    First print after upgrading to Duet3d WiFi
    3.4k
    • briskspiritundefined
      briskspirit @UnderDoneSushi
      @underdonesushi I have a cartesian printer, here you can read some info: https://forum.duet3d.com/topic/7148/qidi-x-pro-ffcp-clone-conversion-to-duet-2-wifi
        briskspirit @dc42
        @dc42 So I have calibrated pressure advance and got M572 D0 S0.242 , M221 didn't touched yet, non-linear didn't touched either.
        Print speed 50mm/s, outline 60%, solid infill 80%, retraction 1mm/s, retraction speed 60mm/s. Layer height 0.2mm, nozzle 0.4mm, extrusion multiplier 100%
        Everything is almost ideal except transition seam between start and end points and too much rounded corners(2 black lines on the third photo on the left are shadows from a ringing):
        4_1544793603246_IMG_1761.jpg 3_1544793603245_IMG_1760.jpg 2_1544793603245_IMG_1759.jpg 1_1544793603245_IMG_1758.jpg 0_1544793603244_IMG_1757.jpg
          briskspirit
          So I decided to check what is wrong... have changed acceleration and max speeds to those calculated and altered jerk values a bit. Have no excessive noise or step skipping. Re-calibrated pressure advance and got these results:
          M572 D0 S0.120
          print speeds: default 80mm/s, outline 65%, solid infill 65%, movement 150mm/s
          And have got very good results with seam(almost not visible), very good quality top infill. But got rippling on both X & Y axis (1mm period) and one very rounded corner(on photo).
          4_1544808372513_IMG_1767.jpg 3_1544808372513_IMG_1766.jpg 2_1544808372512_IMG_1765.jpg 1_1544808372512_IMG_1764.jpg 0_1544808372511_IMG_1763.jpg
          ; Axis kinematics
          M566 X1200 Y1200 Z12 E300:300 ; Set maximum instantaneous speed changes (mm/min)
          ;TODO: change max speed after changing extruders (https://reprapfirmware.org)
          M203 X12000 Y12000 Z600 E12000:12000 ; Set maximum speeds (mm/min) # Max speed before torque drop for X - 15354, Y - 11046
          M201 X2000 Y2000 Z50 E3000:3000 ; Set accelerations (mm/s^2) # Max accel for X by calculator 2820, for Y - 2155(estimate as I don't know exact weight)
            briskspirit
            At 40% of 80mm/s for outlines I am getting less period and less amplitude. (Seems like ~0.8mm)
            Edit:
            Played with :
            M204 P400
            M204 P384
            M204 P340
            M204 P192
            Period is changing, but not amplitude... same. But have got nice seam at M204 P192 (can't see it at all!) and rounded corner became less rounded.
              It looks like you got quite bad ringing because the amplitude is dying down very slowly. Check the tightness of the belt that controls the axis perpendicular to the face that exhibits the riging.
              You could try the dynamic acceleration adjustment feature in firmware 2.02RC6, see https://duet3d.dozuki.com/Wiki/Gcode#Section_M593_Configure_Dynamic_Acceleration_Adjustment.
              briskspiritundefined 1 Reply Last reply Reply Quote 0
                briskspirit @dc42
                @dc42 Both axis are with tight belts for sure, new pulleys and etc... And I don't hear any resonance or other audible problems. Both axis has almost the same ringing problem so I am lost with that problem... Something is flexing too much? Maybe could be the plastic carriage on LM8SUU bearings? I just can't understand what can be so wrong even at 30mm/s to give such a big ringing on both axis..
                Or could it be because my belts might be overtightened ? (Sounds like a guitar strings)
                  What stepper motors are you using, and what motor currents have you set?
                    briskspirit @dc42
                    X axis: nema 17 40mm 0.9deg stepper with current set at 80%, Y axis nema 17 40mm 1.8deg high impedance stepper with current set at 80%
                    M906 X1064 Y680 Z1200 E714:714 I30 ;
                    Full config:
                    ; Configuration file for Duet WiFi
                    M111 S0 ; Debug off
                    G21; Work in millimetres
                    M555 P1 ; Set firmware compatibility to look like RepRapFirmare (P2 for Marlin)
                    M575 P1 B57600 S1 ; Set auxiliary serial port baud rate and require checksum (for PanelDue)
                    M550 PQIDIPro ; Set machine name
                    M552 S1 ; Enable network
                    M587 S" " P" " I192.168.1.201 J192.168.1.1 K255.255.255.0 ; Configure access point and IP addresses. You can delete this line once connected
                    M586 P0 S1 ; Enable HTTP
                    M586 P1 S0 ; Disable FTP
                    M586 P2 S0 ; Disable Telnet
                    M569 P2 S0 ; Drive 2 goes backwards(Z drive)
                    M569 P3 S1 ; Drive 3 goes forwards(Tool 0)
                    M569 P4 S0 ; Drive 4 goes backwards(Tool 1)
                    M350 X16 Y16 Z16 E16:16 I1 S2 ; Configure microstepping without interpolation and Spread Cycle enabled
                    ;16T pulleys
                    M92 X200 Y100 ; Set steps per mm for X(is 0.9deg stepper) Y(is 1.8deg stepper)
                    ;T8*2 lead screw
                    M92 Z1600 ; Set steps per mm for Z
                    ;TODO: will be changed to geared 2.75:1 extruder with Bondtech gears and Nema 17 slim stepper
                    M92 E99:99 ; Set steps per mm for extruders E0 and E1 (Different for PLA and PETG??)
                    ; Axis kinematics
                    M566 X1200 Y1200 Z12 E2400:2400 ; Set maximum instantaneous speed changes (mm/min)
                    M201 X1000 Y1000 Z50 E1000:1000 ; Set accelerations (mm/s^2) # Max accel for X by calculator 2820, for Y - 2155(estimate as I don't know exact weight)
                    ; Steppers currents
                    M906 X1064 Y680 Z1200 E714:714 I30 ; Set motor currents (mA) and motor idle factor in per cent
                    M84 S30 ; Set idle timeout
                    M208 X264.5 Y154 Z169 S0 ; Set axis maxima
                    ;M579 X1.001895478 Y1.004419446; Scale axis (Correction factors based on measurment of printed models)
                    M574 X2 S0 ; Set active low endstop for X
                    M574 Y2 S0 ; Set active low endstop for Y
                    M574 Z2 S0 ; Set active low endstop for Z
                    M558 P0 H5 F120 T12000 ; Disable Z probe but set dive height, probe speed and travel speed
                    M557 X15:249.5 Y15:139 S20 ; Define mesh grid
                    ;Bed
                    M307 H0 A297.5 C982.3 D0.7 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
                    M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
                    M143 H0 S110 ; Set temperature limit for heater 0 to 110C
                    ;Extruders
                    M307 H1 A561.2 C153.0 D9.6 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
                    M305 P1 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 1
                    M143 H1 S310 ; Set temperature limit for heater 1 to 310C (All Metal hotend)
                    M307 H2 A797.2 C207.2 D8.1 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
                    M305 P2 T100000 B3950 C0 R4700  ; Set thermistor + ADC parameters for heater 2
                    M143 H2 S260 ; Set temperature limit for heater 2 to 260C
                    ; Part cooling
                    M106 P0 S0 L0 I0 F100 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                    ; Cooling block fans
                    M106 P1 S1 I0 F25000 H1:2 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                    M106 P2 S1 I0 F25000 H1:2 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                    M563 P0 D0 H1 ; Define tool 0
                    M563 P1 D1 H2 ; Define tool 1
                    G10 P1 X-34 Y0 Z0 ; Set tool 1 axis offsets
                    G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
                    ; Automatic power saving
                    M911 S20 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                    ; Custom settings
                    M501 ; Load saved parameters from non-volatile memory
                    override:
                    M572 D0 S0.120
                      briskspirit
                      @dc42 any ideas where to dig? Please!
                      • Danalundefined
                        Danal @briskspirit
                        @briskspirit said in First print after upgrading to Duet3d WiFi:
                        I don't know if being too tight causes ringing per se... but it does cause all kinds of other bad things.
                        "Tight, but not too tight." Yeah, what a load of... anyway... "Guitar string" is definitely too tight. IMNSHO.
                          dc42 administrators @briskspirit
                          ; Steppers currents
                          Which motors, exactly? Are you using 12V or 24V power? Your Y axis motor in particular almost certainly needs 24V power, and even then the maximum speed before it loses torque and becomes noisy is likely to be quite low.
                          briskspiritundefined 2 Replies Last reply Reply Quote 0
                            briskspirit @dc42
                            @dc42 24V power supply, max speed and acceleration was calculated from your online tools
                            X stepper JK42HM34-1334
                            Y stepper 42HB34F08AB-10
                              briskspirit @dc42
                              @dc42 I saw your answer in topic https://forum.duet3d.com/topic/8223/extruder-smoothness/2
                              I am using 1.8deg steppers on both extruders with steps per mm = ~100. (X16 microstepping, I1)
                              Maybe this is what is going on too?
                              I have two pancake motors with 0.9deg, but they are short/less powerful (waiting for gears to come)
                                Is the ringing pattern worse on the X face of the cube, or on the Y face? Whichever face is worse, it's probably the other axis that is ringing.
                                  briskspirit @dc42
                                  @dc42 Both axis has that ringing with same period but amplitude is worser on the Y face(so X is ringing with more amplitude)
                                    briskspirit
                                    What can cause almost the same ringing?
                                      briskspirit
                                      So I was a bit angry and furious and crashed my printer )) Some 8mm rods got bent and etc... Long story short: rebuilt my printer with new rods, installed dampers for Y and Z, tightened everything and now at 42mm/s speed I am getting very minimal ringing with very small amplitude(can see barely but can't feel by nail). So rebuilding helped or dampers 🙂
                                        I'm glad you solved it.
                                        The major cause of low-frequency ringing on a well-built machine is likely to be the interaction of the elasticity of the belts and the moving mass. That's why it's generally helpful to keep the moving mass as low as possible.
