    waste / nozzle priming bucket - material for lip?
    3D Printing General Chat
    10
    23
    2.3k
    • sonderzugundefined
      sonderzug
      something that Stratasys FDM printers do which works very well is the combination of a fine brass brush and rather stiff (orange) silicone lip. These come as a set in one piece with each set of nozzles and thus can be swapped after some 100 machine hours. They are clipped into the frame to align with the waste bucket. The nozzle is brushed off first in a swift back-and-forth Motion, then wiped off with the lip.
      I would opt for rather hard material for your silicone lip. I don't see the material from e3d's socks lasting very long in this application…
      best regards, Niklas
      • vwegertundefined
        vwegert
        @bret4 I do print a brim as well. With my old (non-Duet) Cartesian printer, any ooze that occurred was simply dropped off the edge of the print bed because the nozzle home position was to the left and front of the print surface. With my new Duet-driven Delta, the home position is right above the print bed of course, so all the "droppings" from heating the nozzle or changing the filament land on the print bed and - with my usual bad luck - end up in the printed piece.
        So far, I haven't tried anything but PLA yet, but once the enclosure is completed, I will try other stuff as well. I should have enough
        • vwegertundefined
          vwegert @briskspirit
          @briskspirit Do you know how the E3D silicone "sock" would handle being dragged across a metal brush? I don't - I could image it might be damaged or even pulled off partially or completely...
          briskspiritundefined 1 Reply Last reply Reply Quote 0
          • briskspiritundefined
            briskspirit @vwegert
            @vwegert I cut that sock to free whole nozzle as it got ripped after 3-4 prints ...
            • mrehorstdmdundefined
              mrehorstdmd
              I have a Cubex Duo that came with a waste bucket. It had a spring loaded teflon strip that the nozzle would scrape against to knock the drool off the extruder. The teflon strip worked fine even at ABS print temperatures because it was only in contact with the nozzle for a fraction of a second as the nozzle passed over it.
                briskspirit @mrehorstdmd
                @mrehorstdmd good idea!
                • chandersundefined
                  chanders
                  I have seen some printers use soda cans that were cut into strips as a wipe area.
                  vwegertundefined 1 Reply Last reply Reply Quote 0
                  • vwegertundefined
                    vwegert @chanders
                    @chanders Hmmmm... Makes me want to check whether I could fit the lower half of a soda can into my printer...
                      deckingman @vwegert
                      @vwegert This is exactly what I do. I use a strip of silicon rubber which is pressed into a slot in a long "bucket". My purge commands consist of extruding some filament then wiping the nozzle back and forth across this strip. I'm 10,000 miles away from home at the moment and only have my phone with me so it's not easy to post a link. However, take a look at my blog which is linked in my signature. There is a detailed post describing how I print with a purge bucket. HTH
                      • vwegertundefined
                        vwegert @deckingman
                        @deckingman This looks like what I had in mind originally. Do you happen to remember what kind of silicone strip you used?
                          deckingman @vwegert
                          @vwegert Not off hand. I think I just did a "Google search" for silicon rubber strip or some such term.
                            mrehorstdmd @deckingman
                            @deckingman You could probably get a silicone strip from a squeegee...
                            • tech-ratonundefined
                              tech-raton
                              I used a bit of silicone sock from e3d. It worked nice...
                              Silicon and heat resistance...
                                deckingman @mrehorstdmd
                                @mrehorstdmd said in waste / nozzle priming bucket - material for lip?:
                                Yes that would have worked too. I found some strip about 20mm X 3mm but IIRC had to buy a I metre length.
                                • jckrayundefined
                                  jckray
                                  I found that the wire bush destroyed a brass nozzle pretty quickly. I ended up using a silicone strip as others have mentioned. I get the silicon from McMaster-Carr and then cut it to size.
                                  https://www.mcmaster.com/3635k11
                                  John
                                  Founder of Hydra Research LLC, developers of the open-source 3D printers and providers of 3D printing services.
                                  https://www.hydraresearch3d.com/
                                    mrehorstdmd
                                    There's a lot of small, cheap, kitchen junk that's made of silicone.
                                    • vwegertundefined
                                      vwegert @mrehorstdmd
                                      @mrehorstdmd I've actually ordered one of these cheap-o baking mats made of heat-resistant silicone - cheap enough to try and cut it to strips...
                                        deckingman @vwegert
                                        @vwegert I kind or forgot but I actually made a video of my purge bucket in action. If it's any use, check it out here https://www.youtube.com/watch?v=zNNmZCXErYY&lc=z234cfh4dkylhh4ra04t1aokgl1ownrihxxz0fiwil5xrk0h00410
