    is it alive or dead
    2.9k
    • yamanundefined
      yaman
      I try to connect with USB
      @dc42 said in is it alive or dead:
      from your photos how you connected the capacitive sensor, buck regulator and Duet together, so I can't say what damage may ha
        Looks like the main processor is OK but not the WiFi module. You could try re-installing the WiFi firmware.
        yamanundefined 1 Reply Last reply Reply Quote 0
        • yamanundefined
          yaman @dc42
          can you tell me how ?
            If the wifi firmware is already on the SD card, sending M997 S1 will install it.
            • yamanundefined
              yaman
                Set the line ending in YAT to LF only (in the Text Settings), then you will be able to read the responses more easily.
                yamanundefined 2 Replies Last reply Reply Quote 0
                • yamanundefined
                  yaman
                  • yamanundefined
                    yaman @dc42
                    This post is deleted!
                    • yamanundefined
                      yaman @dc42
                        You didn't set the line ending in YAT to LF Only, so the response to M997 S1 was truncated, and I can't tell whether the firmware update succeeded or not.
                        • yamanundefined
                          yaman
                          truncated
                            dc42 administrators @yaman
                            @yaman, you still haven't set the YAT line ending properly. Go to Terminal, Settings, Text Settings, EOL Sequence.
                            • yamanundefined
                              yaman
                              • yamanundefined
                                yaman @dc42
                                • yamanundefined
                                  yaman @dc42
                                  • yamanundefined
                                    yaman
                                    is it disable or not function ?
                                    • yamanundefined
                                      yaman
                                      • yamanundefined
                                        yaman @dc42
                                        I think the WIFI module is dead
                                        right now I make order new controller
                                        but entail it's arrive can I replace with this
                                        https://www.amazon.com/gp/product/B07BRQTLZG/ref=ox_sc_act_title_1?smid=A144J8BE3R51KJ&psc=1
                                        is will work if I change the old one with this ?
                                          I agree, the WiFi module is dead, because it failed to connect at all the baud rates that were tried. With the right tools (hot air desoldering equipment or very low melting point solder), it can be removed and then replaced. Don't try to remove it without one of those.
                                          The ESP-12S that you linked to is the correct module. Or you can use the ESP-07S + external antenna, such as https://www.amazon.com/Chironal-ESP8266-ESP-07S-Wireless-Transceiver/dp/B07M7L1CGL/ref=sr_1_12?s=electronics&ie=UTF8&qid=1548322176&sr=1-12&keywords=esp-07s.
                                          • Anidalundefined
                                            Anidal
