cura trouble
21
2.4k
    paul12
    i have a custom delta printer with duet 2 wifi, i usually use slic3r, but when i started using cura on my ender 3, the top surface finish was better. so when i tried using cura with delta the extrusion was at a very very low rate, i have turned on " relative extrusion" on cura.
    Should i make any other changes to the cura or duet settings?
    Also which slicer will everyone recommend?
    ; generated by RepRapFirmware Configuration Tool on Sat Nov 03 2018 14:41:59 GMT+0800 (China Standard Time)
    M555 P1 ; Set firmware compatibility to look like RepRapFirmare
    ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
    M665 R258 L397.110 B150 H330 ; Set delta radius, diagonal rod length, printable radius and homed height
    M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
    M550 PSPARX3D ; Set machine name
    M552 S1 ; Enable network
    ;*** Access point is configured manually via M587
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M569 P3 S0 ; Drive 3 goes backwards
    M584 X0 Y1 Z2 E3 ; Apply custom drive mapping
    M350 X16 Y16 Z16 E16 I0 ; Configure microstepping without interpolation
    M92 X80 Y80 Z80 E100.7200 ; Set steps per mm
    M566 X1000 Y1000 Z1000 E1000 ; Set maximum instantaneous speed changes (mm/min)
    M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
    M201 X3000 Y3000 Z3000 E1500 ; Set accelerations (mm/s^2)
    M906 X1200 Y1200 Z1200 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 Z-0.1 S1 ; Set minimum Z
    M574 X2 Y2 Z2 S0 ; Set active low endstops
    M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
    M558 P9 H10 F108 T3600 ; Set Z probe type to bltouch and the dive height + speeds
    G31 P25 X0 Y13 Z2.481 ; Set Z probe trigger value, offset and trigger height
    M557 R140 S20 ; Define mesh grid
    M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
    M305 P1 T100000 B4388 C0 R4700 ; Set thermistor + ADC parameters for heater 1
    M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P2 S1 I0 F500 H0 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M563 P0 D0 H1 ; Define tool 0
    ; Automatic power saving
    M911 S10 R11 P"G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
    T0 ; Select first tool
    M501
      burtoogle
      Hi @paul12 , please attach some typical gcode for the delta so I can check if there's any obvious issues. Thanks.
      undefined 1 Reply Last reply 9 Jan 2019, 21:18 Reply Quote 0
        paul12
        0_1547068635101_CFFFP_Avengers_logo_keychain.gcode
          paul12 @burtoogle
          @burtoogle thank you for the quick reply sir.
            burtoogle
            I've taken a quick look at the gcode and there are some lines whose extrusion length is less than the resolution of your extruder (i.e your extruder appears to be around 100 steps/mm) but some of the extrusions are less than 0.01 mm in length so you may possibly getting underextrusion. This is a drawback of using relative extrusion when the extruder resolution is low.
            Look at the E values shown on the LHS of this image and you will see what I mean...
            undefined 1 Reply Last reply 10 Jan 2019, 05:37 Reply Quote 0
              What firmware version are you using. There was a bug fixed in 2.02 that should have helped in these cases. You could also increase your extruder microstepping to get a higher E steps per mm value. x64 or x128 seems to help without hitting the CPU too hard.
              undefined 1 Reply Last reply 10 Jan 2019, 05:33 Reply Quote 0
                Naqaj
                Every other version update, CURA resets the material settings back to 3mm filament without any feedback to the user, make sure this has not happened to you and it's still set to 1.75mm
                undefined 1 Reply Last reply 10 Jan 2019, 05:36 Reply Quote 0
                  Wyvern
                  I've had multiple objects slice with missing layers for no reason. Have to play with scale and horz. Expansion. And I'm talking simple stuff.
                    paul12 @Phaedrux
                    @phaedrux am on the latest version released 2.02(RTOS) (2018-12-24b1).
                    Increasing the micro steps will solve my issue sir?
                      paul12 @Naqaj
                      @naqaj i had made it to 1.75 while making the custom machine profile on latest version. let me confirm it again. Thank you
                        paul12 @burtoogle
                        @burtoogle i will try increasing the micro steps like @Phaedrux suggested.
                          Phaedrux Moderator @paul12
                          @paul12 Worth a shot.
                          You can test it by adding M350 E128 after your M92 entry. No other changes needed.
                          I also just noticed that you have interpolation disabled with I0 on your M350 line. That's probably making your printer much noisier than it need be.
                          I would recommend you change your lines to be
                          M350 X16 Y16 Z16 E16 I1 ; Configure microstepping without interpolation
                          M350 E128
                          undefined 1 Reply Last reply 10 Jan 2019, 06:50 Reply Quote 0
                            paul12 @Phaedrux
                            @phaedrux WOWWW!!! adding the interpolation just made the printer SUPER silent.
                            But still there is under extrusion 😞
                            undefined 1 Reply Last reply 10 Jan 2019, 13:24 Reply Quote 0
                              burtoogle
                              Correct me if I am wrong but doesn't interpolation only work when the steps is 16?
                              undefined 1 Reply Last reply 10 Jan 2019, 09:51 Reply Quote 0
                                dc42 administrators @burtoogle
                                @burtoogle said in cura trouble:
                                On the Duet WiFi/Ethernet, that's correct. On the Maestro, interpolation works at all microstep settings.
                                  paul12
                                  anyone using cura for delta printers? Or please do recommend any other slicer for delta printers compatible with Duet ( Other than slic3r 🙂 )
                                  undefined 1 Reply Last reply 10 Jan 2019, 20:41 Reply Quote 0
                                    burtoogle
                                    @paul12 , I have 2 delta printers with Duets and I only use Cura. I (almost invariably) get beautiful prints with the majority of flaws being due to the mechanical limitations of the printers rather than poor gcode from Cura or problems with the Duets.
                                      burtoogle @paul12
                                      @paul12 said in cura trouble:
                                      Yes, you need to increase the microsteps or not use relative extrusion mode (I think).
                                      undefined 1 Reply Last reply 10 Jan 2019, 14:12 Reply Quote 0
                                        Changing to relative extrusion mode won't make any difference, unless that affects the way that Cura does its calculations, causing it to command different extrusion amounts in the GCode.
                                          richardmckenna @paul12
                                          @paul12 I was a die hard Simplify3d user on my corexy. Mainly because I wanted my moneys worth. But it was the only slicer that gave me great prints consistently.
                                          Now I’ve built my large delta I’m really struggling to get good prints with Simplify3d. So last night I used Cura for the first time in well over a year and I have to say the print came out spotless. It was probably the best print I have ever had, nothing to clean up, no blobbing or stringing and the sides were just amazing.
                                          Think I’ll be using Cura more often.
                                          undefined 1 Reply Last reply 11 Jan 2019, 06:18 Reply Quote 1
                                          7 out of 21
