    Won't HOME after capacitive sensor installed
    5.6k
    • Excelonundefined
      Excelon
      2_1545659745647_homez.g 1_1545659745647_homeall.g 0_1545659745646_config.g
        Your homeall.g file is still using a G1 S1 Z move to seek the Z end stop, but since you're now using a z probe, you'll need to change that to G30 which you've already done in homez.
        In homez, you have the G30 to probe, but then you also have a G92 Z0 after that which you should remove, since it would be over writing the Z height you just established by probing.
        Make sense?
        • Excelonundefined
          Excelon
          Did you mean the G1 S2 Z-255 F1800 in homeall.g?
          Yes, makes perfect sense but still X is homing to the left and skipping the belt, even after changed. Am I missing something else? 1_1545680288012_homez.g 0_1545680288011_homeall.g
          Thanks you!
            Phaedrux Moderator @Excelon
            @excelon said in Won't HOME after capacitive sensor installed:
            Yes. Your homez looks correct now. Here's a cleaned up homeall for you:
            G91  ; relative positioning
            G1 Z5 F6000 S2  ; lift Z relative to current position
            G1 S1 X-235 Y-235 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
            G1 X5 Y5 F6000   ; go back a few mm
            G1 S2 X-235 Y-235 F360  ; move slowly to X and Y axis endstops once more (second pass)
            G90   ; absolute positioning
            G1 S2 X65 Y10 F2000   ; put head over the centre of the bed, or wherever you want to probe
            G30  ; lower head, stop when probe triggered and set Z to trigger height
            That sounds like a separate issue. What direction should it move in X to get to the switch?
            First we need to verify that your endstop switches are working as expected. See the procedure here: https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Testing_endstop_switches_using_the_web_interface
            Then we need to verify that your endstop configuration matches the location of the end stops. If you are standing in front of your printer looking at it, where are the end stops located? Left, right, back, front? The 0,0 origin of the printer should be the front left. The printer can home in either direction, but +Y should be towards the back and +X should be to the right. If the endstop is on the 0 side, it's a low end endstop. If it's on the + side, it's a high end endstop. This will dictate the direction you need to move in your homing files so that it moves towards the endstop.
            See here for more detail: https://duet3d.dozuki.com/Wiki/Centering_the_bed_or_setting_the_bed_origin
            • Excelonundefined
              Excelon
              @phaedrux said in Won't HOME after capacitive sensor installed:
              Then we need to verify that your endstop configuration matches the location of the end stops. If you are standing in front of your printer looking at it, where are the end stops located? Left, right, back, front? The 0,0 origin of the printer should be the front left. The printer can home in either direction, but +Y should be towards the back and +X should be to the right. See here for more detail: https://duet3d.dozuki.com/Wiki/Centering_the_bed_or_setting_the_bed_origin
              Thank you for the cleaned up homeall.g I replaced it and, yes, X is still grinding on home/endstop. The physical endstop switch is to the left if you are standing in front of the printer and looking forward, just like Y is away from you ( to the rear ). Funny thing is that homex.g is working properly.
              • Excelonundefined
                Excelon
                edit: One more thing to note. One you home each axes by them selves they home just fine. So, you can home X and Y and the nozzle will endup in the far left and the bed to the rear, but when I home Z the X and Y axis move their specified offset which is fine, but if I home Z again the X and Y move the same amount of offset until the belts are skipping on the other side. It's almost as if Duet doesn't know the orientation
                  @excelon Can you post your homex and homey files as well?
                  This may also help:
                  https://duet3d.dozuki.com/Wiki/Test_homing_behaviour
                  Excelonundefined 1 Reply Last reply Reply Quote 0
                  • Excelonundefined
                    Excelon @Phaedrux
                    @phaedrux
                    Sure, here you go. I'm sure I am missing something small. In the mean while I will take a look at the link you sent me.
                    1_1545682571033_homey.g 0_1545682571033_homex.g
                    • Excelonundefined
                      Excelon
                      I figured it out. I had to change from G1 S2 to G1 S1 in homeall.g. Now I have some fine tuning to do.
                        Glad you got it sorted out.
                        • Excelonundefined
                          Excelon @Phaedrux
                          @phaedrux thank you and dc42 for all your help. I love the challenge. Once the homeall actually worked I have to admit it felt pretty satisfying.
                          I had to run out of the house for a movie date but I tried to print something quickly just to see if all is working but..... homeall was fine. Start print position was even good but as soon as the X axis started its Jog to the right the nozzle started to lower and dug into the bed pretty aggressively. Can you give me some insight and/or links to research this issue please?
                          Happy Holidays and Merry Christmas
                          Thanks again for all your help.
                            Can you post the first 50 or so lines of the gcode file you tried to print?
                            Have you calibrated your z probe trigger height?
                            • Excelonundefined
                              Excelon @Phaedrux
                              I'm not sure if I set z probe height or not, so I would probably say no.
                              edit: Are you talking about G31 code in config.g?
                              Can you send me another link on this please?
                              50 lines of gcode
                              ; G-Code generated by Simplify3D(R) Version 4.1.1
                              ; Dec 24, 2018 at 10:50:20 AM
                              ; Settings Summary
                              ; processName,Process1
                              ; applyToModels,raspberri_pi_camera_case_back_v0.4,raspberri_pi_camera_case_front_m3_bot_v0.4.2,raspberri_pi_camera_case_front_m3_top_v0.4.2,raspberri_pi_camera_case_front_v0.1r,raspberri_pi_camera_case_front_v0.4.2,raspberri_pi_camera_case_back_v0.1r
                              ; profileName,Creality Ender 3
                              ; profileVersion,2018-07-11 08:00:00
                              ; baseProfile,
                              ; printMaterial,PLA
                              ; printQuality,Medium
                              ; printExtruders,
                              ; extruderName,Primary Extruder
                              ; extruderToolheadNumber,0
                              ; extruderDiameter,0.4
                              ; extruderAutoWidth,0
                              ; extruderWidth,0.4
                              ; extrusionMultiplier,0.9
                              ; extruderUseRetract,1
                              ; extruderRetractionDistance,4
                              ; extruderExtraRestartDistance,0
                              ; extruderRetractionZLift,0
                              ; extruderRetractionSpeed,2400
                              ; extruderUseCoasting,0
                              ; extruderCoastingDistance,0.2
                              ; extruderUseWipe,0
                              ; extruderWipeDistance,5
                              ; primaryExtruder,0
                              ; layerHeight,0.2
                              ; topSolidLayers,3
                              ; bottomSolidLayers,3
                              ; perimeterOutlines,3
                              ; printPerimetersInsideOut,1
                              ; startPointOption,2
                              ; startPointOriginX,0
                              ; startPointOriginY,0
                              ; sequentialIslands,0
                              ; spiralVaseMode,0
                              ; firstLayerHeightPercentage,100
                              ; firstLayerWidthPercentage,150
                              ; firstLayerUnderspeed,0.5
                              ; useRaft,0
                              ; raftExtruder,0
                              ; raftTopLayers,3
                              ; raftBaseLayers,2
                              ; raftOffset,3
                              ; raftSeparationDistance,0.14
                              ; raftTopInfill,100
                              ; aboveRaftSpeedMultiplier,0.3
                              ; useSkirt,1
                              ; skirtExtruder,0
                                https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe and then the trigger height section.
                                You'll need to do this to get the z probe working accurately. That would explain the first layer digging into the bed since it doesn't actually know where z0 is until you tell it how far the nozzle is from the bed when the probe triggers.
                                • Excelonundefined
                                  Excelon @Phaedrux
                                  @phaedrux
                                  2 questions.....
                                  1. How can I lower the nozzle -0.160 before the printing starts. When I start the print the nozzle is just a tad bit too high and I use -0.160 in babysteps to lower it to the correct height. Do I do this manually or can I do it in programming?
                                  2. Does Duet get the set Z height from running the mesh compensation or from the config.g code? Reason I ask is because after I running the mesh compensation and take a look at the grid its showing me that my bed is way off as far as being flat is concerned. So, basically I am wondering if running the mesh compensation tool is getting the height of the bed or just offering the variations in height?
                                    Well you set the trigger height like this:
                                    Calibrate the Z probe trigger height
                                    Make sure the dynamic test is successful (Z probe stops when it senses the bed) before doing this.
                                    Ensure that the Z offset in G31 in config.g is set to 0, these steps will be used to measure this actual offset. (send G31 Z0 to set it to 0).
                                    Use the X and Y jog buttons to position the nozzle over the centre of the bed
                                    Jog the nozzle down until it is just touching the bed or just gripping a sheet of paper. If you can't get it low enough, send G92 Z10 to trick the firmware into thinking the nozzle is higher than it actually is.
                                    Once you have the nozzle touching the bed, send command G92 Z0 to tell the firmware that the head is at Z=0
                                    Jog the head up by 5 to 10mm
                                    If the Z probe needs to be deployed, deploy it
                                    Send command G30 S-1. The nozzle will descend or the bed rise until the probe triggers and the Z height at which the probe stopped will be reported. If you are using a nozzle-contact Z probe, the trigger height will be slightly negative. For any other type of Z probe where the probe triggers before the nozzle contacts the bed, it will be positive.
                                    Repeat from step 5 two or three times to make sure that the trigger height is consistent.
                                    In Duet Web Control, go to Settings -> System Editor and edit the config.g file. Set the Z parameter in the G31 command to the trigger height that was reported. Save the file.
                                    Then if you still need a bit of baby stepping to get it right you can add or subtract the value of baby stepping to the g31 z value in config.g to make it persistent.
                                    The mesh compensation takes your 0 point and maps out the variations plus and minus across the bed and adjusts the z axis to keep the nozzle at the same distance.
                                    Excelonundefined 2 Replies Last reply Reply Quote 0
                                    • Excelonundefined
                                      Excelon @Phaedrux
                                      @phaedrux Thank you. Makes sense.
                                      Where exactly would I change total print speed and extruder amount as I have to manually increase extruder to 120% and reduce print speed to 80%. Secondly, if I have to reduce the print speed to 80% is the reduction of 20% factual in the actual numbers in the gcode? Same goes for the increase in the extruder?
                                      • Excelonundefined
                                        Excelon @Phaedrux
                                        @phaedrux Not sure if I am doing something wrong but added Z-.160 to the G31 command in config.g doesn't add the offset to the Z during a print. Any ideas?
                                          You'll have to calibrate the extruder e steps per mm. If you google e steps calibration you'll find some videos that go through it but it basically comes down to measuring a fixed distance on the filament and extruding the same amount and comparing what actually got used and then modifying the steps per mm to get them closer together. I wrote a long post about extruder calibrating a week or so ago if you search you might find it
                                          For print speed you should set that in the slicer.
                                            Here we go https://forum.duet3d.com/topic/8145/where-to-start-with-a-comprehensive-extrusion-calibration/2
