Piezo Z probe problems/ Seeking alternatives !!!
Your trigger height should be a measured using this procedure: https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
gimme 5' to try that asap and provide you an update.
Thanks -
G30 S-1
Error: Z probe already triggered at start of probing move.Also, the machine continuously crashes to X axis endstop for 1 sec.....
Is that when doing homeall?
No. Only if I hit the G30 S-1 or the Bed Mesh compensation
Did you move the print head to bed center with the nozzle just touching the bed before doing G30 S-1?
Yes, I did exactly as the post you re-directed me dictated
So it goes from bed center to crash into the x endstop?
Yes, exactly
Can you post your config.g as it is now?
; generated by RepRapFirmware Configuration Tool v2 on Sun Dec 23 2018 19:43:56 GMT+0200 (Eastern European Standard Time); General preferences
M83 ; ...but relative extruder moves; Network
M550 P"THE PRINTER" ; Set machine name
M552 S1 ; Enable network
M587 S"Hector's House" P"2291052862" ; Configure access point. You can delete this line once connected
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P0 S0 ; Drive 0 goes backwards
M569 P3 S0 ; Drive 3 goes backwards
M350 X32 Y32 Z32 E32 I0 ; Configure microstepping without interpolation
M92 X160.00 Y160.00 Z791.50 E1800.00 ; Set steps per mm
M566 X780.00 Y780.00 Z300.00 E840.00 ; Set maximum instantaneous speed changes (mm/min)
M203 X16200.00 Y16200.00 Z420.00 E7200.00 ; Set maximum speeds (mm/min)
M201 X1800.00 Y1800.00 Z6.00 E250.00 ; Set accelerations (mm/s^2)
M906 X450.00 Y950.00 Z1000.00 E1389.00 I50 ; Set motor currents (mA) and motor idle factor in per cent
M208 X360 Y660 Z180 S0 ; Set axis maxima; Endstops
M574 Z1 S0 ; Set active low and disabled endstops
M574 X1 Y1 S1 ; Set active high endstops; Z-Probe
M558 P5 R0.4 H3 F400 T3600 ; Set Z probe type to effector and the dive height + speeds
G31 P400 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
M557 X0:330 Y0:660 S40 ; Define mesh grid; Heaters
M140 H-1 ; Disable heated bed
M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 280C; Fans
M106 P0 S0.5 I0 F600 H1 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P1 S0 I0 F200 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P2 S0 I0 F200 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic power saving
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss; Custom settings are not configured
You don't have the i1 parameter in the M558 command, If the sensor is a naked piezo cylinder (which is what it looks like), you must use i1 in that command as I said in my previous email, otherwise you will get the "already triggered" error.
@Phaedrux Thank you for taking the time and helping me out.
The truth is, there is so much time lost and solution is not found.If we accept the fact, that Duet is not compatible with this sensor, what are the other options available???
All I have is a BLclone and mechanical endstop. Bear in mind, I am seeking the easiest solution available, as I just learned G code, previous motherboard was plugNplay -
@dc42 Just added I1 and the nozzle crashed to bed on mesh compensation.
However, it did home correctly.; Z-Probe
M558 P5 I1 R0.4 H3 F400 T3600 ; Set Z probe type to effector and the dive height + speeds
M557 X0:330 Y0:660 S40 ; Define mesh grid -
@dc42 While crashing onto the bed, I got this error
G32 Error: Z probe was not triggered during probing move
Like I said before, test with the polarity reversed. Also test at different Z probing speeds (F parameter in the M558 command). See https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe for how to test it.
However, a naked piezo cylinder is a very primitive type of Z probe, and reliably operation may be hard to achieve. You might possibly find that P1 in the M558 command along with i0 works better than P8 (again, try both polarities).
Might want to trigger it by hand while testing rather than wait for it to contact the bed just in case. That way you can kill power if it doesn't trigger as expected.
@dc42 Okay, I tried P1 mode while erasing I1 , I didn't get a single error.
However, it crashes onto X endstop for 1sec continuously
So, what else can be done??
@phaedrux It happened now, will try to do that next time
