    Won't HOME after capacitive sensor installed
    5.6k
    • Excelonundefined
      Excelon
      I figured it out. I had to change from G1 S2 to G1 S1 in homeall.g. Now I have some fine tuning to do.
        Glad you got it sorted out.
        Excelonundefined 1 Reply Last reply Reply Quote 0
        • Excelonundefined
          Excelon @Phaedrux
          @phaedrux thank you and dc42 for all your help. I love the challenge. Once the homeall actually worked I have to admit it felt pretty satisfying.
          I had to run out of the house for a movie date but I tried to print something quickly just to see if all is working but..... homeall was fine. Start print position was even good but as soon as the X axis started its Jog to the right the nozzle started to lower and dug into the bed pretty aggressively. Can you give me some insight and/or links to research this issue please?
          Happy Holidays and Merry Christmas
          Thanks again for all your help.
            Can you post the first 50 or so lines of the gcode file you tried to print?
            Have you calibrated your z probe trigger height?
            • Excelonundefined
              Excelon @Phaedrux
              @phaedrux said in Won't HOME after capacitive sensor installed:
              I'm not sure if I set z probe height or not, so I would probably say no.
              edit: Are you talking about G31 code in config.g?
              Can you send me another link on this please?
              50 lines of gcode
              ; G-Code generated by Simplify3D(R) Version 4.1.1
              ; Dec 24, 2018 at 10:50:20 AM
              ; Settings Summary
              ; processName,Process1
              ; applyToModels,raspberri_pi_camera_case_back_v0.4,raspberri_pi_camera_case_front_m3_bot_v0.4.2,raspberri_pi_camera_case_front_m3_top_v0.4.2,raspberri_pi_camera_case_front_v0.1r,raspberri_pi_camera_case_front_v0.4.2,raspberri_pi_camera_case_back_v0.1r
              ; profileName,Creality Ender 3
              ; profileVersion,2018-07-11 08:00:00
              ; baseProfile,
              ; printMaterial,PLA
              ; printQuality,Medium
              ; printExtruders,
              ; extruderName,Primary Extruder
              ; extruderToolheadNumber,0
              ; extruderDiameter,0.4
              ; extruderAutoWidth,0
              ; extruderWidth,0.4
              ; extrusionMultiplier,0.9
              ; extruderUseRetract,1
              ; extruderRetractionDistance,4
              ; extruderExtraRestartDistance,0
              ; extruderRetractionZLift,0
              ; extruderRetractionSpeed,2400
              ; extruderUseCoasting,0
              ; extruderCoastingDistance,0.2
              ; extruderUseWipe,0
              ; extruderWipeDistance,5
              ; primaryExtruder,0
              ; layerHeight,0.2
              ; topSolidLayers,3
              ; bottomSolidLayers,3
              ; perimeterOutlines,3
              ; printPerimetersInsideOut,1
              ; startPointOption,2
              ; startPointOriginX,0
              ; startPointOriginY,0
              ; sequentialIslands,0
              ; spiralVaseMode,0
              ; firstLayerHeightPercentage,100
              ; firstLayerWidthPercentage,150
              ; firstLayerUnderspeed,0.5
              ; useRaft,0
              ; raftExtruder,0
              ; raftTopLayers,3
              ; raftBaseLayers,2
              ; raftOffset,3
              ; raftSeparationDistance,0.14
              ; raftTopInfill,100
              ; aboveRaftSpeedMultiplier,0.3
              ; useSkirt,1
              ; skirtExtruder,0
                https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe and then the trigger height section.
                You'll need to do this to get the z probe working accurately. That would explain the first layer digging into the bed since it doesn't actually know where z0 is until you tell it how far the nozzle is from the bed when the probe triggers.
                • Excelonundefined
                  Excelon @Phaedrux
                  @phaedrux
                  2 questions.....
                  1. How can I lower the nozzle -0.160 before the printing starts. When I start the print the nozzle is just a tad bit too high and I use -0.160 in babysteps to lower it to the correct height. Do I do this manually or can I do it in programming?
                  2. Does Duet get the set Z height from running the mesh compensation or from the config.g code? Reason I ask is because after I running the mesh compensation and take a look at the grid its showing me that my bed is way off as far as being flat is concerned. So, basically I am wondering if running the mesh compensation tool is getting the height of the bed or just offering the variations in height?
                    Well you set the trigger height like this:
                    Calibrate the Z probe trigger height
                    Make sure the dynamic test is successful (Z probe stops when it senses the bed) before doing this.
                    Ensure that the Z offset in G31 in config.g is set to 0, these steps will be used to measure this actual offset. (send G31 Z0 to set it to 0).
                    Use the X and Y jog buttons to position the nozzle over the centre of the bed
                    Jog the nozzle down until it is just touching the bed or just gripping a sheet of paper. If you can't get it low enough, send G92 Z10 to trick the firmware into thinking the nozzle is higher than it actually is.
                    Once you have the nozzle touching the bed, send command G92 Z0 to tell the firmware that the head is at Z=0
                    Jog the head up by 5 to 10mm
                    If the Z probe needs to be deployed, deploy it
                    Send command G30 S-1. The nozzle will descend or the bed rise until the probe triggers and the Z height at which the probe stopped will be reported. If you are using a nozzle-contact Z probe, the trigger height will be slightly negative. For any other type of Z probe where the probe triggers before the nozzle contacts the bed, it will be positive.
                    Repeat from step 5 two or three times to make sure that the trigger height is consistent.
                    In Duet Web Control, go to Settings -> System Editor and edit the config.g file. Set the Z parameter in the G31 command to the trigger height that was reported. Save the file.
                    Then if you still need a bit of baby stepping to get it right you can add or subtract the value of baby stepping to the g31 z value in config.g to make it persistent.
                    The mesh compensation takes your 0 point and maps out the variations plus and minus across the bed and adjusts the z axis to keep the nozzle at the same distance.
                    Excelonundefined 2 Replies Last reply Reply Quote 0
                    • Excelonundefined
                      Excelon @Phaedrux
                      @phaedrux Thank you. Makes sense.
                      Where exactly would I change total print speed and extruder amount as I have to manually increase extruder to 120% and reduce print speed to 80%. Secondly, if I have to reduce the print speed to 80% is the reduction of 20% factual in the actual numbers in the gcode? Same goes for the increase in the extruder?
                      • Excelonundefined
                        Excelon @Phaedrux
                        @phaedrux Not sure if I am doing something wrong but added Z-.160 to the G31 command in config.g doesn't add the offset to the Z during a print. Any ideas?
                          You'll have to calibrate the extruder e steps per mm. If you google e steps calibration you'll find some videos that go through it but it basically comes down to measuring a fixed distance on the filament and extruding the same amount and comparing what actually got used and then modifying the steps per mm to get them closer together. I wrote a long post about extruder calibrating a week or so ago if you search you might find it
                          For print speed you should set that in the slicer.
                            Here we go https://forum.duet3d.com/topic/8145/where-to-start-with-a-comprehensive-extrusion-calibration/2
                              Phaedrux Moderator @Excelon
                              @excelon said in Won't HOME after capacitive sensor installed:
                              Have you varified your z0 position? If you job the nozzle to z0 is it just touching the bed?
                              Is your mesh compensation accurate? Is it even being loaded? G29 S1 to load the saved height map.
                              • Excelonundefined
                                Excelon @Phaedrux
                                @phaedrux Not sure what you mean by " Is your mesh compensation accurate? ". Do I have to run the mesh comp tool once again after I find the correct height?
                                I was able to get the negative offset to work in the Z axis but I had to add a G30 P1 Z-.160 comand after G31 command. Should I not have to do that?
                                M574 Z5 S2 ; Set Z probe
                                M558 P5 H5 F240 T6000 I1 ; Set Z probe type to switch and the dive height + speeds
                                G31 P1000 X-75 Y-45 Z0 ; Set Z probe trigger value, offset and trigger height
                                G30 P1 Z-.160
                                M557 X-8:172 Y0:220 S20 ; Define mesh grid
                                  I'm not really clear on that actually. I don't think so. As long as the probe is getting a repeatable result I think the mesh should be valid and the height offset would apply to all points.
                                  But what I mean by is your your height map accurate is that if you have mesh compensation active and you move to z1 and then jog the nozzle in X and Y does it actively adjust the z axis to keep the nozzle a steady 1mm away from the bed, or does it seem to get closer or farther as it moves?
                                  A good test of that is to print a bed level test STL that prints some lines across the surface of the bed. If the mesh is accurate it should give a consistent first layer. If it's not some areas might be too squished and others too far away.
                                  Maybe you can post an image of your mesh compensation result. It can be easier to judge a good map just from looking at it sometimes.
                                  Your g31 doesn't look right. The z value shouldn't be zero. Once you've used that trigger height process using g30 s-1 to measure it you should put that value there.
                                  I'm not sure what that g30 p1 is for but it probably shouldn't be there in config.g. your problem should be resolved once you have a measured value entered in the g31 z in the line above.
                                  Can you post your config.g and homing files as they are now as well? I think you're pretty close to getting everything in place.
                                  • Excelonundefined
                                    Excelon @Phaedrux
                                    @phaedrux
                                    OK. So, the mesh comp tool/map is active and working 100%. I know this because my bed is pretty messed up from pile driving the nozzle into the corner trying to figure out a few things ( my fault ). Not to mention that I didn't know how to code in the mesh mapping into my gcode and used to have to do it manually, but not anymore, thank you.
                                    As for the G30 P1 in the config.g.... I entered it there because no matter the value I entered in the G31 line, it would make no difference. I know you have said before that I should be able to enter a Z offset in the G31 line, but it doesn't work.
                                    NOTE: I removed the Z neg offset becuase I manually changed it but I would still like to be able to offset Z in the future in case I changed nozzles or the like.
                                    Most recent files.....
                                    3_1545799253017_homez (1).g 2_1545799253017_homey.g 1_1545799253017_homex.g 0_1545799253016_homeall (1).g
                                    • Excelonundefined
                                      Excelon
                                      Thank god for auto bed leveling
                                        Your home all is a little weird since it does a fast home of x and y, then moves back a little bit and homes z, and then moves some more in x and y.
                                        You should finish all the x and y moves first and then move the probe to the center of the bed and g30 there to get a good center point z height. Use the same coordinates for the homez for consistency.
                                          Now just missing config.g
                                          • Excelonundefined
                                            Excelon @Phaedrux
                                            @phaedrux 0_1545804443527_config.g
                                            Sorry, I missed that somehow...
