Pressure advance possibly not working correctly
@deckingman they're all over, but my seems are not always in the same place, so I'd have to rotate the printed model to show you all of them.
@garyd9 I'll try that and let you know
@garyd9 I tried it and they're still there. That's odd because it's only a couple mm of retraction.
@gnydick said in Pressure advance possibly not working correctly:
If you turn off pressure advance and the problem still exists, it strongly suggests that pressure advance isn't the issue. (Are you 100% certain that pressure advance wasn't enabled? The best way to be sure is to run M572 from the gcode console while a print is running and verify that the returned value is 0.00.)
Hi @gnydick , could you please post some gcode that has this problem. Thanks.
Layers look thicc, .8 nozzle?
Every machine I've used with a .8 or larger exhibits this issue.
@wyvern yes, .8 nozzle. That could be it.
@gnydick I don't know how to fix it or what it is, but it shows on tight curves.
.6 is usable for general use, I use .8 for simple geometry parts that need to be strong. -
@martin1454 thanks
