec 2018, 07:36 Reply Quote 0
                            Tommy_Fr @dc42
                            @dc42 said in [Problem] Homing Z works with Macro but not with Home Buttons:
                            I just tried with g30 and it seems to work now. I will do further tests in the few coming day.
                              Tommy_Fr
                              I tested it within several ways, which with bed compensation and it works great.
                              Thank you to @dc42.
                              You can mark it as solved.
