[Problem] Homing Z works with Macro but not with Home Buttons
z probe homez homing npn sensor macro
2.3k
    Tommy_Fr
    Thank you both for your answers.
    I replaced homez.g and homeall.g Z probe command G30 with Macro_01 file command G1 S1 Z3200 F9000 (I just deleted Xnnnn Ynnnn). It now works.
    @phaedrux said in [Problem] Homing Z works with Macro but not with Home Buttons:
    Can you post the contents of your test homing macro?
    Here it is:
    0_1544630685917_01-Test_IR_PD_Homing.g
    Printer: FLSun I3 C_Plus
    Board: Duet Wifi 1.04
      Which firmware version?
        Tommy_Fr
        Firmware Electronics: Duet WiFi 1.04 (bought from one of the official Duet suppliers)
        Firmware Version: 2.01(RTOS) (2018-07-26b2)
        WiFi Server Version: 1.21
        Web Interface Version: 1.21.2-dc42
          kazolar
          I have a fairly complex home z operation, so I put all of it in homez.g and then I call that from homeall.g -- that's simple -- in fact in my homeall.g I simply have
          M280 P5 S160
          G91
          G1 Z4 F200 S2
          M98 Phomeaxis.g
          G90
          M98 Phomez.g
          so I can make whatever adjustments I need in each script for doing homing
            Tommy_Fr
            I noticed what you said @kazolar .
            I fixed toward direction for my Z axis to be rightful and easier to understand. It now goes in right direction (forward goes up, with Z increasing).
            When I use G30, G30 S-1 or G30 S-2, movement is in the wrong direction (so upward instead of downward); before the toward change for my Z axis it was going downward.
            So G30 direction and stop while probe is triggering does not work.
            undefined 1 Reply Last reply 15 Dec 2018, 15:12 Reply Quote 0
              dc42 administrators @Tommy_Fr
              @tommy_fr said in [Problem] Homing Z works with Macro but not with Home Buttons:
              Increasing positive Z must be the nozzle moving upwards or the bed moving downwards, so that the Z coordinate is the height of the nozzle above the bed.
                Tommy_Fr
                Yes, it was what I meant. Sorry if my english was incorrect. The nozzle is moving upwards with increasing positive Z.
                undefined 1 Reply Last reply 15 Dec 2018, 17:55 Reply Quote 0
                  In that case, I don't understand how G30 commands can be moving in the wrong direction; except that some variations of G30 command move the nozzle t the dive height (M558 H parameter) first, and all G30 commands move the nozzle back to the dive height after probing.
                  Have you tested the Z probe as described at https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe ?
                    Tommy_Fr
                    M558 H parameter was H5, I have changed it to 1 to try, and there is no difference.
                    Yes, I have tested Z as described at https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe.
                    But I wonder if there is a scale issue, because on DWC I have that for machine control:
                    It is normal X and Y lines have different values from Z line.
                    And when I click, for example, on Z+5, nozzle moves five times more longer away than on X+10.
                    So, is there a scale issue?
                    UPDATE: I edited my config.g file and changed Z steps per mm which was totally wrong (I set a M5 lead screw system instead of a M8, but value was still incorrect, changing from 4000 to 2560, I finally changed it to 400 which seems to be right or close of the rightful value). Z line on DWC did not change but movement matches more with the first both lines, X and Y.
                      So does Z homing work now?
                      undefined 1 Reply Last reply 18 Dec 2018, 07:36 Reply Quote 0
                        Tommy_Fr @dc42
                        @dc42 said in [Problem] Homing Z works with Macro but not with Home Buttons:
                        I just tried with g30 and it seems to work now. I will do further tests in the few coming day.
                          Tommy_Fr
                          I tested it within several ways, which with bed compensation and it works great.
                          Thank you to @dc42.
                          You can mark it as solved.
